Question about GE Refrigerators
GE gss22wgpa side by side not cooling enough
Problem intermittent
  • 8 Answers
SOURCE: Not cooling properly
The defrost heater could be bad and the coils are freezing. The defrost sw could be bad.
Posted on Mar 13, 2009
  • 3 Answers
SOURCE: ge side by side not cool enough even on higher
I posted this on another problem, but this may help you too.
Check to see if there is frost on the back panel of the freezer.
If there is try solution below:
I had a similar problem. The frost in the back is an indication that your coils are frozen. This could be from food packages falling out of the freezer drawers in the back and blocking the air circulation vents or maybe the freezer door was not closed completely and letting moist/humid air in and freezing the coils.
For me it was the first problem listed.I had to completely empty the freezer and Frig. and take the back panel off in the freezer. There you will see the coils and lots of ice!
1. Remove all items from the frig. and freezer and unplug frig.
2. Pull all the freezer drawers out.
3. On my GE side by side I took the light cover off and removed the bulb. There you will see two panel screws. Remove the screws.
4. Now pull out the mouldings on each side and you should be able to remove the panel.
5. Take a hair drier and completely defrost all the ice from the coils.
Be sure to keep plenty of towels handy for all the water mess. Remember to keep an eye on the drain tray in the back of the frig. and use a sponge to collect the water that will build up.
Hope this helps!.....
Woody
Posted on Mar 29, 2009
  • 531 Answers
SOURCE: GE side by side fridge not cooling enough Freezer side was still
check see if you have frost build up in the freezer back wall you may have defrost problem
Posted on Apr 06, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: have side by side ge, not cooling correctly, only
Hello
Have a look under and behind the refrig,see if there is dust and dirt on the condensor and condensor fan.
If so, lightly take a vacum and sweep it off.Also claen any dust off the front grill located at the bottom.
If this doesnt help you may have a bad defrost timer or your low on freon,which would require a service call.
Thanks
Posted on Apr 14, 2010
  • 472 Answers
SOURCE: ge gss25kgtbb the setting is
this unit has had some issues... a few things to look for first...is there any frost in freezer compartment on back wall?/ should not be if there is you have a defrost problem...next make sure the fan inside the freezer is running you may have to open door and hold door switch with hand while listening... if all that is good make sure compressor is running when you notice it is warming up your not hearing any clicking on and off are you? if so this is a relay problem with compressor ... if all that is good the major problem they are having is with the control boards on these things going bad they have updated them already 2 or three times ..hope this helps you out repost with anymore questions one of us will help you out...
Posted on Jan 05, 2011
GE side by side refrigerator not cooling at all even after replacing the main board
In many cases changing the board alone will not solve the problem if the start relay, overload and the run capacitor have not been replaced, WR09X10107 Relay and Overload Kit and WR62X79 Run Capacitor You can locate a service manual HERE and test points and wiring diagram HERE I am here to answer any questions you may have, Thanks Sea Breeze
May 20, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi my GE side by side fridge is not getting cold enough
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side Model GSS22WGPA CC Ice has quite freezing and frost is building up on the back of the freezer. Only 7 yrs old. I have been told it is probably the defrost heaters and it has shorted out...
if they will replace it do it . i do belive that the main board wil have to be replaced . but i not sure that the heater caused it .. that is guess work at this time , .. mm hope this helped . ps did some one ck the heater .. in any case g e will fix it and if it keeps doing it make them repl .. hope this helps mm feed back pls ..
Oct 21, 2010 | GE Refrigerators
The frezer not cool enoug
you may not have enough air circulation at the rear of the machine when you moved it. if the machine can not loose heat through the radiator at the back it looses its cooling capacity. move it back to where it was?
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge hotpoint side by side refrigerator is not get cold enough
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Gshs5kgx refrigerator not cold enough, controls
Did you solve this problem? We're having the same problem on our GE same model, but no turbo cool option.
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 06, 2009 | GE Refrigerators
Let it defrost for awhile. Hook it back up, After on for a bit, check the fan under the fridge to see if it works. Also is there any air blowing inside the fridge and freezer. If not then the cooling fan has gone bad. Thats easy to replace. If none of the above then eather the compressor is going out but doubtful being there is ice on the back. But the freon could be low.
Jan 31, 2009 | GE Refrigerators
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE not working
Change the defrost heater, It's located at the bottom of the frosted coils and should have a pink and blue wire running to it.
Jun 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
