Question about Black & Decker Leaf Hog 12-AMP Electric Blower/Vacuum #BV4000
B&D Leaf Hog Electric will only start if sitting on flat surface
It may continue running when picked up, but might not. It appears to be related to some secret catch or electrical connection that I cannot locate.
  • bixbybreck Jul 09, 2009
    I have the manual and it doesn't mention anything about this issue. The how to regards how to change out the vacuum and blower attachments, which I already know how to do using the manual. It doesn't deal with the problem I am having, at least not directly.
    Thanks for the effort, but no banana.
5 Suggested Answers
bbreton
  • 437 Answers
SOURCE: when plugged in-the B/D leaf hog won't work.
Well Jim the unit may have a motor burned out or a switch has gone bad. We leave in a disposable society. Your blower is one that is not worth taking to a shop to be repaired because the cost of repairs would exceed the cost of a new unit. So you may have to bite the bullet and go out and purchase a new one.
Good Day.
Posted on Oct 14, 2009
SOURCE: My motor brushes at end
Try Platt Electrical supply - 800-257-5288 (Platt.com) BLACK & DECKER #89754-01 REPLACEMENT BRUSH. It seems the entire motor head was manufactured by DeWalt and is now obsolete. I don't know if these brushes will fit, but someone there may help.
Good Luck!
Posted on Aug 31, 2011
citizensirhc
  • 19 Answers
SOURCE: My Black & Decker Leafblower Leaf Hog BV4000 type 2 quit running suddenly while using. It had run about an hour, was not warm to the touch and is 2 years old. Is thuis a common problem and what might
I have this unit. Mine stopped working today after being warm on the handle the last few uses. I opened the unit up (torx 15) and smelled, then found that a fused wire coming off the motor had burned/melted/separated at a plastic plug right inside the handle. I'm not sure if it had anything to do with it, but in this same compartment of the handle there was an anti-theft strip floating around. I called BandD and they said the BV4000 type ONE has been recalled. http://www.cpsc.gov/cpscpub/prerel/prhtml07/07005.html
But not the type 2. Even though the failure described for the type 1 is exactly what I found in the type 2.
Posted on Dec 01, 2011
  • 6468 Answers
SOURCE: electric b&d leaf blower will not turn on
open the covers while unplugged and see if a wire came unplugged
Posted on Mar 24, 2012
Same thing here after i did my neigbours yard!!!! i found out it was the switch the latch that moves it wont I am trying to work a away round it hope this helps
Nov 18, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
My motor brushes at end of life for a Black and Decker electric leaf blower. Where can I get them? Black and Decker leaf hog, model BV400 type 4, Cinderson 90510850 motor. Black and Decker site no help...
Good Luck!
Aug 31, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
Where do i switch theLEAF HOG FROM VACUUM TO BLOWER
Remove vaccuum tube. Allow the access door for the vacuum tube to shut all the way. Attatch the blower tube where you had the collection back for the vaccuum attatched. That is it.
Feb 01, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
Will start but wont run.runs only a second
It is possible that the ON/OFF switch is bad or the wires that connect to the switch are loose and are not making permanent contact. Check the switch.
Dec 04, 2010 | Black & Decker Leaf Hog 12-AMP Electric...
Need carbon brush replacments
google for sources. In the 80's i was employed by a co that probuced brushes according to specs. We received them in bags, or envelopes, etc. If you cannot find them through the orig. mfgr., send the remaining brush or the holder, with as much of the brush as is remaining for proper dim. estimate and brush composition. some brushes have the composition of dry charcoal. while some such as "EGO" can substitute for a very soft pencil.
Nov 26, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
Where can I buy a new vacuum bag
you can go to there web sit and order that way or you can check it on there web page to find a dealer closed to you. search black & decker
Oct 13, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
Zipper is really stuck
sometimes dirt and debree can get stuck in there, try saturating it with a strong penetrating oil like PB Blaster, available at your local auto parts store, and let it soak in for about an hour and use a pair of pliers to get a good grip.
Nov 23, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Black & Decker Leaf Hog 12-AMP Electric Blower/Vacuum #BV4000 Logo
54 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
