Question about P3 Direct P3 P4750 Light Owl - LED Direct p3p4750 p3-p4750
P4750 keeps going on and off without activation
Set to stay on for 20 sec. but goes on and off all night without being activated.
Cooper ms34w wont turn off stays on night an day without movment
Have you had a look at the underside of the motion detector the should be some things for you to a just it with
Mar 25, 2014 | Cooper Lighting Flood Lights. 180 Degree...
Tip
Samsung SGH-500 codes
#*6837# = Official Software version
*#9999# = Software version
*#8888# = HW version
*#8377466# = Same HW/SW version thing
*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#4777*8665# = GPSR Tool
*#8999*523# = LCD Brightness
*#8999*3825523# = External Display
*#8999*377# = Errors
#*5737425# = JAVA Something{I choose 2 and it chrashed}
*#2255# = Call List
#*536961# = Java Status Code
#*536962# = Java Status Code
#*536963# = Java Status Code
#*53696# = Java Status Code
#*1200# = AFC DAC Val
#*1300# = IMEI
#*1400# = IMSI
#*2562# = ??? White for 15 secs than restarts.
#*2565# = Check Blocking
#*3353# = Check Code
#*3837# = ??? White for 15 secs than restarts.
#*3849# = ??? White for 15 secs than restarts.
#*3851# = ??? White for 15 secs than restarts.
#*3876# = ??? White for 15 secs than restarts.
#*7222# = Operation Typ (Class C GSM)
#*7224# = I Got !! ERROR !!
#*7252# = Oparation Typ (Class B GPRS)
#*7271# = Multi Slot (Class GPRS)
#*7274# = Multi Slot (Class 4 GPRS)
#*7276# = Dunno
#*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
#*2787# = CRTP ON/OFF
#*3737# = L1 Dbg data
#*5133# = L1 Dbg data
#*7288# = GPRS Attached
#*7287# = GPRS Detached
#*7666# = SrCell Data
#*7693# = sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
#*7284# = Class : B,C or GPRS
#*2256# = Calibration Info
#*2286# = Battery Data
#*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
#*2679# = Copycat feature (Activate or Deactivate)
#*3940# = External loop test 9600 bps
#*4263# = Handsfree mode (Activate or Deactivate)
#*4700# = Half Rate (Activate or Deactivate)
#*7352# = BVMC Reg value
#*8462# = Sleeptime
#*2558# = Time ON
#*3370# = EFR (Activate or Deactivate)
#*3941# = External looptest 115200 bps
#*5176# = L1 Sleep
#*7462# = SIM phase
#*7983# = Voltage/Frequenci (Activate or Deactivate)
#*7986# = Voltage (Activate or Deactivate)
#*8466# = Old time
#*2255# = Call ???
#*5187# = L1C2G trace (Activate or Deactivate)
#*5376# = ??? White for 15 secs than restarts.
#*6837# = Official Software Version
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*7638# = RLC allways open ended TBF (Activate or Deactivate)
#*7632# = Sleep mode Debug
#*7673# = Sleep mode RESET
#*2337# = Permanent Registration Beep
#*2474# = ???
#*2834# = Audio Path
#*3270# = DCS support (Activate or Deactivate)
#*3282# = Data (Activate or Deactivate)
#*3476# = EGSM (Activate or Deactivate)
#*3676# = Flash volume formated
#*4760# = GSM (Activate or Deactivate)
#*4864# = Dunno doesn't work on newer versions
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*7326# = Accessory (I got ********)
#*7683# = Sleep variable (
#*7762# = SMS Brearer CS (Activate or Deactivate)
#*8465# = Time in L1
#*9795# = wtls key
#*2252# = Current CAL
#*2836# = AVDDSS Management (Activate or Deactivate)
#*3877# = Dump of SPY trace
#*7728# = RSAV done# (Everything went to standart but nothing was deleted)
#*2677# = ARM State (None or Full Rate)
*#8999*636# = Have no clue what it is, i see 20 lines
*#8999*8376263# = HW ver, SW ver and Build Date
*#7465625# = Check the locks
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
*2767*927# = E2P Wap Reset
*2767*226372# = E2P Camera Reset
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
#*6428# = MIC Measurement
#*3230# = Trace enable and DCD disable
#*3231# = Trace disable and DCD enable
#*3232# = Current Mode
#7263867# = RAM Dump (On or Off)
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
*335# = Delete all MMS Messages
*663867# = Dump Mm file
#*536961# = WAPSAR enable / HTTP disable
#*536962# = WAPSAR disable / HTTP enable
#*536963# = Serial eable / Others disable
#*53696# = Java Download Mode
#*5663351# = Wap Model ID [Your Model]
#*5663352# = Wap Model ID [SEC-SGHXXXX/1.0]
#*566335# = Wap Model ID [SEC-SGHXXXX/1.0]
*2767*66335# = Check on which model it is
*2767*7100# = SEC-SGHS100/1.0
*2767*8200# = SEC-SGHV200/1.0
*2767*7300# = SEC-SGHS300/1.0
*2767*7650# = Nokia7650/1.0
*2767*2877368# = Reset WAP Model ID to standard
on Mar 06, 2010 | Cell Phones
I NEED A NETWORK CODE TO UNLOCK MY D500 PHONE
Here are all known special codes for Samsung phones!
