Question about Samsung ML2525W Laser Printer
I get a ghost image when printing
Happens with all media weights from paper to card. I get a nice printed image and next to it a very light, yet noticeable print of the same image.
  • 78 Answers
2 things can cause this problem.Since I can not see the problem all I can do is tell both problems.If the image is black like toner in both places then you probably have a defective fusing assembly with coating worn off.It acts like a Teflon skillet with teflon worn off. The eggs stick to where the coating is missing.So with that said if coating is missing from fuser then toner sticks and comes off on the page on the next revolution.The other problem is with the drum/toner cartridge.The drum is not cleaning after the print is put on the page causing the image to repeat on the page.
Posted on Apr 16, 2014
Soulvisitor
  • 1113 Answers
SOURCE: Samsung 1710 stops before printing
Sounds like the printer is having trouble feeding the paper , it tries then fails to feed paper and goes into jam.
Locate rubber feed roller (usally grey or black about a inch wide should be , lower front above paper tray, whipe this rubber roller with a slightly damp cloth and try again
You could also verify if this is the problem by feeding paper via bypass instead of paper tray
Check to make sure error light is not indicating no toner and that is what is stopping printing
Posted on Oct 29, 2007
SOURCE: printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Posted on Dec 03, 2007
  • 4 Answers
SOURCE: Paper Jam
I have just SOLVED my CLP 300 printer paper jams by replacing the rubber band on the paper pick up roller. My old rubbber had worn flat and had dried out. I was lucky as Samsung had sent me one for an engineer to fit. However, being an engineer myself, I replaced it with instant success!
You could fix yours without replacing the band because all it needs is to be turned around to a non worn area. To get to it safely, unplug your printer from the mains supply and the USB cable. Remove the paper tray.
Open the front door and remove the imaging unit complete with toners. Now turn your Printer upside down and look for the rotating bar with a centre wheel and rubber band. The rubber band looks like it only goes half way around the wheel. This band is Clipped onto the wheel. With careful prising, you can unclip the rubber band. It's a bit tricky and tight but I have done it no probs. Perhaps being a techy myself has helped? Anyway, rotate the band around so that a fresh bit of rubber will be acting on the paper and refit. This is also tight and tricky, but can be done without dismantling the printer to replace the who bar.
The actual part that is unserviceable is the rubber on the Samsung MEA unit pick up roller. The part number is JC97-02647A
Now refit all the other stuff and test your printer. I have also got rid of the dreaded clicking too! But that's another story.
Hope this helps?
Posted on Dec 30, 2007
galadhiren
  • 15 Answers
SOURCE: printing photos
Of course you can use 4x6 photo paper
you have select the paper size from page setup as 4x6
and put the paper in the tray after adjusting the tray size
Posted on Jan 02, 2008
  • 14 Answers
SOURCE: I am getting a ghost image of what I am printing
i would say ghost image is more likelly your imaging drum.
some printers have the imaging drum built into the cartridge some have it separate.
i would say try another cartridge
also don't trust remanufactured cartridges if you are concerned with print quality.
Posted on Apr 24, 2009
Hp 5550 patchy print
Most of the cases fuser assembly or supplies are causes of ghost image. If image is not properly transferring on media causes transfer roller or ETB.
Do this small exercise: Give print command, wait till paper grabs, once paper entered in cartridge area, power it off, open top & front cover, remove paper and see the print quality.Observed any ghost image what you observed? No ghost image? then problem with fuser assembly..
1.Remove fuser assembly, check any toner particles deposited on surface of fuser transfer roller or heater roller.. if found clean carefully with good cotton cloth while fuser having certain temperature,pl avoid metal & sharp objects to clean..
2. Clean paper path roller(You can observe the rollers to push the paper to reach the destination)
I hope this exercise will resolves the issue..
Jul 26, 2012 | HP Color LaserJet 5550hdn Printer
RICOH FW740 is printing with a ghost image. Can I clean it myself?
Ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. Read More here Image ghosting problem
Dec 02, 2011 | Ricoh Office Equipment & Supplies
I have Minolta 2300W Laser Printer and it folds the first page only about 3 to 4 inches down makes a nice one inch fold but take that out and print again...next page fine.....now printing with two wide...
The is blocked by dust on the side of the paper on the image unit that would have color associated with the print. Remove all the image units and clean all the laser glass. Replace those image units also if streaking as for the paper ensure correct paper side and media type.
Jul 12, 2010 | Minolta magicolor 2300W Laser Printer
Can't remove memory card from printer
hi
  • Ensure the MP970 is connected to a working electrical outlet. Turn the printer on by pressing and releasing the power button located on the upper left hand side of the control panel.
  • Step 2 Select the memory card you wish to use. Insert the memory card into an appropriate adapter if it requires one. Open the Card Slot Cover, located on the right hand side of the printer, by pulling the door out and toward the center of the printer.
  • Step 3 Insert the memory card into the appropriate card slot with the label side facing up. Confirm the Access Lamp is lighted. Close the card slot cover.
  • Step 4 Check the "Select and Print" option on the display screen. Select the "Okay" option.
  • Step 5 Load your preferred print media into the printer. Confirm Paper Source, Paper Size and Media type. Select the "Okay" option. Select the "Next" option. Select the "Okay" option to access the images on your memory card.
  • Step 6 Press the Left or Right Arrow buttons to select the image you wish to print. Press the + or – button to determine the number of copies of this image you wish to print. Select the "Okay" option.
  • Step 7 Confirm your print instructions. Select the Print option to being printing your photos.
  • Jul 06, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    Poor print quality
    The "ghost" image is "burned" onto the drum.
    A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
    You need to replace the drum.
    Apr 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
    Text is "ghosting" when using card stock
    I sort of solved my ghosting problem by selecting print, set up, and then under media type selected thicker paper. This apparently pulls the card stock through at a slower rate which helped tremendously. One of my documents turned out perfect and the other "ghosted" just a little.
    Dec 17, 2008 | Brother HL-2070N Laser Printer
    OKI c5400
    Assuming that you are using the same paper and have not changed any of the consumables you should do the following:
    1. Clean LED head with lens cleaner or soft tissue.
    1. Remove the toner cartridge and give it a few shakes then reinstall it.
    2. The Toner Could be low so Change toner cartridge.
    4. Make sure that the paper is not damp as this will cause fading and poor quality printing and images.
    1. The image drum may have been light contaminated so remove it from the printer and store it in a totally dark place for several hours then reinstall it.
    2. If the image drum is dirty then wipe it very gently with soft tissues, being careful not to scratch it.
    3. Open the top cover and check to be sure that each toner cartridge is fully seated and that each toner cartridge lock lever is pushed all the way back.
    4. Press the top cover release latch and open, then close, the cover.
    5. Check MEDIA MENUTRAY1 MEDIA TYPE and set as required. Do the same for TRAY2 and MPT.
    6. Check MEDIA MENUTRAY1 MEDIA WEIGHT and set as required. Do the same for TRAY2 and MPT.
    7. Possibly set the value of media weight in the menu to the next heaviest one.
    8. Check PRINT MENURESOLUTION setting and set to 600 x 1200DPI
    9. Check PRINT MENUTONER SAVE MODE and make sure this is OFF
    10. Check PRINT MENU – MONO PRINT SPEED and make sure this is set to MIXED SPEED
    11. Check the COLOUR MENU – DENSITY CONTROL and set this to AUTO
    12. Check the COLOUR MENU – AUTO DENSITY and set this to EXECUTE
    13. Check the COLOUR MENUCMY 100% DENSITY is set to ENABLE if you want a glossier black finish.
    Feb 17, 2008 | OKI C5400 Laser Printer
    Samsung ML2525W Laser Printer Logo
    165 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    CheckitRight
    CheckitRight
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
