Question about Canon PIXMA iP8500 InkJet Photo Printer
Ptinter start up
Switch on printer after the usual printer carriage positioning the fault light comes on and wont allow the printer to print it do'snt reset
    New Friend:
  • 75 Answers
Hi, Try reloading the software that came with the printer. Hope this helps. all the best.
Posted on Apr 12, 2014
5 Suggested Answers
SOURCE: canon mp730 ink cartridge carriage will not slide
I have the same problem. Anyone have any suggestions on what to do about it?
Posted on Jan 14, 2010
xptareq2000
  • 1447 Answers
SOURCE: Will not print. power light flashes green and
It goes to damage Ink absorber .Many ink absorb this pad.You must be reset it self or any workshop.if itself
1.Press power button and resume button realize resume button and press 3 time then go to power button.
Posted on Feb 12, 2010
jonniewalker
  • 1031 Answers
SOURCE: The cartridge carriage has jammed at the right
The carriage is probably stuck due to obstruction on its way ,which doesnt allow for free movement.examine the carriage rail for any obstruction ,if possible use a pressurised blower to blow the carriage rail.then Open the access to see if the print head will move to the center if not then Unplug the unit. Open the back door
check for a small black gear and spin the gear
and check where the print heads park.check the tray where the print head packs for any possible obstruction as u spin the gear. as the plate moves .after then Turn the unit back on. and try printing again
Posted on Mar 29, 2010
mercadoarvin
  • 384 Answers
SOURCE: have canon mp610 printer....wont print
Welcome to Fixya.
Here are the items that you can try to resolve this problem :
  • Uninstall the printer driver via (Windows) : Control Panel/Remove programs
  • Restart your computer
  • Download the updated driver from the below link. Choose your operating system then download until it's complete.
  • Launch the setup application after download and follow on-screen instructions
  • Restart computer
Canon Updated Driver
Thanks for using Fixya.
Posted on Jul 06, 2011
My ptinter has a serious problem , every time i turn on it the print head jerks so fast right side and backs again then it doesnt work again , it sound it gets crazy , can you help me please , and how...
Might be your printer inkjet technology one, just observe back side of carriage assm a film called encoder strip which is helping to carriage assm for positioning, might be mis positioned, become dirty(there is en number of stripes on encoder) or encoder reader sensor got dirty/not working results carriage moves left to right faster. check above said components..if found encoder faulty replace it..best of luck
Sep 10, 2011 | Office Equipment & Supplies
Hi I have HP 1210 All in one, and now it wont print. It tell me to check paper (none there, even inside..) and cardridge. And whats more important, when I turn it on, cardridge start riding from left to...
hi
1. 1 Switch off the printer and disconnect the powersupply. Allow any residual charge to fade away before putting your hands ormetal tools inside the chassis. 2. Step 2 Pin down the exact location of the jam. Thethree hot spots for a jam are the paper tray, anywhere between the feed trayand the print carriage, or between the print carriage and the output tray. 3. Step 3 Take off the front paper tray if the sheet gotstuck while it was still in the front area of the printer. If the sheet jammedhere, you should be able to see most of the paper. 4. Step 4 Pull on the sheet with both hands and steadypressure. Do not tug as you might rip the paper, leaving a chunk of it deeperin the machine. 5. Step 5 Open the back panel to reach paper jammedbetween the feed tray area and the print carriage of the all-in-one printer.Carefully remove the jammed paper from the machine. 6. Step 6 Use the carriage access door to reach a jamfurther inside the all-in-one printer. You may need to move the print carriageout of your way to clear the jam. 7. Step 7 Return any access panels to their closed andlocked positions. Plug your printer back in and flip the power switch.
Jun 14, 2011 | HP PSC 1210 All-In-One InkJet Printer
The carriage that holds the cartridges is stuck and when I open the front panel it wont move to the center as usual. I cannot print anything obviously
I have the same printer. Underneath the home position is a rubber "wiper" that cleans the underside of the cartridges. Ink buildups get dried out and can cause the carriage to stick. You may be able to " help" the carriage out of home position by GENTLY using the belt that runs from left to right to move the carriage to the left. U nderneath where the carriage previous sat you will see 2 rubber objects. Carefully wipe off any dried up ink. This is a messy job ! Good luck.