#*5737425# = JAVA Something{I choose 2 and it chrashed}][/b]
*#2255# = Call List
#*1300# = IMEI
#*1400# = IMSI
#*2565# = ChAeck Blocking
#*7271# = Multi Slot (Class 1 GPRS)
#*7276# = Dunno
#*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
#*8462# = Sleeptime
#*2558# = Time ON
#*5176# = L1 Sleep
#*7462# = SIM phase
#*8466# = Old time
#*2255# = Call ???
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*2474# = ???
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*7683# = Sleep variable (8)
#*9795# = wtls key
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
*2767*2877368# = Reset WAP Model ID to standart
~KenjiFox
Jan 07, 2011 | Samsung SGH-D500 Cellular Phone
The Time display only stays on for 15min - how do you set it to keep on permanently?
First, keep in mind that the unit shuts down to preserve battery life. Simply remove any batteries to be sure the unit won't accidentally run on them and activate the 10 minute auto-shutdown. Keep the AC adapter plugged in at all times for a continuous projection. If you don't have the AC adapter then I'm afraid you're out of luck. Perhaps check eBay for one, but you will need that cable plugged in if you want the projector to stay on all night.
Jul 17, 2010 | Uncle Milton Night Sky Projector Clock
How can the standby mode on the Nokia 2730 be fixed.
first decide that in your phone activated your screen saver if yes then customize your display setting. if not then active your screen saver which is watch.if you not get any solution then format your phone. these code are under the following.
*#7780# then want security code. please give your security code. then your phone will be restore factory settings.
Jul 03, 2010 | Nokia 2730 Cell Phone
How to unclock my samsung cell phone
ALL SAMSUNG UNLOCK CODE.... ---------------------------
*2767*688# = Unlocking Code *#8999*8378# = All in one Code *#4777*8665# = GPSR Tool *#8999*523# = LCD Brightness *#8999*3825523# = External Display *#8999*377# = Errors #*5737425# = JAVA Something{I choose 2 and it chrashed}]/b *#2255# = Call List
#*536961# = Java Status Code #*536962# = Java Status Code #*536963# = Java Status Code #*53696# = Java Status Code
#*1200# = AFC DAC Val #*1300# = IMEI #*1400# = IMSI
#*2562# = ??? White for 15 secs than restarts. #*2565# = ChAeck Blocking #*3353# = Check Code #*3837# = ??? White for 15 secs than restarts. #*3849# = ??? White for 15 secs than restarts. #*3851# = ??? White for 15 secs than restarts. #*3876# = ??? White for 15 secs than restarts.
