Question about Pride Health & Beauty
Pride Legend XL flashing led issue when first turned on
The scooter is about 4-5 years old (bought used). It has the dual speed option (rabbit-turtle). Lately it is exhibiting a weird symptom when sitting for a while and the key is first turned on..continuous flash..nothing to decode a flash count.Scooter will not reverse. Turn key on off a couple of times and press FWD lever, I hear a relay click and the scooter will move forward and then backwards. Battery chargef indicator is pegged to the right, New batteries installed last year and maintained over the winter. Any ideas?
  • 1 more comment
  • SuperCarver2011
    SuperCarver2011 Apr 12, 2014
    Ok, I FOUND MY PROBLEM. The reason it would not move
  • SuperCarver2011
    was because the speed pot was DIRTY. The speed pot must be at minumum so that the scooter does not jump ahead once the fwd or rev paddle is depressed. It is a safety feature on these scooters and if the speed control is not reduced, there is continuous flashing indicator. In my case the speed pot was dirty inside and not going down to minimum so the motor relay was prevented from being engaged (click). Prying the Knob off the speed control and spraying down the shaft with electronic contact cleaner, then rotating the control back and forth a few times, SOLVED the problem. With the speed pot at miinimum and key on, the status LED is steady and scooter will move in forward or reverse.
  • SuperCarver2011
    SuperCarver2011 Apr 14, 2014
    Problem solved. Read my comments above.
  • 32 Answers
SOURCE: no movement, forward or reverse
sounds like it is in neutral, look for a lever on the bottom, rear of the scooter to pull up
Posted on May 07, 2009
gewiz
  • 1263 Answers
SOURCE: I have a Pride Legnd..the scooter started loseing
hi, first you need to check the connections to the batteries then to the motor controller, and don't dismiss the speed pot, disconnect the speed pot and try a normal 5K pot inplace of it, if the scooters responds you find the problem just a case of getting the right speed pot. Check the freewheel switch, normally it located on the motor side.
Regards
GeWiz.
Posted on Dec 15, 2009
Testimonial: "Any insight to a problem is a positive step."
  • 177 Answers
SOURCE: The Pride GoGo 4 wheel scooter does not move
Hi. How many beeps between pauses? This is a fault code.
A couple of problems might cause this fault. Is your free-wheel lever in the correct place. These levers operate a switch, that tells the controller that the brake is disabled, this stops the controller from driving the scooter with out brakes.
Might also be caused by a stuck brush in the motor. This is usually caused by the caps that hold the brushes in, not being tight enough. Check the brushes, make sure they slide in and out smoothly, retighten the caps. Be carefull because these caps can crack easily.
Good luck. Neil.
Posted on Jun 12, 2010
  • 46 Answers
SOURCE: Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
Posted on Jul 11, 2010
  • 1015 Answers
SOURCE: I have a 4 wheel Pride Victory 10 scooter that is
This sounds to me like you need a cleaning of all electrical connections that you can get to. I would remove cable from negitive side of the battery first and leave it disconnected until you are finished. Clean both battery cables using a wire brush sand paper or whatever you can to clean. I would also have the battery tested. Some auto parts stores such as auto zone will do this for you for free.
You probably will need to have most of this work done by a service tech, as it sounds like the throttle control is going to need work and the only units like yours that I have worked on were not user friendly.Sorry I'm not more help. Thank you
Posted on Jan 07, 2011
First used sonic mobilty bad rabbit/turtle pot-led-battery meter?
I suggest dealer specific troubleshooting. Who knows what the previous electrical tape wizard soldered or attempted? If you want to keep trying, access a schematic of wiring diagram. Good luck.
Mar 10, 2014 | Pride Sonic 3 Wheel Portable Scooter
Rabbit/turtle value
Pride's website can give you the information you seek. A local mobility service center can give you an estimate.
I have a problem with a Drive Mini Phantom scooter. If you picture the speed control dial as a clock with the slow (turtle) position at 7:00 and the fast (rabbit) position at 5:00, the scooter does not...
It could be battery problems or ECU problems i dont feel the problem stems from the dial or variable switch. if possible try and get a current tester and test how much power the battery's are actually producing. other than those suggestions i dont have any other fixes at present, keep me posted, best regards
Oct 30, 2013 | Drive Medical Mini Phantom Three Wheel...
Today i got a rascal329le mobility scooter and i did not get a manual with it and i dont know what the turtle switch is for, its above the speed knob in top right of 'dashboard' could you tell me...
The turtle switch is the low speed range. This is so you creep along at slower speeds inside buildings etc.
You should be bale to get a manual from Rascal. Call the customer service center at 1-800-257-7955
That should be the right number if not contact any local reseller and they should be able to get your in touch with Rascal.
Sep 01, 2011 | Health & Beauty
Just bought this from an individual who knew nothing about it. Scooter is in excellent condition however it has been sitting for a bit. The problem is the scooter only goes forward when in the High speed...
Jade
This model Drive Phoenix 3 wheel is found for sale at pharmacies and is subject to floor model abuse.
Most common abuse is not recharging batterys and letting them sulfate thus
reducing life of of charge.
I have found that the foward and back-up levers have been bent
by people sitting and squeezing both levers at the same time. the resulting misshaping of the levers results in a very slow speed comand to the controller because of limitted movment of speed control. The result is that main control (turtle/hare) must be advanced to fast (hare) position to get scooter to move.
I have had success straightening levers by carefully bending them in opposite direction on my Phoenix 3W ( which was a clearence item with no warranty.)
The real (legal)solution is ordering a new lever having a technician
replace it so as not to void warranty.
Hope this helps....jth1939
Apr 02, 2011 | Drive Medical Phoenix 3 Wheel Compact...
Stuck in slow (turle) setting.
Hi. This fault could have a few different causes.
Does your hand control have a dial for the turtle to rabbit speed control, or does it have an up button and a down button?. I have had a few dial ( potentiometer ) pots play up, and cause similar problems.
The fault could also be faulty Battery or Motor connector. These terminals develope a bad connection and can get that bad that the plastic housing starts to melt with heat. Also check battery terminals are tight.
Do the batteries last? I have had a few machines with a burnt out motor.These often still drive but only slowly, and the batteries fade quickly.
Good luck. Neil.
Jun 03, 2010 | Invacare Pronto M51 Power Wheelchair
Starting craftsman 6.5 hp 4 in 1 leaf vacuum
Check to see that bag is attached correctly as it has a kill switch.
Oct 11, 2009 | Sears Vacuum Shredder Bagger Replacement...
Health & Beauty Logo
48 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
