Question about GE Profile JTP18 Electric Single Oven
GE Washing Machine That the Water Does Not Cut Off!
I have a GE washing machine that the cold water does not shut off when the water level is met and the tub starts to agitates. The hot water will shut off when it is suppose to. I always need to set a timer in the house so I remember to manually turn off the cold water so it will not overflow! Help! Thank you.
  • 82 Answers
Your washer valve is sticking, it should probably be replaced
Posted on Jun 18, 2009
How to clean oven racks
If you mean the straight-in-a-line-parallel-stainless-steel-wire-rod type, we use these methods at home:
General all-round cleaning:
Oven-cleaner spray foam, left to soak to lift grease, then good sponge-down with water-damped cloth / sponge.
Stubborn gunk on racks:
Place racks in empty bath, spray/soak in oven cleaner, or..
pour or squirt engine cleaner / degreaser over entire rack surface, allow to work grease loose, then pour boiling hot water to rinse and dislodge fattiness and carbon.
Ordinary dry washing powder is high in caustic, so also works well.
'Handy-Andy' cream is quite high in ammonia among other unpronounceable chemicals for lifting stuck grease and oils.
Make a stiff, sticky paste of clothes-washing powder and water, then apply to a kitchen 'Zim', ie green scouring pad and mixed with lots of elbow-grease, can restore the racks to former glory.
Rinse well under running water to remove soap.
Otherwise 'bath' the racks in hottest geyser water with washing powder sprinkled on top to soak.
A stiff nylon brush helps to scrub the burnt bits away.
Dec 20, 2017 | Ovens
Door locked
Ok,there may be a lock button next to the others.Look at that.Maybe it is pushed.I have has something similar happen.
Mar 09, 2014 | GE Profile JT965 Electric Double Oven
How can I control the presure of the water drain in the washer mashine
Only way to reduce pressure is to reduce efficiency of pump. i.e. reduce voltage supplying pump winding. Could reduce flow rate by restricting outlet hose diameter but not a good idea as could effect peformance of washing machine and overload pump, belt or brake.
Apr 02, 2011 | Ovens
Ignis adl349/a seems to fill and drain ok but stops after 2/3 mins and beeps 4 times
What this actually signifies is that there is a problem with the spray arms; they are blocked, needs cleaning.
Then, check on the filters as well, its an uncommon problem, but once cleaned, run the machine on a hottest wash, hope it clears the problem.
Check inside for the hose (see if in place or off the top spray bar)to check whether water is going into the spray bars and spray arms work well. ----------
The 5 flashes indicate a spray. Pump fault, either blocked or motor fault.
Press and hold the start button until the light goes out.
Select a program and try the machine again.--------
This should help.keep updated.Thanks.Helpmech,.
Feb 16, 2011 | GE Built-In Dishwashera Oven
He4 tub won't spin. It fills with water and drains out but wont spin
Hello cnt.... If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Dec 03, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The display shows F 7 E 6, the oven buttons do not work but the broiler acts like its coming on but does not message. The maual asked to cut the power for 30 secs and restart. Tried that did not work...
http://appliancejunk.com/ge/cookingproduct/31-20105.pdf
Please find above your service and repair manual, use this to troubleshoot and resolve your issue
This website below will also assist in locating an reolving your problem.
http://www.acmehowto.com/howto/appliance/range/erange.php
E6 - Drain pump error Water level does not decrease to reset point within 15 minutes from draining water from the washer. Press POWER button. No other buttons work:
· Check wiring harness
· Check pump motor
· Check circuit board
0 or F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
Aug 20, 2010 | GE Ovens
The water fills and drain from the bottom of the washing machine. Have checked all the pipes no problem. Please advice
front load or top ? drain hose must be elevated to 36 '' 34 min. if hose on floor it will not work .. needs stand pipe . if its leaking inside you may have a hose off . reinstall and wala it works .. mm hope some of ans work for you ..
Dec 03, 2009 | Ovens
Model WPDH 8900 start/pause button keeps flashing, no water flows to begin cycle
un plug machine / make shure water is turned on / plug back in . reset cycle / if same problem . change wash tempt . if same problem sounds like programer .not you but the digital control .. mm
Dec 02, 2009 | Ovens
GE WPSR3120WOWW FIRST WASH WORKED AND DID'T FILL BACK UP WITH WATER FOR THE SECOND WASH AND THE SPIN CYCLE WON'T WORK.
Pop the front cover off by using a putty knife to push the clips in (2) at the seam where it meets the washer's top. Pull the thin hose off the left side of the tub and clean it out. (do this with the tub empty) replace tube and front panel and you are good to go.
Explaination: The goop in the tube prevents air from escaping as the water level droped, thus the washer thinks it is still full of water. If it thinks it is full of water, it will not fill any more, nor will it spin.
To prevent this from re-occouring, I'd suggest filling the machine to the lowest level with hot water and adding several cups of bleach. Run the cycle (with no clothes) to help clear out the goop. Use an extra large rinse to make sure there is no bleach residue before doing a load of clothing again. Do this about once every 3 months, and I don't think you'll see the problem again.
Nov 15, 2009 | Ovens
GE Profile JTP18 Electric Single Oven Logo
194 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