Dec 16, 2010 | HP DeskJet 845c Printer
Paper jammed
Hi Good day!!!
Here are some steps to remove paper jam
1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
Paper was jammed, it split. We went through back of HP Officejet7310 to remove paper. After we removed it three lights came on and kept coming on without stop constantly. Auto Answer, Exclamation, and...
FLOWO THE STEPS
1. 1
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2
Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3
Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4
Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5
6. Step 6
Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7
Apr 25, 2010 | HP PSC 1610v All-in-One Printer
It wont print
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 22, 2010 | Brother HL-2040 Laser Printer
Pixma MP610 will not start up. Was working OK. Just under 1 year old. Printer detected by computer, and print carriage lifts, but will not move. Ink in all the cartridges Front lights blinking alternately...
6A00 indicates a problem with the carriage lifting mechanism. Simply put there is beam kind of thing that the cartridge carriage assembly on which the print head rides on and something on it is obstructing the carriage assembly. The fix? Open the printhead cover and turn on the printer. You will see that the carriage arm is extended and tries to move back to the initial printing position but it can't. Just give it a little helping hand and bingo! The print head moves to the correct position. You will then have to clean up whatever is blocking its path. Usual culprits being ink, paperclips, tiny bits of popcorn(or anything else you prefer eating while printing!:)
Let me know if you need more help,
Sai.
Jan 03, 2010 | Canon Office Equipment & Supplies
Printer not printing
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear access door. Press in the tab on the left of the door, and then pull out the door. Figure 1: Remove the rear access door c00861145.jpg
  3. Gently pull the paper out of the rollers. If printing labels, make sure that a label did not detach from the label sheet while passing through the printer.
  4. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water.
  5. Rotate the rollers with your fingers to clean all the way around. Figure 2: Clean the paper rollers c00246512.jpg
  6. Allow the rollers to dry completely.
  7. Replace the rear access door. Align the pegs on the right side of the door, and then push the door forward until it snaps into place. Figure 3: Replace the rear access door c00861146.jpg
  8. Reconnect the power cord to the back of the product.
  9. Press the Power button (c01345237.gif ) to turn on the product.
  10. Load paper in the paper tray.
  11. Try the print job again.
  12. With the product turned on, open the product cover. The carriage might move to the center of the product. Allow it to move to that position.
    1. c01553685.gif 1 - Print carriage
    2. Without turning off the product, disconnect the power cord from the back of the product. CAUTION: In the following steps, you move parts by hand. If you do not unplug the power cord, there is a risk of an electrical shock.
    3. Disconnect the power cord from the wall outlet.
    4. Make sure the print cartridges are secure, locked into the carriage, and have not come loose.
    5. Check for any obstructions under or around the carriage that are preventing it from moving.
    6. Make sure the carriage can move freely across the width of the product by firmly pushing the carriage to the left, and then to the right. Clear any obstructions.
    7. Close the product cover.
    9. Reconnect the power cord to the wall outlet.
    10. Press the Power button (c01345237.gif ) to turn on the product.
Jan 11, 2009 | Office Equipment & Supplies
Printer problems
Two areas to check: (1) There's a encoder strip (sliver colored metal in the lexmark) the sits right behind the carriage assembly (where the cartridges are installed). It is slotted with "timing marks". This lets the machine know where the carriage assembly is at when parked in home position or starting to print a job. You can carefully clean this with water and a paper towel or cotton swab. I would recommend using some canned air to clean it after that since some of the paper fibers for the towel could be left behind. (2) The carriage rod that the carriage assembly (see above) rides on gets dirty and dry. Clean it with some water and paper towel then use a drop of light weight oil (3 in 1 or sewing machine oil) on it one either side of the carriage assembly. If these don't work, probably time for a new machine.
Jul 27, 2007 | Lexmark JetPrinter Z25 InkJet Color...
Okidata 320/420 printhead not printing aligned.
Clean the large silver rod that runs through the carriage. It is dirty and not allowing the carriage to move as freely as it should. Ideally it should be left dry. Also change the ribbon. The same motor drives the carriage and the ribbon. If it has a bind, the same thing can happen. Hope it helps Ed
May 18, 2007 | OKI MICROLINE 520 Matrix Printer
Canon PIXMA iP8500 InkJet Photo Printer Logo
old marine
old marine
