Question about Sony NWZB135F MP3 Player
How can I repair it?
Battery is always down
    Top Expert:
  • Sony Master
  • 10,875 Answers
Buy a new one or drain battery totally and recharge with a good charger
Posted on Jul 05, 2015
2 Suggested Answers
  • 35 Answers
SOURCE: My Sony MP3 player's volume button will not
yaa it can be repaired
Posted on Jun 21, 2011
Why is my nikon coolpix L20 battery exhausted even with new batteries
If you are using rechargeable batteries, It could be that your camera's battery charger circuit is defective. If your camera is out of warranty, the cheap solution would be to buy an external charger. Another possibility is that a short circuit or defective electronic component is drawing excessive current and draining your batteries. If that is the case, you will need to have your camera repaired. Nikon USA Repair Depot's number is 1-800-645-6687 9AM-8PM EST, Monday to Friday. They will tell you how to return your camera for repair and they will give you a free estimate if it is out of warranty.
Sep 01, 2014 | Nikon COOLPIX L20 Digital Camera
Can battery compartment be repaired when tabs are broken off which hold lid down?
possibly...if it is the body where the tabs are broken off the manufacturer (Olympus) might be able to replace the body shell. I'd check with them.
Aug 16, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
How to remove a battery
Check your Owner's Manual for any special proceedures regarding antitheft features that need to be addressed before disconnecting the battery. Always make sure the keys are OUT OF THE CAR before you start. Anything obstructing your access to the battery must be removed. Always remove the negative terminal of the battery FIRST. There will be a "hold down" feature that securely holds the battery in place- either a strap or bar across the top of the battery, or a claw type clamp that kinda bites into side of the battery at the bottom. You have to remove "hold down". Old battery out, new battery in. Alway attach the negative terminal to the battery after the positive terminal. (Negative cable- off first, on last)
Mar 16, 2014 | 2002 Oldsmobile Bravada
No power going through the laptop
Hi Paul,
Are you using the recommended power supply adapter?
If not, then that is most likely the culprit.
Many people lose the proper adapters and try using a generic one, and that's a big NO, NO!!!.
If this is not the issue, then I would suggest you take the unit to your nearest PC repair shop for them to check it out, the check up itself is cheap, but if you need repairs/replacements, then it isn't so cheap, but reasonably priced.
I hope This answers your query.
Regards,
Peter
Mar 01, 2013 | Acer Extensa 5210 5220 5620G 5620Z...
Location of battery
You can find it in the front behind the green pull down door and front grill.
If you need additonal help you can contact the repair guys at
http://www.mypegperegoparts.com
I get all my parts from them and they always seem to help me out.
hope this helps
May 29, 2010 | Peg Perego John Deere Gator HPX Ride on...
Battery won't hold a charge - go-go elite travellor scooter battery charged overnight but won't hold charge.
We have had problems with scooter batteries from time to time and the repair man said to take apart the battery case and disconnect the batteries and use a car charger. I put the two battery in parallel and used a amp battery charger. This worked fine.
Don't run your scooter batteries all the way down when using the Go Go as the scooter charger won't always bring them up to full charge and you may have repeat this. Also running the batteries all the way down shortens there life.
Mar 19, 2010 | Pride Mobility Products Go-Go Elite...
Will not power on. new batteries installed.
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 01, 2009 | Canon PowerShot A95 Digital Camera
Fujifilm e900 shuts down when shutter is pressed
Hello
Thank you for using
Always check the batteries first but if is it still giving the same fault, your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Fujitsu Cameras
Need a schematic for a belkin F6C120-unv. All functions of the unit work fine other than the charging circuit won't keep the batteries charged. Runs about 24.7 volts, but keeps getting lower as the...
When batteries discharge during ac power it could indicate charger failure or micro failure or some other wierdness. makers do not release cd info. The best thing is.. buy another one as they can be very difficult to repair and of course they are dangerous, batteries are always live, waiting to bite you. I have worked on and repaired such circuits as the AP 200 series resonant converter and selling and hiring UPS for a long time. Beyond the simple easy checks youhave done the time it takes to understand how they work can better be used.
Sep 22, 2009 | Belkin Enterprise (F6C1200-UNV)...
Macbook Won't Always Shut Down!
Click on the hard drive icon, then on Applications, then Disk Utilities. Select the hard drive, the click on repair. This will repair any issues with Mac OS.
If it does not, it may be a hardware problem. I just received mine from Apple repair. Mine would not come out of sleep.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 12, 2009 | Apple 13.3 MacBook Intel Core 2 Duo...
Sony NWZB135F  MP3 Player Logo
93 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
