Question about Razor MX350 DIRT ROCKET - BLUE
Bike fully charged but when you turn trottle bike just won't move
When you turn the trottle you hear a clicking sound but bike just does not move
5 Suggested Answers
albertjunior
  • 56 Answers
SOURCE: The bike says that it is fully charged but is very
the battery is bad....because of over charge....u need a new one!....
Posted on Oct 06, 2009
SOURCE: battery is fully charged, when
Did you ever solve this problem? Having the same issue
Posted on Mar 27, 2011
SOURCE: off-on switch as bright as when it was new. green
On n off switch on bike wont stay on. U can turn it on when charger is hooked up to it but once u take plug out red light goes off.
Posted on Jan 20, 2013
erickedubbs
  • 15 Answers
SOURCE: Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Posted on Apr 13, 2013
Springer classic clicks when trying to start
Make sure the battery is fully charged. Contrary to what some people will tell you, Harley batteries are not fully charged when shipped to dealerships. I work at a dealership and it normally takes a full 8 hour shift to charge a new battery that fits your bike. The clicking sound in normally caused by a low battery. Good luck!
Apr 02, 2014 | 2005 Harley Davidson FLSTSC - FLSTSCI...
2008 yamaha r6 white smoke out of exhaust and when i cut the bike off it will not start again
Sounds like it overheated. White smoke can be oil but, with it not starting sounds like coolant and it overheated. Take it to a repair facility for confirmation.
May 16, 2012 | 2008 Yamaha YZF-R6
Okay i own 1996 suzuki gsxr750 now i have recently took everything off the bike to get parts painted tank,fairings, etc. while i was doing some minor things with the bike while it was completly stripped...
Bike batteries need full charge to start a bike, if there is less than full charge you can't even push start them. No click generally means no charge, the clicking sound is the solenoid working.
When you just start the bike and run it at idle, even fast idle. The battery does not get sufficient charge. What you take out of it to start it, is more than what you put back in it when you run it at idle. Bikes need to be at road speed to charge efficiently.
Also just sitting around they discharge, you may have an earth leak also. That causes your battery to discharge at a more accelorated rate than normal. If it has a clock in it, this bleeds off a small amount of power but still enough if it isn't being correctly charged.
Aug 01, 2011 | Suzuki GSX-R 750 Motorcycles
My bike won't start, it is a 2000 1500 intruder suzuki, the starter was looked at by a professional and the starter is good. All lights work, battery is fully charged, the only way I can start my bike...
check you starter sol it is undre driver side fuel tank cover jump it across the two red and black wire with key on and see if it turn over if it start you will need to buy another one cost about 75.00
Jul 28, 2011 | 2000 Suzuki VL 1500 Intruder LC
I keep trying to get it to turn over but it keeps clicking and wont turn over. im thinking its the starter but it worked fine yesterday i had to jump it and it would turn over yesterday. i left it in the...
Most likely it is your battery. If it started when you jump started it then the battery was too weak, and it won't hold a charge, so when you park it overnigt it is not strong enough to start the bike. You may have loose or corroded cables and that can lead to a weak battery because it wasn't getting charged like it should. Unfortunatly when bike batteries get that weak they usually need replaced. Unlike a car battery they can't take the punishment of improper charging.
Apr 21, 2011 | 1981 Honda CX 500 A
Not responing to the trottle.
The Main controllers always seem to be the problem on these quads. If you have a voltmeter you must check the batteries for a complete charge. You should read 24volt or around 24.60 vdc. If you have a full charge usaully 12-16 hrs by the charger supplied with the quad. Than check the output to the motor by disconnecting the motor wire and put your leads in the sockets and verify if you are getting voltage to the motor. Make sure you re-connected the battery before testing the controller output. You should see a varying voltage from 0-24 vdc when the throttle is turned. If you do not see anything at the motor lead and your batteries show charge. the controller is faulty or you have a bad connection. Un-plug and plug and connectors.
Dec 28, 2010 | Razor Dirt Quad Bike
My 2002 kawasaki ninja 250 is having trouble starting. (electric start) At first it was just giving me this clicking sound kinda like when your car wont turn over and start. So I replaced the battery for...
The oil light is on because the engine isn't running to build any oil pressure. Sounds like the new battery may need to be charged fully. After the battery is fully charged, and the 'clicking' noise is back (or not) check the battery connections for corrosion--especially at the positive terminal. If ok, you should get one solid click when trying to start. If ok, but still not starting, jump the two heavy terminals of the solenoid (click source) with a heavy wire which should bump the starter motor. If nothing, then the starter motor needs service--usually the brushes inside fail to make contact with the armature due to brush wear, or weak springs. Most dealers will likely only sell you a new starter--no internal parts. Hope this helps!
Oct 04, 2010 | kawasaki Ninja 250R Motorcycles
Off-on switch as bright as when it was new. green light on charger indicates the battery is fully charged. turn throttls and bike barely moves..... ?????
check voltage with a multimeter set on volts before trying to trottle and then after you trottle it should close to the same voltage. If not then you need to replace battery.
Jul 07, 2010 | Razor MX350 DIRT ROCKET - BLUE
I have a '99 FZS Fazer 600, and it won't start. I've been having problems with the battery running down when riding with lights on, and I sometimes have to push start the bike. Now though, the bike cut out...
i had same problem turned out to be electrical issue check all your wiring connections under the seat and under your fuel tank and if there all fine try checking that your fuel pump motor is running mine wasnt because of damp on my wiring connectors. when you turn on the ignition the bike should click a few times and your fuel pump should come on look under your tank looks like this with 2 tubes running from your fuel tank http://cgi.ebay.co.uk/yamaha-fzs-600-fazer-00-fuel-pump_W0QQitemZ250559832283QQcmdZViewItem?rvr_id=&rvr_id=&cguid=6d2769071260a0e2048322d3fffcee00
this needs to be running or you will be riding the bike on gravity fed fuel and as soon as you open the bike up you will not get enough to the engine and will cut out hope this helps
Oct 04, 2009 | 1999 Yamaha FZS 600 Fazer
Razor MX350 DIRT ROCKET - BLUE Logo
168 people viewed this question
Top Razor Cycling Experts
Ted Maxwell
ray gallant
wayne-m
Are you a Razor Cycling Expert? Answer questions, earn points and help others
