Question about Dell Dimension E521 PC Desktop
Dell Ispirim will not boot after power failure. Fans run, mb light on. Dtartup buttom amber.
Power supply seems ok. Will not post-could cpu be in sleep mode?
  • Dell Master
  • 998 Answers
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Posted on Jan 03, 2015
pagebor
  • 2785 Answers
SOURCE: Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Posted on Aug 08, 2008
  • 326 Answers
SOURCE: Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Posted on Aug 11, 2008
jelacio
  • 10 Answers
SOURCE: I have a flickering amber light on the power button; replaced power supply and motherboard with no luck
FIRST IF YOU REPLACED THE POWER SUPPLY OF YOUR DELL PC,
MAKE SURE IS A RECOMMEND POWER SUPPLY FOR DELL COMPUTERS ONLY
BECAUSE DELL USE A DIFFERENT (NONSTARD) PS
AN PLEASE DON'T TURN YOUR PC ON, TILE YOU ARE SURE I'TS A DELL COMPATIBLE POWER SUPPLY
YOU CAN FRY YOUR COMPUTER
ON THE MOTHERBOARD I'T MAY BE THE BIOS (BIOS STANDS FOR INPUT /OUTPUT SYSTEM) I'T A CHIP ON YOUR MOTHERBOARD THAT CONTROLS THE SYSTEM HARDWARE AND ACTS AS AN INTERFACE BETWEEN THE OPERATING SYSTEM AND THE HARDWARE
I'T MAY BE FLASH
IF IS FLASH ,
YOU PROBABLY NEED TO REPLACE THE MOTHERBOARD
OR CALL DELL TO SEE IF THEY CAN FIX IT
Posted on Aug 20, 2008
SOURCE: Dell GX280 no display
I solved this on a Dell GX280 by removing the CPU and then reseating it in the socket. Also cleaned cpu and heatsink and applied new thermal compound.
Posted on Nov 01, 2008
  • 28 Answers
SOURCE: dell c521 won't start
- disconnect the hdd and optical drive cables, remove the expansion card, reseat the atx and 12v cable and turn the computer on. if the power led is glowing green connect the devices on by to find what device is causing the no post issue. after the strip down if the power button is still yellow replace the motherboard
Posted on Dec 19, 2008
When I power on the desktop the power button LED turns to steady amber and the fans race constantly at high speed. The system does not seem to complete POST or boot into the O/S. I changed the CMOS Battery...
Can you check at the back of the computer to see what the diagnostic lights are indicating 4 led's (eg yygg - yellow yellow green green) - post the result and i may be able to provide a soltuion
Sep 24, 2013 | Intel K83v0 Dell Motherboard Inspiron 560...
Optiplex 320 wont boot. Amber power light and fans running
power off 1st..then open ur cpu ..check ur ram ...and clean it....or mother board is not work replace near hardware shop....or check ur bios bettery or change it
Feb 17, 2012 | Shuttle sn Computers & Internet
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
We have around 30 units of DELL Optiplex GX280 having mother board failure. It was more then 3 years old already. Once the turbo fan become noisy then it will gone dead.
May be serious. See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans sound like 747 taking off. Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
I obviously can not be 100% sure about this as the unit is not here.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one such link.
http://en.community.dell.com/support-forums/desktop/f/3514/p/19253544/19414291.aspx
Feb 16, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
I have a Dimension 4700 that was working until recently.Now the computer won't boot at all. There is no power, the fans aren't whirring, no beeps and no video on the monitor. The only signs of power are a...
1a Research your blinking amber lights and the ABCD's. If the specifics don't explain a LACK of power (because even a shorted USB device can sap your juice resulting in a no video condition for example) try these:
Steps to get any PC running again:
1. Remove all addon cards and HD's CD's, so all you have is video, keyboard, and mouse.
Try it - if you see any video, add one thing back at a time starting with your boot and other drives. When it dies again, there's your problem...
2. Reseat the RAM and CPU
Try it, if it works you fixed it until oxygen does its thing again in a year or two...
3. Test power supply voltages with a meter, just test a hard drive connector, red and yellow are positive and the 2 blacks are grounds you should have both 12 volts and 5 volts, (plus a couple lower voltages for the CPU and RAM on the MB, disregard for now) if 5 and 12 are there, test that they have good amperage (over 1 amp will *usually* mean you have full power)
If it still doesn't work, it's either a power supply problem with the lower voltages, or a motherboard problem, retry steps 1 and 2 a couple times, then...
4. beg borrow or (eeek! buy) a power supply...
80 or 90 percent of the time, you won't get to step 3, let alone 4, all that's left is the motherboard, etc. good luck
Aug 09, 2010 | Dell Dimension 4700 PC Desktop
Dell Inspiron Vostro 530s won't boot.
I work for Dell, If the power button led light is flashing amber or amber (the Power supply is faulty) The Yellow light you saw inside the motherboard is the "Flea Light" (that is one way you could check if there is still power on the motherboard). Since the motherboard was replaced there are a few more things to check:
1. Video card (integrated or expansion)
2. Monitor (Make sure it displays self test feature when the cables are removed)
3. Monitor Cables (VGA / DVi)
4. Power Cable on the Monitor (try a different cable)
5. Power Supply (you already checked, but i suspect this is causing the problem)
Hope this helps.
Mar 16, 2010 | Computers & Internet
My tower won't turn on it keeps flashing yellow, no response. What can I do?
take everything out of tower plug in keyboard power and video see what happens
do not unplug power to mb two seperate plugs a 20 pin and a 4pin
Oct 31, 2009 | Dell OptiPlex GX270 PC Desktop
Power Problem
It could be the power supply isn't getting enough current to run things. I'd start there.
Jun 21, 2008 | Dell Dimension 4600 PC Desktop
Power
You might have to change your power supply..(ex:SMPS or ATX)
Oct 23, 2007 | Dell OptiPlex GX270 PC Desktop
Dell Dimension E521 PC Desktop Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
