Question about Behringer Europower Pmp5000 Powered Mixer Pmp5000
Europower pmp 5000 turn off issue - Behringer Europower Pmp5000 Powered Mixer Pmp5000
  • 5603 Answers
SOURCE: I have a beringer pmp 5000. Out of the box, I
Yes, the fan is temperature controlled. You have to drive it a bit before it runs, and then it is kind of throttled versus temperature.
Posted on Sep 22, 2009
hmerchant110
  • 7191 Answers
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Jan 15, 2010
  • 5603 Answers
SOURCE: europower pmp 3000 120v or 220v ?
Unit has wide range power supply will operate on 100 volts to 240 volts without any change other than possible plug adapter to mate with each countries receptacle standard.
Posted on Feb 06, 2010
pgh_pa_guy
  • 2992 Answers
SOURCE: Fuse blown on Europower PMP
You don't need to use a ceramic fuse if one's not available. You can also use a glass cartridge fuse as well. Just be sure the rating is the same. Be aware, though, that fuses seldom blow on their own. Usually it's because something else has shorted. So don't be surprised if replacing the fuse only results in another blown fuse. Behringer stuff is notoriously cheap and under-protected, so by the time the fuse blows it's usually more trouble than it's worth trying to fix. But maybe you'll be lucky and it will be something simple. Good luck, and thanks for using Fixya!
Posted on Jul 06, 2011
  • 5603 Answers
SOURCE: my europower pmp 2000 powered mixer wont turn on
This is likely a power supply failure, possibly brought on by a failure of one of the amp channels.
This is probably close to your supply:
http://elektrotanya.com/behringer_sps600_power-supply_sch.pdf/download.html
Scroll down to "get manual" and click on that to download schematic. Ignore other download links.
Posted on Aug 05, 2011
If possible can i get schematic for Europower pmp 980S ?
Request the schematic diagram directly from Europower.
Mar 10, 2018 | Music
I have my pc hooked via 1/8" to 1/4' to my europower pmp518m and my sound is very low, but my mics are very loud (need music loud also)
The 1/8 jackon the PC is Stereo so you would need a stereo splitter to then go into separate jacks or maybe tape input on the PMP. Plugging in a mono jack shorts out one side of the PC audio out. Make sure you use a splitter type and NOT a 1/8 to 1/4 stereo cable. It must split into TWO cablles to plug into the PMP.
Mar 12, 2013 | Music
One side of my europower pmp 5000 is out, the other is fine.....what up?
What is up is one of the two power amps is blown... I know this problem... It is USUALLY the rearmost channel which goes to the left Speakon faacing the back. Weak insulation between layers of the multilayer circuit board arcs and fries three transistors and a diode and sometimes a few more components. It takes a lot of skill to restore the module and is beyond most repair shops. A whole new module costs about $155 from Full Compass. The amp is an HCA2400 module, but you MAY need the Behringer part number to order it from Full Compass. Also please read my tip on Fixya for PMP mixers regarding the hazard when using 1/4 inch plugs from the Speakon connectors... the Channel A sleeve is the "hot", not the tip and if you ground the sleeve, goodbye channel A...
Aug 18, 2011 | Behringer Europower Pmp5000 Powered Mixer...
My europower pmp 2000 powered mixer wont turn on and the fuse appears good. I turned it on and it immediately turned off ,nothing smells burnt. any ideas on what it could be
Aug 05, 2011 | Behringer Pmp2000 Europower 800w 10ch...
There are two resistors 310-3 10R on the power supply of the Europower pmp 5000, i need to know if it is 330k or 330om.
The schematic for the power supply does NOT show resistors in the 310-3... Where are these in the circuit... IF THESE happen to be the gate drive resistors for the IGBT's they are 33 ohms. If you have hasd a failure in this area there are other parts that typically get destroyed, including one or both the speedup diodes at the same gates; Here is the complete PMP5000 schematic:
http://elektrotanya.com/behringer_europower-p0569_hca2400_sps1000_dpx_pmp-1280s_5000_sch.pdf/download.html
Scroll down to "get manual" and cliick to download. IGNORE other download links. If you need help restoring the PSU get back to me.
Jul 20, 2011 | Behringer Europower Pmp5000 Powered Mixer...
I need the diagram of behringer europower pmh1000
Here:
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers on the page.
Jul 12, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Jai un probleme sur mon appareil beringher pmp 5000 je connais plus les references des transistor sur le tableau d alimentation cest des transistor noire merci
I don not know French.. I will get my wife to translate. I have schematic and can interpret transistor numbers. Schematic:
Scroll down to "get manual" and click to download. IGNORE other download links.
Jul 02, 2011 | Behringer Europower Pmp5000 Powered Mixer...
No amp output.amplifier damage
You will have to have it repaired. Also read my tip regarduing the PMP mixer/amps that if you use 1/4 inch cable plugs to speakers, the SLEEVE of channel A is hot, not the tip. It the sleeve shportss to somehing that is ground, goodbye Channel A or more. This is not in the book.
Feb 19, 2011 | Behringer Europower Pmp1000 Powered Mixer...
How do I turn on my europower pmp 2000
The power button (push) is in the back, just next to where you plug power cord.
Aug 06, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer Europower Pmp5000 Powered Mixer Pmp5000 Logo
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
