Shakes when spinning
I know this is a daft question but can you rock the washer when it is empty just try from right hand corner then the left hand corner if you can move it back and forth the washer is not level and needs the legs under the washer adjusting to level it and stop it jumping about other then that if it is an old machine their are two shock absorbers in the machine that can leak and let it bounce around if one side has gone and not the other both are easy to fix once you know with one is the problem
SOURCE: my brand new amana washer shakes violently when spinning
try adjusting the feet on the bottom of the washer the floor may not be level to adjust the legs turn them with a wrench or if the lock nuts are not tight turn the legs clockwise as you look at the front of the machine till all four feet are sung on all 4 corners. This is the most common problem. hope this helps and thanks for using fix-ya
