Question about Stoves 720EF Electric Double Oven
NEED TO KNOW WHERE THE ELECTRICAL FUSES ON OVEN
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 80 Answers
There are no fuses on ovens other than soldered into PCB's or timers. they use the household RCD
Posted on Apr 13, 2014
Where is the fuses located on a moffat stove
There are none. It is wired into the buildings electrical panel. You have to know where the circuit breaker panel is to find a tripped breaker
Aug 10, 2016 | Moffat E32 Full Size Electric Convection...
Miele 212 oven does not work. We have a Miele oven that does not work anymore. 220V gets to the oven and then nothing happens, no lights, no display, nothing... Advise anyone?
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
May 18, 2015 | Miele Ovens
Troubleshooting power issues for whirlpool accubake double oven
5.Even a bad relay door switch will hinder your oven from operating.
Mar 02, 2015 | Whirlpool Ovens
No power after self cleaning
5.
Dec 14, 2013 | LG LWD3081ST Electric Double Oven
Our Belling Touchtronic hob wont now turn on. Have checked wiring on the mains and fuses but make no difference. Any ideas? Was fine yesterday and had shown no signs of intermittent working
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: I offer free advice bcuz God is so good!
5.
Dec 27, 2012 | Belling Ovens
MY OVEN WILL NOT WORK, WAS WONDERING IF THEY HAVE A FUSE IN THE BACK OF THEM. NOT EVEN THE LIGHT WILL COME ON THE KNOB. IT HAS ON IT MODEL 6AKP603/WHAND THE TYPE IS FCEM6.
Check the Main Electrical Panel for your house or apartment. There will be a breaker or fuse in there for your Oven. If it's a new Electrical Panel it will have the Breakers, so reset them. If it's an older Electrical Panel it will have Fuses, replace them. Depending on the Building codes in your area it should be Two---30 amp fuses.
Jun 08, 2011 | Whirlpool Ovens
Hi the main oven doesnt heat up
There are a couple of quick things to check. First, check the fuses, there will usually be a row of scew-in fuses, probably in the upper cabinet where the controls are. Ensure that the oven controls are set to "off" before you remove any fuses, it is safer. If the fuses are alright, check the oven timer, as many older mechanical timers may stick and effectively "lock-out" the oven. It is not uncommon for a wiring connection to fail, but unless you are comfortable and competant with electrical repairs you may wish to call a service tech. Also, please be aware that the wiring and all the connectors must be rated for use in hot appliances. I hope that this is helpful, Rob
Jan 01, 2011 | Hotpoint Ovens
Hi there. I need to change the fuses on my oven,
hello,
Instruction below.
  • Unplug your oven. Insert the size 15 Security Torx bit into your multi-bit screwdriver and remove the screws from the back panel. Take off the back panel.
  • 2 Locate the fuse. It should be near where the electrical cord comes into the oven. The fuse is a small white bar with metal caps on either end. Carefully remove the fuse. Avoid touching the transformer or other parts inside the oven.
  • 3 Purchase a new fuse. Most whirlpool ovens use an 18 amp ceramic fuse. Consult your owner's manual to find out what kind of fuse is used, or take the old fuse into the store to find the exact match.
  • 4 Replace the fuse. Put the cover back on and see if your oven works. If it does, replace the screws. If it does not, try a different fuse. If the oven still does not turn on, you may have to have it replaced of professionally repaired.
  • thanks and thanks for visiting.
    Oct 09, 2010 | Ovens
    F3 hv breakdown
    you would need a clamp on amp meter and some basic electrical know how because you are dealing with a serious amount of power to seriously hurt or kill. You could try just looking at the hv transformers. sometimes you can see a burn mark which lets you know to change it, also check the fuses the third one (20 amp) is usually blown in this case
    Jul 27, 2008 | TurboChef C3 Single Oven
    Stoves 720EF Electric Double Oven Logo
    35 people viewed this question
    Top Stoves Ovens Experts
    ashburton
    Dan Webster
    Dan Webster
    Are you a Stoves Oven Expert? Answer questions, earn points and help others