#*7222# = Operation Typ (Class C GSM) #*7224# = I Got !! ERROR !! #*7252# = Oparation Typ (Class B GPRS) #*7271# = Multi Slot (Class 1 GPRS) #*7274# = Multi Slot (Class 4 GPRS) #*7276# = Dunno #*7337# = EEPROM Reset (Unlock and Resets Wap Settings) #*2787# = CRTP ON/OFF #*3737# = L1 Dbg data #*5133# = L1 Dbg data #*7288# = GPRS Attached #*7287# = GPRS Detached #*7666# = SrCell Data #*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while) #*7284# = Class : B,C or GPRS #*2256# = Calibration Info #*2286# = Battery Data #*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10) #*2679# = Copycat feature (Activate or Deactivate) #*3940# = External loop test 9600 bps #*4263# = Handsfree mode (Activate or Deactivate) #*4700# = Half Rate (Activate or Deactivate) #*7352# = BVMC Reg value #*8462# = Sleeptime #*2558# = Time ON #*3370# = EFR (Activate or Deactivate) #*3941# = External looptest 115200 bps #*5176# = L1 Sleep #*7462# = SIM phase #*7983# = Voltage/Frequenci (Activate or Deactivate) #*7986# = Voltage (Activate or Deactivate) #*8466# = Old time #*2255# = Call ??? #*5187# = L1C2G trace (Activate or Deactivate) #*5376# = ??? White for 15 secs than restarts. #*6837# = Official Software Version #*7524# = KCGPRS #*7562# = LOCI GPRS #*7638# = RLC allways open ended TBF (Activate or Deactivate) #*7632# = Sleep mode Debug #*7673# = Sleep mode RESET #*2337# = Permanent Registration Beep #*2474# = ??? #*2834# = Audio Path #*3270# = DCS support (Activate or Deactivate) #*3282# = Data (Activate or Deactivate) #*3476# = EGSM (Activate or Deactivate) #*3676# = Flash volume formated #*4760# = GSM (Activate or Deactivate) #*4864# = Dunno doesn't work on newer versions #*5171# = L1P1 #*5172# = L1P2 #*5173# = L1P3 #*7326# = Accessory (I got ********) #*7683# = Sleep variable (8) #*7762# = SMS Brearer CS (Activate or Deactivate) #*8465# = Time in L1 #*9795# = wtls key #*2252# = Current CAL #*2836# = AVDDSS Management (Activate or Deactivate) #*3877# = Dump of SPY trace #*7728# = RSAV done# (Everything went to standart but nothing was deleted) #*2677# = ARM State (None or Full Rate) *#8999*636# = Have no clue what it is, i see 20 lines *#9999# = Software version *#8999*8376263# = HW ver, SW ver and Build Date *#8888# = HW version *#8377466# = Same HW/SW version thing ------------------------------------------------------- WORKS *#7465625# = Check the locks *7465625*638*Code# = Enables Network lock #7465625*638*Code# = Disables Network lock *7465625*782*Code# = Enables Subset lock #7465625*782*Code# = Disables Subset lock *7465625*77*Code# = Enables SP lock #7465625*77*Code# = Disables SP lock *7465625*27*Code# = Enables CP lock #7465625*27*Code# = Disables CP lock *7465625*746*Code# = Enables SIM lock #7465625*746*Code# = Disables SIM lock *7465625*228# = Activa lock ON #7465625*228# = Activa lock OFF *7465625*28638# = Auto Network lock ON #7465625*28638# = Auto Network lock OFF *7465625*28782# = Auto subset lock ON #7465625*28782# = Auto subset lock OFF *7465625*2877# = Auto SP lock ON #7465625*2877# = Auto SP lock OFF *7465625*2827# = Auto CP lock ON #7465625*2827# = Auto CP lock OFF *7465625*28746# = Auto SIM lock ON #7465625*28746# = Auto SIM lock OFF ----------------------------------------------------- WORKS*2767*3855# = E2P Full Reset WORKS*2767*2878# =SOFTWARE VERSIONS *2767*927# = E2P Wap Reset *2767*226372# = E2P Camera Reset #*6420# = MIC Off #*6421# = MIC On #*6422# = MIC Data #*6428# = MIC Measurement #*3230# = Trace enable and DCD disable #*3231# = Trace disable and DCD enable #*3232# = Current Mode
#7263867# = RAM Dump (On or Off) *2767*49927# = Germany WAP Settings *2767*44927# = UK WAP Settings *2767*31927# = Netherlands WAP Settings *2767*420927# = Czech WAP Settings *2767*43927# = Austria WAP Settings *2767*39927# = Italy WAP Settings *2767*33927# = France WAP Settings *2767*351927# = Portugal WAP Settings *2767*34927# = Spain WAP Settings *2767*46927# = Sweden WAP Settings *2767*380927# = Ukraine WAP Settings *2767*7927# = Russia WAP Settings *2767*30927# = GREECE WAP Settings *2767*73738927# = WAP Settings Reset *2767*49667# = Germany MMS Settings *2767*44667# = UK MMS Settings *2767*31667# = Netherlands MMS Settings *2767*420667# = Czech MMS Settings *2767*43667# = Austria MMS Settings *2767*39667# = Italy MMS Settings *2767*33667# = France MMS Settings *2767*351667# = Portugal MMS Settings *2767*34667# = Spain MMS Settings *2767*46667# = Sweden MMS Settings *2767*380667# = Ukraine MMS Settings *2767*7667#. = Russia MMS Settings *2767*30667# = GREECE MMS Settings
*335# = Delete all MMS Messages *663867# = Dump Mm file #*536961# = WAPSAR enable / HTTP disable #*536962# = WAPSAR disable / HTTP enable #*536963# = Serial eable / Others disable #*53696# = Java Download Mode #*5663351# = Wap Model ID [Your Model] #*5663352# = Wap Model ID [SEC-SGHXXXX/1.0] #*566335# = Wap Model ID [SEC-SGHXXXX/1.0] *2767*66335# = Check on which model it is *2767*7100# = SEC-SGHS100/1.0 *2767*8200# = SEC-SGHV200/1.0 *2767*7300# = SEC-SGHS300/1.0 *2767*7650# = Nokia7650/1.0 *2767*2877368# = Reset WAP Model ID to standart
Jun 15, 2010 | Samsung SGH-A877 Impression Cell Phone
My VGA signal is active but I have no DVI signal.
