Question about Whirlpool LEQ9858P Electric Dryer
Kenmore 110 element wont shutoff
Element turns off and on while dial is in the off position
  • Whirlpool Master
  • 842 Answers
You have a ground short to the element, so either the element is broken and touching the case or you and a wire touching ground around the element. Either way unplug this unit and check for a short wire from the back of the unit. Safety first!!
Good Luck Gere
Posted on Apr 13, 2014
Cwsr ele 2406024 cv50
I'm inclined to think that the problem is in the electronics, in the circuit board, since it's acting so oddly. The timer dial shouldn't allow the heating element to energize when the door is open.
If the thermal fuse is blown, you should NOT get heat.
Aug 13, 2014 | Kenmore Dryers
I have a Kenmore Refrigerator (bottom freezer) model 596.62822200. I replaced the overload relay last week but now the freezer is frosting up and restricting the air flow to the frig section. I have, I...
First of all, check the defrost element, you can do this by test lead, Active to one end and Neutral to the other end of the element leads, the element should get hot if its ok, if not, replace it, to check the timer, locate the clock advance dial, note its position by way of marker pen, allow the unit to run for 3-6 hrs and check position regulary of the dial, it should advance clockwise1/4 of a turn every 3 hrs, if that runs ok then its the thermo fuse.
Anymore help, contact me at wgheaven@yahoo.com.au
Regards Russ....ps dont forget to vote and goodluck.
May 07, 2011 | Kenmore Freezers
I have a Kenmore refrigerator model number 25358685894. The defrost does not working. I have changed the heating element once about a year ago and thought it might be the same issue again. I notice when...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Kenmore Refrigerators
Can you tell me the order in which each componet of a gas furnace comes on to start the furance?
Yes there is a sequence:
0:00 Dial for fan/limit switch is at 70 deg position. Furnace is cold. I turn T-stat to 80 deg to start furnace.
1:00 Burner comes on and dial begins to move slowly up.
2:30 Dial at 140 deg and fan motor comes on. Dial never goes above 150 deg.
3:00 Burner turns off. Dial slowly moves back towards 90 deg.
4:45 Burner turns on and dial is at 110 deg.
4:50 Fan turns off with dial still at 110 deg.
5:30 Burner off. Dial at 120 deg.
6:15 Fan on. Dial at 140 deg. Burner is still off.
7:00 Burner on. Dial at 120 deg.
7:40 Burner off. Dial still at 120 deg.
8:30 Fan off with dial at 110 deg., and it quickly snaps back to the 80 deg. position.
8:30 plus, cycle continues.....
Mar 25, 2010 | Heating & Cooling
Kenmore dryer, heat element ALWAYS on
Good day,
Sounds as if the element inside the canister has shorted to the canister body. You will have to remove the element to check it. I'll include a tutorial on how.
If that doesn't resolve the issue, please reply back.. Whirlpool makes Kenmore dryers.
Jack
http://www.applianceaid.com/wp_element.html
P.S. Look close. It doesn't take much....
Feb 01, 2010 | Dryers
Element light staying on
sometimes this is a wireing problem....elements will heat but do they turn orange. if not then the stove may be hooked up like a 110volts..
Nov 04, 2009 | Office Equipment & Supplies
Kenmore dryer 110-86094110 wont heat. Heating
Hi, Check all the thernostats and the thermal fuse for continuity. They should all show a closed circuit. If any of them are open, it will need replaced. It is usuallly the thermostat on the top side of the element housing.
I hope this helps you. If I can assist you further, please let me know.
Vic
Jun 28, 2009 | Dryers
Kenmore gas dryer will not start model 110 72972109
check your motor relay under your control panel
Dec 23, 2008 | Kenmore 62802 Electric Dryer
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
Heating Element
your dryer is a 220 plug check the circuit breaker first
one 110 runs the heating element and the other 110 runs motor and dials
this is usually the cause of dryer malfunctions
heating elements are simple big mesh of curled metal wire like a toaster but more of it
it would take alot to knock out the heating element
check the dials too these could be sticking or worn dials you dont have to run dryer to check dials
Jun 27, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool LEQ9858P Electric Dryer Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
