Question about Sewing Machines
Nelco sewing machine
I have a nelco sewing model r-300 having problems with the bobbin when i try to tread it won't make a loop please help me my name is penny.
When was your machine serviced last if it was a year or more spend the money it will extend the life of your sewing machine
Mary
Posted on Apr 12, 2014
I need help putting the bobbin threader back onto a Nelco JA38 sewing machine and the springs are giving me fits. Any help?
Not sure if you are having problems with the bobbin winder or threading the bobbin. This may help:
Nelco JA 38 Sewing Machine Threading Diagram
To avoid awful thread nests under the fabric, be sure to ALWAYS RAISE the presser foot when threading the top thread.
Interestingly, the bobbin threading instructions (above) show the bobbin loading into the bobbin case so it turns COUNTER-clockwise. This is the opposite of instructions for most machines. You can probably try both, the clockwise or Counter-clockwise,and see if one works better than the other.
Be sure to use fresh, good quality sewing machine oil or Tri-Flow Synthetic Oil on your machine. Open it up, while gently wiggling the handwheel, drop a couple drops of oil every place that metal rubs against metal. Avoid plastic or rubber parts! You may even find little round holes throughout that are oil ports. Be sure to get the area around the needlebar, presser foot lifter, feed dogs, the bobbin area, and all the dial and selector mechanisms.
You can find manuals for your machine online (not free!).
Nelco Sewing Machine Manuals Instruction and Repair Manuals
Aug 07, 2017 | Sewing Machines
Releasing clutch that is stuck on Nelco sewing machine. Love this machine have had it for 47 years
Has the machine been regularly cleaned and oiled? Most times, older mechanical machines seize due to old oil turning to glue/varnish and preventing the parts from moving.
Perhaps a bit of Tri-Flow and heat will loosen it. If you are trying to wind bobbins, you can also purchase a stand-alone bobbin winder (one brand is called Sidewinder) for ~$30. It is helpful for many sewists because bobbins can be wound without unthreading the machine and it saves wear and tear on the machine. (Love my Nelco J-28!)
Wheel on right side that controls the needle up and down is very tight...
Jul 09, 2017 | Sewing Machines
I need the manual for a Nelco F600. Do you have it or know where I can get one. I was given a machine but think it has been in storage for a long time! Need to oil and check it out.
A manual for a similar model would be a benefit. Most machines operate and thread the same. Yes, you should definitely clean and lube your machine before trying any sewing. Tri-Flow Synthetic Lube from the hardware store is a good product to use because it does not dry out and turn to glue over time.
Nelco sewing machine manual free
FWIW, I inherited a Nelco J28 and it is the toughest machine in my arsenal. I repair horse equipment with it. The stitch quality is not the best, but it certainly sews most anything thrown at it. The only issue I have with it (and it is my issue, not the machine's) is that it has a side-loading bobbin which means the home position of the needle is also on the left instead of the middle. Having always used a centered needle makes using it seem somewhat unnatural. However, your machine appears to have the front-loading bobbin and centered needle.
May 16, 2017 | Sewing Machines
Hello I have a nelco sewing machine but I have no clue how to sew with it I am a mixed media artist and now I want to incorporate sewing in my art please help me thank you
Before we can help, we need to know the model.
Perhaps this will be helpful:
FWIW, I have an old Nelco J-28 that was passed on to me by someone who started quilting with it and advanced on to a career making wonderful creatively designed scenic quilts. It is a basic machine with straight stitch and a few zig-zag stitches. It's a tough metal mechanical machine and has been used to repair horse equipment (fly masks, etc.) and upholstery. The only thing that is perplexing to me is that it is a left needle position machine, ie the bobbin loads on the left side, the needle faces the left side, and the needle home position is on the left side and swings from the left to the right. All my other machines are center needle position so it takes some adjustment whenever switching to the Nelco--but that is a personal thing and in no way reflects on the machine and its usability. The good thing--since it is a mechanical machine, it can be maintained with frequent oiling using fresh good quality sewing machine oil and regular cleaning.
The best advice ever provided--Always Raise the presser foot when threading the upper thread and make sure the machine is threaded correctly.
Jan 03, 2017 | Sewing Machines
Bobbin not turn
the hook should rotate to hook the loop and complete the stitch around the bobbin thread.
Feb 26, 2014 | Sewing Machines
The tread is "looping" on
Loops on the top of the fabric are signs of the bobbin thread being too loose. Linda at Relics
Jun 18, 2011 | Kenmore Sewing Machines
My mother"ssewing machine willnot pick
I saw Nelco on this website http://www.sewusa.com/Sewing_Machine_Manuals/Nelco_Sewing_Machines.htm
purchasing /obtaining a manual is always very helpful when working with a sewing machine.
However, simple stuff to check, is the needle in the right way, with the scarf (groove) to the back?
Is the needle new and the right type of needle for this machine? Sorry, I don't know a lot about Nelco however, most machines use 130/705H system needles, but there is always the exception, especially with something 40+ years old so it pays to check it out.
And lastly timing, the needle needs to be down at the lowest point as the rotary hook comes around to catch the thread. If this isn't happening, then it could be that the timing is out on the machine. It's never happened to me but it can happen. But I'd suggest you try changing needle, check threading path and bobbin firstly.
Good luck.
Apr 10, 2011 | Sewing Machines
BOBBIN TREAD LOOPING UNDERNEATH
looping thread on the bobbin side means that the upper tension is too loose... make sure it's threaded correctly.
Jun 14, 2009 | Feiyue FS288
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
157 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
