Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Exhaust filter keeps popping out - Kenmore 25512/ 25513 Progressive Canister Vacuum
  • 39 Answers
If the filter is clogged or not breathing well it will pop off. These filter are only good for 6 to 12 months of normal use. You can run it without the filter . The filter only helps with allergies.
Posted on Apr 13, 2014
Dyson ball dc25 filter B keeps popping out
Hoover or dyson , can not be both
Jul 22, 2016 | Dyson DC25 Vacuum
How do I fix the machine - the filter keeps popping making me stop vacuuming several times per use.
Contact Dyson and ask if there is a fault with this type of cleaners air filters. They may send you a new part to fit if there is s known fault.
Any of the washable filters have to be left for a few days to dry in normal weather before they are fully dried out before the unit can be used again. If possible try and hang them up on a washing line to allow the free flow of air to dry the filter.
May 22, 2015 | Dyson DC25 All Floors Bagless Upright...
Filter in the ball keeps popping out even though it is clipped in place.
Air filter is not getting air flow.air must pass thru filter or it will pop off.I placed filter against exhaust end of shop-vac ( NOT SUCTION END) untill I got air coming out.
Mar 12, 2015 | Filter Vacuums
Cannot find filter in bag compartment
If you're looking for the exhaust filter, it is on the top of the machine under the crevice tool and dusting brush.
If you look at the rear of the machine you will see a tab on the attachment holder.
Remove the attachments on the unit
Push tab on rear of vacuum on the attachment compartment
Lift cover and your exhaust filter should be exposed and should just pop right off for replacement.
Mar 03, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Heppa filter pops off when I turn the vacuum on
Did you replace the exhaust air diffuser? That's the plastic type vent housing the hepa filter was under.
Oct 12, 2013 | Electrolux UltraActive Turbo Bagless...
Heppa filter keeps popping off when i turn on the vacum
Hi There, 99 times out of 100 this is due to the exhaust filter being too blocked for the air to actually get through. What happens is that the pressure in the motor increases and effectively blows the filter and filter cage clean off. If you have a look at the underside of the filter I would bet that it is very dirty and you will need to buy a new hepa filter
Oct 12, 2013 | Electrolux EL7055A Bagless Canister Vacuum
Ultraactive vaccum filter keeps popping off
There are two possible causes for this issue. The most likely is that your exhaust filter is blocked and so the air literally cant get out. You need to replace the exhaust Hepa Filter every six months anyway so get a new one and see if that fixes the problem. If it still is popping off after this it means the tiny lugs on the filter cover are damaged so you will need to get a new one of those.
Jul 11, 2013 | Electrolux UltraActive Turbo Bagless...
Filter in ball keeps popping off
Is the spring in the clip that locks the filter in place , it's not much bigger than the one found in a pen !
Feb 19, 2012 | Dyson DC25 All Floors Bagless Upright...
Inner ball filter keeps popping out of place when trying to use vacuum.
Jul 23, 2011 | Dyson DC25 Animal Bagless Upright Vacuum
The bottom filter under the canister keeps popping out everytime I vacuum. This is really annoying. The bottom looks sort of dirty but I'm not sure how to clean it.The top looks very clean. I know I need...
This is a pretty clear indication that your filter is clogged and needs to be replaced. HEPA filters are different then say pre-motor filters, or sponge filters. Because they are usually the last filter before the air is exhausted, it's usually catching very tiny microscopic particles. Because of this, trying to determine if the filter is dirty or clogged can be difficult, if not impossible on HEPA pleated exhaust filters.
The fact that your filters continues popping out, indicates that the air is not being able to pass through the filter as it's supposed to, and is instead the air is having to try and find a different way to escape, causing the force of the back up of air to blow the filter out.
I think if you replace this filter, it should fix the problem completely. Because this filter is designed to capture microscopic particles rather then large particles, washing this filter, or getting it wet is not advised, and wouldn't be an effective way to clean it. You really will need to replace the filter soon, but if you'd like to try and prolong the life of your filter, you may use an air compressor, and blow from the top of the filter (the area that looks clean), and clear the microscopic particles, and dust out of the filter this way. If you suffer from breathing issues, asthma, or allergies, I would highly advise against doing this without a mask on. The dust that will come out is extremely fine dust that can cause people with the above conditions to suffer greatly. Doing this outdoors is highly recommended.
An air compressor can certainly prolong the life of HEPA filters, but again, sooner or later you'll need to replace the filter.
If you're in need of buying one of these filters, you're in luck! We carry these filtes on our site, and they are in stock. Here's a link back to the filter on our site if you need to order one. We offer free shipping, 60 day returns, free return shipping, and no restocking fees. Please feel free to reply to this solution by using the comment box at the end of this solution. If you found my solution to be helpful, please be so kind and rate my repair, or leave feedback for me. This is greatly appreciated by the FixYa community, and is really what keeps repair professionals like myself to keep answering free questions, and not just the premium questions which we get paid to answer.
http://www.govacuum.com/10662-Hoover-303172002-Windtunnel-T-Series-Replacement-HEPA-Filter-Cartridge.aspx
Thanks so much,
Chris Jones
GoVacuum.com
Jan 07, 2011 | Hoover UH70120 WindTunnel TSeries Rewind...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
