Question about Whirlpool LEQ9858P Electric Dryer
Elements stays on all the time
Element stays on when dial shuts off
    Problem Solver:
  • 6 Answers
Gat a repair men. if the element is on when the fan is not blowing severe overheating can occur
Posted on Apr 13, 2014
Cwsr ele 2406024 cv50
I'm inclined to think that the problem is in the electronics, in the circuit board, since it's acting so oddly. The timer dial shouldn't allow the heating element to energize when the door is open.
If the thermal fuse is blown, you should NOT get heat.
Aug 13, 2014 | Kenmore Dryers
Frigidaire gallery drys heating element stays on when the door is open
L-2 goes directly to the element. You my friend have a shorted heater element which continues to feed whenever the timer is turned on. You need to inspect the element and see if it is touching the pan.
Jun 13, 2012 | Frigidaire GLER331A Electric Dryer
Turning dial for small element - sparks flew out and it blew a breaker - could not shut dial off
This could be the heating element, receptacle or infinite switch. I would first check the element and element receptacle if it checks out good check the switch. Here is a couple links that will walk you thru this.
http://appliancehelponline.com/elementreceptaclevideo.html
http://appliancehelponline.com/infiniteswitchvideo.html
Aug 04, 2010 | Frigidaire FEF352 Electric Kitchen Range
Oven does not heat
This clicking sound.. If it is coming from the control panel area could be indicative of a relay that is malfunctioning.
For giggles try the oven on just broil. See if the upper element comes on and stays on, or if it too shuts down.
If it stays on then you most likely have a bad control board.
If it shuts off like the bake element and does not come back on, I would carefully inspect your power cord and cord connections as well as the range outlet.
Jun 16, 2010 | Kitchen Ranges
Element light staying on
sometimes this is a wireing problem....elements will heat but do they turn orange. if not then the stove may be hooked up like a 110volts..
Nov 04, 2009 | Office Equipment & Supplies
Heating element stays on when turned off
The thermostat (that is the dial that you turn to energize the heating elements) is the only thing that connects power to and disconnects power from the heating element. It is bad.
You can unplug the unit and remove the thermostat. Take it to a parts supplier and get a new one and install it. Your problem will go away.
If you would like to see a wiring diagram...click on this link:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255301.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 15, 2009 | Frigidaire FEF336BC Electric Kitchen Range
The element on top of the stove stays on
Replace the switch for the bad element. It is stuck internally in the ON position.
Jul 30, 2009 | Frigidaire FEF352 Electric Kitchen Range
Top element only stays on high
The trouble would be a failed infinite heat switch. This is the adjustable switch you are using to set the element to low, medium or high.
**Use extreme caution if you are making the repairs yourself.....Turn off circuit breaker and verify power is off with a meter. 240VAC is present at the switch. In addition, the glass top and elements are very fragile.
Apr 28, 2009 | KitchenAid Kitchen Ranges
Whirlpool LEQ9858P Electric Dryer Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
