Question about Quad Cycling
Apache 50cc resistor is broke and then won't start
  • 906 Answers
LOL, Replace the resistor.
Posted on Jan 25, 2015
My apache 50cc quad has a new carburator but it's keeps flooding and cutting out
1. fuel pump to strong.
2. needle seat blocked.
3. wrong carb jetting
this is possible faults
Mar 23, 2014 | Garden
50cc apache quad spark problems
Could be the CDI. Check the stator and pickup coil specs with a multimeter first.
Nov 17, 2013 | ATVs
My problem i lost transistors for power for car amplifier audio apache i need numbers for transistors
There might be still other power transistors left, same part number
for the power inverter ( IRLZ43N on some ).
Except for the Main Amp that have Complimentary Pair
check for possible burnt or open resistors , too
Jul 23, 2012 | Audio Players & Recorders
My Peugeot vivacity 50cc moped won't start just
Hi, Check fuel tank that it has fuel. Check sparkplug and/or replace it. Make sure engine has spark when cranking it over. Good luck.
Sep 27, 2011 | 2010 Peugeot Vivacity Roland Garros
Gilera DNA 50cc the engine won't start but when I squeezed the wool surrounding the baffle there appeared to be some crust that I broke and it started. Howeer, after 2 miles the same problem. How do I...
you need to burn out all the carbon in the exhaust.it will be causing a restiction and making it hard for the engine to run properly.I would use a gas torch to do this but be real careful..
May 30, 2011 | Gilera 200 PRO Motorcycles
How do i get the pin out of balance bar assembly. part of the bar broke of in a crash. i have a new bar.
Where did you get your new balance bar? I have the UJ415 apache and broke the black balance bar off within 10 minutes but can't find a replacement? Thanks!
Sep 12, 2010 | Apache RC Mini Helicopter AH-64
Remove and replace balance bar?
Were you able to find a replacement balance bar? I broke mine and can't find one? Thanks!
Apr 18, 2010 | Apache RC Mini Helicopter AH-64
How to download and install apache on linux5
Hi Follow the below procedures.
How to install and start the Apache or httpd service under Linux
by Milind
Q. How do I install and start the Apache or httpd web server under Fedora core or Cent OS?
A. Apache HTTP Server is a free software/open source web server for Unix-like systems and other oses.
Apache features configurable error messages, DBMS-based authentication databases, and content negotiation. It is also supported by several graphical user interfaces (GUIs) which permit easier, more intuitive configuration of the server.
Use rpm command to install Apache under Linux. You can also use up2date or yum command to install the same.
Task: Install Apache/httpd under Fedroa Core/Cent OS Linux
Type the following command if you are using Fedora or Cent OS Linux:
# yum install httpd
Now, start the Apache/httpd
# chkconfig httpd on
# /etc/init.d/httpd start
Task: Install Apache/httpd under Red Hat Enterprise Linux
# up2date httpd
Start the Apache/httpd
Task: Debian Linux httpd/Apache installation
Use apt-get command:
# apt-get install apache2
# /etc/init.d/apache2 start
Task: Verify that port 80 is open
# netstat -tulpn | grep :80
You can also install httpd from CDROM with rpm command:
# rpm -ivh httpd*
Configuration
Your server is started but you need to configure and use Apache as per your requirement. /etc/httpd/conf/httpd.conf (RHEL/Cent OS/Fedora Core Linux) or /etc/apache2/httpd.conf (Debian / Ubuntu Linux) configuration file. Use text editor such as vi to edit file. This file is very well documented or read official Apache configuration documentation for more information.
Dec 30, 2009 | Red Hat Enterprise Linux ES 3 Standard...
Cycling Logo
Top Quad Cycling Experts
shaun taylor
Eric Hidle
Level 1 Expert
Are you a Quad Cycling Expert? Answer questions, earn points and help others
