Question about Refrigerators
Hello, I have a model MTB2455AR in normal household use for about 9-10 years. Recently the cooling performance degraded rapidly. The frozen food started thawing and the main box went up to 50 degrees and the icemaker stopped making any ice blocks. The back of the freezer compartment was building up a layer of frost. We turned it off for a day and opened the lower back and found a lot of dust, lint, and pet hair. We cleaned off the coil and the fan and everything else we could reach easily in the lower rear of the machine. Before closing up the black fiber access panel, we plugged the refrigerator in and verified that the fan near the coil was turning. For two days we felt like geniuses and the machine seemed perfect, but the problems all returned. The kitchen has a typical ambient temperature in the 70's. Worth fixing?
  • tom9616 Jun 25, 2009
    One of the clips holding the defrost heater had rusted and the heater tube had dropped at one end. Water got into the rubber cap on that end of the tube, corroding the electrical connection. Replacement of the heater coil and clips took care of the problem. You led me right to it. Thanks for the quick and detailed response. Tom
  • Refrigerators Master
  • 19,396 Answers
the fact that you found ice on the coils at the back of the fridge means that there is a problem with the defrost system.
The defrost system ensures that coils are not icing up, and it is composed by a fan , the evaporation coil, and a defrost thermostat that start energy to the coil.
If the fan is working, then faulty parts are either the defrost thermostat or the coil.
the evaporation coil can be tested reading ohms with a multimeter, if there is infinite impedance between the two coils contacts, that means that coil must be replaced.
The thermostat is more difficult to test, and returns about 1kohms at ambient temp.
On your fridge there is also an additional 38 degrees defrost thermostat that must be tested.
Here the parts:
Defrost Thermostat
THERMOSTAT (Thermostat Order 542369 Cement)
EVAP Coil/HEAT EXCH. ASSY. 21 & 24'
Here all parts and diarams for your appliance: http://www.partselect.com/MultiModels.aspx?ModelNum=MTB2455AR&SearchTerm=thermostat&RefineSearch=0
Regards.
Posted on Jun 17, 2009
Frig side by side model glrs267zcq1 freezer cool but not frozen no ice
Hello friend, thanks for your post!
I see your Frigidaire refrigerator is not freezing in the freezer section but keeping your fresh food side cool. Some possibilities could be your refrigerator stuck in defrost mode, the control panel, or sealed system. I would recommend performing a reset on your appliance which would be flipping your household circuit breaker off for ten minutes. If that does not resolve your issue I would seek assistance from a professional to properly diagnose and repair your appliance. -Matt
Aug 17, 2014 | Frigidaire Refrigerators
LG French door bottom freezer unit is only 5 years old. Bottom freezer suddenly not keeping food frozen. Ice cubes are melting, ice cream is soft, and there is water on bags of frozen food in top basket...
You have a defrost condensate drain blockage where all the water from defrost remains inside the freezer compartment and causes the symptons you are having. I cannot tell you how to remove every model numbers freezer rear panel but I think that if you study over my link here=> Leaking Refrigerators and this link HERE you will get an idea of what to do. I am here to answer any questions, Sea Breeze
Aug 09, 2013 | Refrigerators
FRIGIDAIRE CHEST FREEZER WILL NOT FREEZE FOOD OR KEEP FROZEN
Hello Cory Mitchell - If your freezer is not cooling, it could have a floating restriction in the lines or something more complicated like an issue with the seal system that only a professional can repair. This can conclude the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. If the compressor was running, humming or even a little warm then that was typically normal. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Feb 13, 2013 | Frigidaire FFFC07M2KW 7.2 Cubic Foot Chest...
What is the suitable temperature for 3 star freezer in uk summer?
3 star freezers are not storage freezers and will maintain frozen food for a short time only, They should reach -18c when closed but may come up in temperature quite rapidly when the door is opened. They are usually found as the cooling evaporator in fridges with freezer boxes in. Four star freezers are dedicated freezer storage space and will keep frozen food at the right temperature for some months.
May 19, 2012 | LEC Freezers
I recently bought a norfrost chest freezer model c6aew,the freezer did not come with a manual or guide.i switched on the freezer set the dial to seven waited 24hrs and put some food into the freezer to...
Can't help I'm afraid, but we have exactly the same problem with exactly the same model. Ours did work for nearly 2 years, but recently only works with the boost button pressed in. I suspect the thermostat is not working as the boost button over-rides the thermostat to give max cooling. Your freezer is new so get it exchanged; it certainly doesn't need to be full to work!
May 29, 2010 | Freezers
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Side by Side Can't find model # Not cooling enough
I cleaned condenser coils with vacum, emptied the defrost tray and vacumed all the dust from the unit, unplugging first of course. Now it is working just fine. Thank you fixya for all your help and postings.
I still can't find the model number anyplace on the unit. This unit is only 2 1/2 year old but no model number to be found on the unit. But
Jul 06, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Doesn't cool fresh food
It´s probably overloaded. Any refrigerator has a specific cooling capacity eg x Kg/24hours. you must check that capacity and charge acording to that.
Jun 30, 2008 | GE Refrigerators
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
