Astra will not start
I did the complete engine on my 1.6 8 valve fuel injected Opel Astra, trying to start vehicle, just swings but will not start. Engine management light stays on while swinging. What could be the problem?
    New Friend:
    Problem Solver:
  • 9 Answers
Same kind of thing happened to me and it turns out it was the ECU, otherwise known as the engine control unit. I went to the wreckers and got a new one. :)
Posted on Apr 24, 2014
  • 9 Answers
SOURCE: Umax astra 2500 Driver for Vista OS
try this
http://www.umax.com/download/index.jsp
download the driver from this site
Posted on Oct 08, 2008
rizla
  • 1463 Answers
SOURCE: I WANT TO FREE DOWNLOAD ASTRA 5600 SCANNER
hi kash
go to here scroll down the page for the drivers
UMAX Scanner Astra 5600/5650 Driver Windows 98SE/ME/2000/XP
riz.
Posted on Dec 11, 2008
SOURCE: Drivers for umax astra 4100 on linux
throw the linux system or your scanner. as they not compatible
Posted on Feb 14, 2009
SOURCE: scanner umax astra 4100 driver
how can i get my UMAX Astra 4100 driver
Posted on May 01, 2009
SOURCE: Driver For Umax Astra 5650
i need driver for astra 5600/5650 scanner
Posted on Oct 29, 2009
Opel astra 1.8 16v is a fuel injection?
all opel/vauxhall i.8 16 valve engines have fuel injection systems and should be multipiont or single. if its multipoint you should be able to see the separate injectors on the inlet manifold if its the economy version it will look like its got a carburetter but its a single point system not knowing the model/year it is not easy for me to help
Jan 18, 2018 | Opel Cars & Trucks
How can I get a wiring diagram for a opel astra 1999 2l fuel injection?
Have you tried Google? If not then suggest you invest in a workshop manual. Most of the Astra fuel injection system is solid state so unless you can actually see a break in the wiring the likelihood is that the problem will need a fault code reader to pinpoint.
Jul 23, 2016 | Opel Cars & Trucks
Opel Astra 2001 1.2 ecotec - Hard to start and engine with hick-ups on idle
Guessing just wastes money . have the fault codes read first and find exactly which sensor/s are causing you a problem
not all faults energize the engine light and remember the engine light also refers to problems in the transmission
May 10, 2015 | 2001 Opel Astra
OPEL ASTRA 1.4 CARBURETOR 1986 MODEL IT WONT
Did you check for ignition spark and presence of fuel in carburetor?
Aug 10, 2013 | 1999 Honda CR-V Distributor for L4 2.0L
Opel astra twinport 1.6 2006 Z16XE TURNS OVER BUT WONT START
Hi, Have a diagnostic scan done and also a mechanical error trace ,
the solution to the problem could be the CKP crankshaft position sensor or a wiring related issue, it could also be the fuel pump , the pump relay , engine management actuator . In order for your engine to start it requires the following:
Compression
Fuel pressure and volume
A proper spark
Correct valve timing and ignition timing
A decent battery vitally important as all engine management relies on it.
Hope this helps a bit
Regards Higgins.
Sep 14, 2012 | 2006 Opel Astra 1.6
Opel Astra 1600 16v jerking at low rpms when car
i got opel astra 160i 95 model. it jerks when the engine is hot/warm when excellerating.
Jun 09, 2009 | 1999 Chevrolet K1500
117 people viewed this question
k24674
jasbo
jasbo
