Question about Quad Cycling
Apache 50cc resistor faulty - Quad Cycling
  • 906 Answers
Replace it.
Posted on Jan 25, 2015
How to cool my Apache rtr 160 engine
Hi, Krishna for overheating issues the usual suspects are:
1. Engine oil level and SAE weight are too low or not circulating.
2. Insufficient or blocked air flow over the engine.
3. Heavy combustion chamber carbon deposits.
4. Ignition timing retarded due to faulty MAP, CKP, or CMP sensor.
5. Carburetor jetted too lean.
6. Leaking intake or exhaust valve.
7. Water coolant old or low change every two years.
8. Water pump failure.
9. Radiator clogged, cap loose or malfunctioning.
10. Radiator fans not coming on.
11. Clutch slipping, brakes dragging, heavy load, towing a trailer etc.
12. Idling too long without moving.
13. For constant hot weather temperatures, mountain, or desert riding conditions consider adding an oil cooler and or cylinder head cooler.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Top 10 things you need to know about the 2012 TVS Apache RTR 160 180
https://www.tvsmotor.com/pdf/Manuals-Apache-RTR-160-NEW.pdf
Life On 2 Wheels
TVS Apache RTR 160 2010
TVS Apache Wikipedia
Mar 10, 2017 | 2010 TVS Apache RTR 160
Why does my TVS Apache 150 overheat?
Hi, Hasan and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.complaintboard.in/complaints-reviews/tvs-apache-rtr-180-l57056.html
http://www.motorcycleforum.com/129-first-bike-new-rider/192586-tvs-apache-rtr-engine-overheating-along-increased-idling-rpm.html
TVS Apache 150 2011 service manual DOWNLOAD FREE FULLMANUALS COM
http://www.tvsmotor.co.id/images/catalogue/docs/apache.pdf
https://www.tvsmotor.com/manual-download.asp
Jan 02, 2017 | 2010 TVS Apache 150
2012 Apache RTR 160 HyperEdge the neutral light is not on when it is in neutral, the electric starter will not work without the clutch lever pulled in, what is the problem?
Hi, Sushant the neutral light could be a burned out bulb, faulty neutral light switch or the wiring in between, the clutch lever has a safety switch so you can't start the bike in gear for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Common Problems with Bikes and Their Solutions
TVS Apache RTR 160 Long Term Ownership Review By Sabi
RTR 160 Service Manual
Apache RTR 180 User Manual
Nov 02, 2016 | 2011 TVS Apache RTR 160
My apache 50cc quad has a new carburator but it's keeps flooding and cutting out
1. fuel pump to strong.
2. needle seat blocked.
3. wrong carb jetting
this is possible faults
Mar 23, 2014 | Garden
50cc apache quad spark problems
Could be the CDI. Check the stator and pickup coil specs with a multimeter first.
Nov 17, 2013 | ATVs
My problem i lost transistors for power for car amplifier audio apache i need numbers for transistors
There might be still other power transistors left, same part number
for the power inverter ( IRLZ43N on some ).
Except for the Main Amp that have Complimentary Pair
check for possible burnt or open resistors , too
Jul 23, 2012 | Audio Players & Recorders
How to wire up some head lights and brake lights and also indercaters for a pit bike 50cc
you will have to install a lighting coil and a resistor the lighting coil will install behind the magneto and the resistor somewhere else the resistor is so the light will not surge and burn out or put out to much current and burn the lights out
Dec 02, 2011 | Pit Bike 125cc 4 Stroke Dirt Bike
Cycling Logo
64 people viewed this question
Top Quad Cycling Experts
shaun taylor
Eric Hidle
Level 1 Expert
Are you a Quad Cycling Expert? Answer questions, earn points and help others
