Question about Maytag Performa PAV2200
Washing machine make humming sound in control panel
Same humming no matter what type of wash cycle i turn to. i think its the control panel.
  • 111 Answers
Change the start capacitor located at by the motor or at the back of the unit
Posted on Jun 18, 2009
Washing machine spins to slow to drain all water
Your drain hose might be clogged. Disconnect it and try to run water through it.
Dec 01, 2012 | Frigidaire 14 Cycle Tumble Action Washer
Washer control humming
it's always worth replacing the brushes - pattern one's are cheap at around 20 quid so it's just about the cheapest thing to try and washing machines do all mannor of crazy things you wouldn't think were related - like not draining (the water does still drain out but when it hasn't spun properly the clothes are still full of water for instance) worn brushes have a differing effect on difrent washing cycles. the other thing to suspect is the controller -but these are so expensive you can nearly always buy a cheap washing machine for less
Oct 02, 2012 | Whirlpool Washing Machines
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
The washing machine goes through the whole cycle but the machine will not do the spin cycle and I think the agitator has a hard time moving?
If you find this check whether the machine pump out the water from the unit listen for the humming sound from the motor if you found the humming sound means your spinning coil is defective kindly replace the motor
Jan 20, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 80 series wash machine humming
you have a clogged pump
the pump is hooked directly to the motor if thats cogged the motor cannot move producing a humming sound
Oct 07, 2009 | Washing Machines
Frigidaire GLTF2940ES0 won't pump or spin
Sounds like a water valve solenoid. The hot and cold water is controlled by solenoids that open and close. Try running just the hot and just the cold. If one or the other works, then the proble,m is a bad solenoid valve
May 28, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Wash goes silent at the rinse and spin cycle
if the wash water isn't draining you have a bad lid switch back out the two screws at the bottom of the control panel in the back pull the control panel forward tilt it back on its hinges on the body of the washer you will see a connector with three wires grey green purple make sure the knob is in disconnect the connector and put a jumper wire from gray to purple where it goes to the control panel pull out the knob and see what happens
Mar 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Noisy
usually a noisy machine means either the main bearings have gone or the motor has got damaged/worn in some way. to check the main bearings try lifting the drum with the hand from inside or rotate the drum with the hand to see if the rumble can be felt. i cannot think what else would cause a loud humming though.
Jun 11, 2007 | Zanussi FJ1454W Front Load Washer
Washing Machines Logo
106 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
