Question about HP LaserJet 2840 All-In-One Printer
50.3 fuser error
I have a problem on my HP Color LaserJet 2840 which has an error 50.3 fuser error. Need some help on how to solve this problem.
Thanks.
    President:
  • HP Master
  • 1,314 Answers
You need to replace the fuser, a consumable item.
Posted on Jun 17, 2009
HP Color LaserJet 2840 keeps showing 50.2 Fuser error message. Nothing helps correct problem. What to do? Have tried repeatedly turning printer off, waiting several seconds and turning on again. Each time...
The fuser is the heating unit near the paper exit, and that error means the lamp is burned out, the overtemp sensor is out, or the thermistor in the fuser is bad. About all you can do is replace the fuser. www.precisionroller.com will have a new fuser for you.
Jan 12, 2010 | HP LaserJet 2840 All-In-One Printer
The hp color laser jet 2840 does not print. message "50.2 fuser error" appears
HP recommended checks: 1. adequate 120 VAC power supply, 2. Remove Fuser Assembly, wait 5 minutes and then reseat. 3. Reset the printer to Factory Default settings (remember to copy down the IP address, mask and gateway numbers first).
While this may solve the problem, it is much more likely it's time to replace the fuser. Cost is approx $125 if you buy it online. Just do a Google search on HP 2840 fuser.
This link will show you where your fuser is and how to remove and replace it.
http://h20464.www2.hp.com/resultsCSR.htm?prodSeriesId=445194&MEID=631309C6-088F-43F9-931F-604BAE10EB69
Oct 21, 2009 | HP LaserJet 2840 All-In-One Printer
I get a 59.4 error trying to print with the 2840
The problem is not the fuser, is the main motor, you have to change it
PRINTER ERROR A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error 1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor’s cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
May 26, 2009 | HP LaserJet 3600n Printer
My HP Color Laserjet 2840 and is saying "50.1 Fuser Error"
HP error message 50.X is usually a fuser error. replace fuser
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
50.2 Fuser Error in HP Laserjet 2840
Printer connected straight to wallsocket,?check the fuser, remove it check for damages, and put it back, if error persist buy a new fuser.
Nov 10, 2008 | HP LaserJet 2840 All-In-One Printer
Need to order a replacement FUSER it's located in the rear of the printer. If you live in the USA you need 110V if you're in Euro 220V see below for the part number you need to order.
RG5-7602-000
RG5-7603-000
Fuser ***'y, 110V, CLJ 2820/2840
Fuser ***'y, 220V, CLJ 2820/2840
CLJ 2820/2840
Aug 06, 2008 | HP LaserJet 2820 Printer
Hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
When you print it cimes on 50.1 fuser error and won't print
Your fuser lamp is not coming on. Reseat the fuser. If that does not help, your fuser will need to be replaced.
Mar 03, 2008 | HP LaserJet 2840 Printer
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Dec 05, 2007 | HP Color LaserJet 2600n Printer
HP LaserJet 2840 All-In-One Printer Logo
1,086 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
