Question about Ovens
My oven had 1electrical power then suddenly cut out .
    Problem Solver:
  • 6 Answers
Would need a little more info. could be many things but check that someone hadn't set the timer and the oven turned off on time. fint the instruction book and reset the timer.autocook back to Manual.
Posted on Apr 13, 2014
Multi purpose oven won't work after power cut have reset clock, light won't work. Is making all the right sounds just won work
power supply from clock damaged not by power cut but voltage spike when power resumed the oven thinks its in auto mode permanentley thats why it wont come on ,new clock or power board needed.
Feb 03, 2017 | Neff Ovens
Main oven not working following a power cut. Timer flashing AUTO and clock control buttons not working
The auto function will cut off the power to your oven try switching the oven to manual control to reset the control.
Apr 26, 2015 | Ovens
We had a power cut this morning ours is a double oven, the small oven/grill works but not the main oven also there is no clock on
This fault is unlikely to have been caused by power outage. Disconnect from mains, remove rear panel and look for damage in the area where the power cable connects to the iven
Nov 24, 2014 | Ovens
What causes the flame switch to cut out ion an Imperial ICVD convection oven
This flame sensor switch is a safety device that only allows the main valve to open after is is satisfied there is a pilot flame. Otherwise if there were no pilot and the main valve was allowed to open, the inside of the burner area would quickly fill with gas and pose an exposion hazard. The original capillary tube type switch is obsolete and a new electronic unit conversion kit is available. Contact Imperial tech support for more information
Apr 29, 2012 | Imperial ICVD-2-HH Turbo-Flow Gas Double...
I replaced the flash timer on my oven and the power still does not come on what else could it be???
Is the electronic timer in the manual mode?
Is the element faulty?
Poor connection at the oven element terminals?
No voltage output from the oven thermostat control?
The oven thermal cut-out switch has operated and cut all power to oven?
Feb 08, 2011 | Frigidaire Ovens
Oven cuts out as soon as it reaches temperature
not expert on bosch but sounds like cooling fan not working, either fan defective or cut in themostat not working.
Jul 22, 2010 | Bosch Ovens
No Power to Belling 163 model
check the safty cut out, if there is one
May 16, 2009 | Belling XOU252 Electric Single Oven
The Oven won't heat up
the thermal cut off located on the back of the oven has probably tripped,common problem. replace thermal cut off.
Dec 19, 2008 | Whirlpool RBS245PDS Electric Single Oven
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
Ovens Logo
32 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
