Question about Vizio VL370M LCD TV
Some dtv channels missing on VIZIO
Recently one local DTV channel (really #21, virtual 20-1 through -3) has disappeared from our Vizio TV. It has been replaced with what should be virtual channel 24-1 through -6 but they come up as 20-3 to 20-9. Tried all the reset, power disconnect, channel scanning, and antenna disconnect and connect suggestions. Nothing works. These two sets of channels come up correctly on other sets we have. All other channels are fine on this Vizio set as well.
    Genius:
  • Vizio Master
  • 1,039 Answers
Have you tried doing the channel search? If that does not help replace the main board
Posted on May 13, 2014
SOURCE: vizio vm60p hdtv scanning problem
I had the same problem. Change your input to dtv even if you are using coaxial input. Then go to the menu screen and select tuner settings. Dtv setting should appear.
Posted on Jan 05, 2012
Axle80
  • 73 Answers
SOURCE: Vizio P50HDTV DTV does not work any more
Call vizio's customer support line and tell them you got the 'pop of death', They know this tv is a lemon and are standing behind it to make it right. They will take down your info and serial number and set up a repair order FREE OF CHARGE. When I called, they told me that this model was know to have serious defects and was given a lifetime manufacturer warranty to cover all parts and labor! What happens is that they send someone out, he pronounces the TV to be dead and not worth fixing and they give you a brand spankin new one! This way they get a better reputation by 'covering' their duds but reality is that they don't have to keep fixing this tv if they replace it with a model that only has one year MFG warranty. Either way you win. Post back if you get a different result from calling Vizio. I'd like to know how everyone else's experience is turning out.
Posted on Mar 08, 2009
SOURCE: Vizio LCD DTV 32 inch. Model L32. I can't 'scan'
Follow up on No DTV tuner after unplugging it a month for vacation. After I let it set plugged in for about 2-3 days it started working normally again and has been fine ever since. I hope this may help someone else. Genez 6-7-09
Posted on Jun 08, 2009
  • 92 Answers
SOURCE: I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Posted on Jun 20, 2009
electrotech1
  • 1126 Answers
SOURCE: I have a Vizio VW42LF TV that is 2 yrs old.
The TV processor could have some garbage in it do to a small power surge and if you leave your TV unplug for 40MIN., then that will reset it bad to normal, and if tuner still looks snowy and not getting channels, then the tuner, or main TV module needs replaced.
Posted on Dec 19, 2010
VIZIO DTV WONT PICK UP CHANNELS
the freeview board has failed easy to change it is just clipped in on to the board. that also could be the fault it may have come out of its conector.
Oct 02, 2013 | Vizio VM60P 60 in. Plasma TV
Vizio vm60p hdtv scanning problem
Nov 17, 2011 | Vizio VM60P 60 in. Plasma TV
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
Unable to scan for available channels on Vizio VW32L
Check for proper cable connection on back of TV if there is more than one cable connector, and that you are scanning for proper source like AIR for the DTV tunner if no DTV tunner in TV you will need a Box, and if you are a cable user make sure you are scanning for cable channels.
Mar 15, 2010 | Vizio VW32L 32 in. LCD HDTV
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
CHANGE CHANNELS WITH THE CONTROL
Run a channel scan on the DTV and/or TV input depending on what one your not getting channels on. This will solve your issue.
Change the input on the unit to the DTV or TV input. Press the menu button on the remote. Navigate to the tuner DTV or TV tuner setup menu. Go down to auto search using the down arrow. go right when with auto search selected. This may take a few minutes but you should have all the channels back after the scan.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Vizio VL370M LCD TV Logo
263 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