You must just have one port to be active.
Let's say you want to use the VGA then it should only be the one plugged-in and vice versa
you can't have both ports to be connected at the same time.
Feb 28, 2010 | HP Computers & Internet
Samsung t239 wrong card message
samsung all code press unlock
here are the codes that i have hope they help
D807
Guys!!! :-) Unlock D807 - Its so easy!!!
Turn off the phone. Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit.
Choose menu #7. After phone reboots type *0141# and hit the Call button. Turn off and insert another SIM Card. Turn on.
The code is 00000000.
e900
Free solution (SIM)unlock E900
Here follows the free solution to (SIM)unlock a Samsung E900, which worked for me.
- NSdongle crack + D800 USB datacable (PCB120BBE)
- Select C200 model
- Select right COM port (Windows XP -> Devicemanager -> Ports (COM&LPT))
(Not the COM port which you can find under 'Modems')
- Press 'UNLOCK'
And your Samsung E900 is unlock! (Well, mine was)
(Thanks!! to BouRRi GSM, who wrote it somewhere on this forum)
Got
new sam unlock
*7465625*638*00000000*00000000#
NEXT ENTER
#7465625*638*00000000#
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock – inactive
panamastercodes
*01763*737381#
sam1
Power on your phone (Models Z105, Z107V, Z140, Z140V, Z500, Z500V, etc.......)
1- Enter code *7465625*28782# without a sim in the phone
2- Phone will display "Auto Subset Lock: Activated!"
3- Enter code *7465625*28638# without a sim again
3- Phone will display "Auto Network Lock: Activated!"
4- Now insert the sim and enjoy! Phone is Unlocked!
(NOTE: When you change sim to other operator
repeat this process to unlock it for that operator also)
sammaster
*2767*2878# without simcard
Samsung
*#2255# = Call List
#*1300# = IMEI
#*1400# = IMSI
#*7276# = Dunno
#*8462# = Sleeptime
#*2558# = Time ON
#*5176# = L1 Sleep
#*7462# = SIM phase
#*8466# = Old time
#*2255# = Call ???
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*2474# = ???
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*9795# = wtls key
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
*2767*2877368# = Reset WAP Model ID to standart __________________
Jan 08, 2010 | Samsung SGH-t239 Cell Phone
Garage light turns on without disturbance.
Most likely the unit has a sensor that activates the light when you walk around or open the door.
if no one is in the room it should go off in 5 minutes, but if someone goes back in there to check it goes back on again.
Under the light cover there should be a switch where you can disable it or make it less sensitive.
Sep 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Menu,sound problems
First thing is try to take out the batteries out of the remote control Then if the problem persist, unplug the set for a couple of hours if not over night. If that dosent work then check to see if any of the front panel buttons may be stuk .. If all of this was checked its time to call in a repairman as you have a microprocessor circuit or EEPROM fault or the five volts going to the reset is too low. Good Luck
Jul 26, 2006 | Philips 27PT6441 27" TV
P3 Direct P3 P4750 Light Owl - LED Direct p3p4750 p3-p4750 Logo
71 people viewed this question
Top P3 Direct Home Experts
Donni Steen
Tom Chichester
Are you a P3 Direct Home Expert? Answer questions, earn points and help others
