Will not copy in black ink, install all new cartridge , and checked vent holes and ran clean cartridges, ran align printer says it fails, one time it showed error on control panel of OXC 19A0013
Hp7510e photosmart All three in one C11a product no 877a B1h option . When copy on color it will copy color section but will not copy the black sections. Is there print head problem or memory problem, is it worth fixing in shop? Thank Mark
CoachTim
  • 202 Answers
SOURCE: incorrect ink level reading
kiwipom, While ink cartridges look like plastic cups that only hold ink...they are not. The information the printer needs to think it has a "NEW" set of ink cartridges is on the cartridge itself. You must fakeout the printer to believe you are inserting "new lexmark" inks. Printer companies make money from the repeated sale of the ink, not the printer itself. I had an old epson that I would refill I would then have to place pieces of tape on the cartridge turn the printer on, remove the cartridge move the tape to another side of the cartridge turn on again etc. Anyway lexmark may need the same. When the new original cartridges show try them first to get the printer "thinking" correctly. Let me know what happens. Good Luck, Tim
Posted on Feb 28, 2007
Soulvisitor
  • 1113 Answers
SOURCE: I admit it, I used cheapo refill ink! Now the black section of the print head doesn't work...
I'm afraid there is no real sucessful way of cleaning these print heads, tiny micro filters built into the head unit will blocked. I have never unblocked one fully.
Fix is to replace head
These heads are not easy to fit, then once they are you must program in the head id and run a purge with four gen inks, this purge uses like 1/4 of each ink.
Recommennd you replace printer it is cheaper to
LINK to UNRECOMENDED removal of head
I dont have the 420 cn listed but here is link to mfc425cn head info so you can see how much they are not worth buying
below is pic of head
2d7dc76.jpg .
Posted on Jan 13, 2008
SOURCE: CanonPIXMA iP90 Color Ink Tank installation problem
can anyone tell me what to do
Posted on Sep 24, 2008
Joed911
  • 4338 Answers
SOURCE: my photosmart hp C6180 keeps saying printer
C6180 reset:
Perform a semi-full reset to set all user menu settings, telephony parameter settings, country/region and language UI, fax memory settings, fax journal information, speed dial and broadcast lists, personal header information, and junk fax settings to the default settings. Performing a semi-full reset of the All-in-One
  1. Use the On button to turn on the product.
  2. Remove the power cord from the product.
  3. Press and hold the # and 6 buttons.
  4. While holding the buttons down, connect the power cord to the product.
  5. Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
  6. Use the On button to turn on the product. The reset information appears on the color graphics display.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01457329&cc=us&lc=en&dlc=en&product=1153494
Or a Full reset:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00720248&cc=us&lc=en&dlc=en&product=1153494
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jun 12, 2009
  • 421 Answers
SOURCE: I have no way of changing the ink cartridge in my printer.
Hi, the information you need is here:
http://support.epson-europe.com/onlineguides/en/sc46/index.htm
Just click on the replacing ink cartridges on the left hand side, follow the instructions and pictures there.
Posted on Jan 13, 2010
Not printing black
You didn't say printer name but it sounds like you have seperate cartridges! Most cartriges have connection points built in for the electricity to heat ink. You might want to see if the connection on both the printer and cartridge are clean.
some printers will tell you ink level! If yours tells you you have ink in the black then connection are good.
your test print must be missing the black, so I have also seen where multiple head cleanings may be required to unclog inkjet cartridge ports.
if not a manufacturers cartridge but refill you might want to try a new one.
Did you try selecting print black only? Like you are making a copy!
Sometimes HP cartridges have a small vent on top near rear that can clog use small pin to clear any vented buildup.
Sep 29, 2016 | Office Equipment & Supplies
MY HPOFFICEJET ALL IN ONE SERIES 4620 WILL NOT PRINT IN BLACK WHEN YOU DO A ALIGNMENT PAGE THERES NO BLACK WRITING SO THE SCANNER SAYS COULD NOT DETECT ALIGNMENT PAGE ALIGNMENT FAILED WHAT CAN I DO NEW...
I have a 4620, and had the same thing occur with the black ink. After a few hours on the phone with HP and them sending me a replacement printer that also wouldn't print, I found that there is a "vent" on the printer cartridges that if clogged, will cause that color not to print. The vent is on the top of the cartridge, facing up when installed into the printer. The vent looks like a "T". Unfortunately, the packaging that HP uses on these cartridges sometimes causes glue to clogged the vent. Take a sharp nail or straight pin, and clean out the vent. Hope this is successful for you.
Aug 01, 2014 | HP Office Equipment & Supplies
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
Fails to print black at all
you need to do two types of cleanups one by the softwar5e and selecting self-cleaning and alignment and the second by hand and that by taking both inks out and using a clean dry cloth to clean around the ink cartridges and make sure that the vent hole is clear and no stiker5s on the housing after that with a clean cotton swaps clean the inside housing in the printer and install the inks again starting with the black making sure that the ink is placed good in the housing and close the door good and run the alignment, and let me know how that worked.
Please see that grant me your approvals by rating my service and I hope that I can serve you again the future.
Sep 26, 2009 | Canon SmartBase MP390 All-In-One InkJet...
New black ink cartridge won't print for Brother MFC-290C
run software cleaning function for the heads and run the alignment, make sure that you move all the stickers from the cartridges and the vent hole is clear, clean the inside housing from any dry ink...let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 20, 2009 | Brother MFC-290C Printer
Printer produces a poor copy
remove cartridges , take a q-tip w/alcohol and clean out ink ports where they drop ink onto the paprer the ports could be clogged with dry ink , thus preventing the new ink from reaching the paper. after you clean out the ink ports re-install the cartridges, and do alignment proceedures again this time color should be restored
Jul 11, 2009 | Lexmark X2250 All-In-One InkJet Printer
Won't print or copy (looks like it's out of ink or cartridge is jammed)
if you have the program of printer install to your comp ? then run the maintenance program , that will CLEAN , ALIGN , AND PRINT A TEST PAPER , AJ
May 08, 2009 | HP OfficeJet R80xi All-In-One InkJet...
Printer will not copy
It Does keep asking if it fails to get it right, usually it fails to get scan of alignment page completed correctly because it fails to see one of the colours printed on its alignment page correctly,
I would guess that you should change colour cartridge as well (these I have seen deplete themselves trying print black when black ink is not present.
There is also a way of telling your printer to forget about alignment would you like to know how......Press and hold the Setup button, and then press Options (or Copy Options ).
Here is a link to how an alignment page should look and HP answers to your problem, please rate my solution for me.
Nov 21, 2007 | HP PSC 2175 All-In-One InkJet Printer
Ink cartridge alignment problem
well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called amazon.com and i ordered a new epson printer,
Oct 26, 2007 | HP PhotoSmart C4180 All-in-One Color...
14 people viewed this question
jasbo
jasbo
