SOURCE: Recovering deleted files from olympus VN-4100PC voice recorder
Chances are there to recover such kind of deleted files from your Olympus recorder.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP.
SOURCE: Need to recover deleted file from recorder
Sorry for a late reply but chances are high to recover your deleted files.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Regards
SOURCE: Can you recover deleted files
YES, it is definitely possible to recover such kind of files deleted from your Olympus recorder.
Then connect your recorder to a PC with a recovery program installed. Photo Recovery Software (also recover Voice memos, audio and video files) is right what you need to use if you are running Windows. If you are Mac OS X users, turn to Data Recovery for Mac.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. I hope this will help. Best regards!
SOURCE: recover deleted files from olympus recorder srs
Yes, it's possible to recover files removed from myrecorder device. The
best way is to use a file recovery software, recommended asoftech data
recovery as it helped me before. use link below to download the software
Data Recovery Software for voice recorder
Here's a step by step guide that I find very useful
How to get back files from USB drive
Here's a video tutorial that you may take a look
SOURCE: how to recover deleted files
You can recover deleted files with asoftech data recovery software. get the software from link below
Voice Recorder Data Recovery Software
Please be noted that your voice recorder memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
You may check out this memory card recovery tutorial also
