Question about Vision Fitness Exercise & Fitness
How to set up and maintain user information on Vision Fitness TF20 classic treadmill?
vpaaf
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
Posted on May 01, 2009
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
maxtreadmill
  • 832 Answers
SOURCE: Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Posted on Mar 01, 2010
  • 9 Answers
SOURCE: I have a vision fitness T9450 treadmill. My wife
first thing to do is to enter the calibration mode. First remove and replace the safety key. Press and hold the elevation up and the speed down buttons until the machines beeps at you 3 times consecutively. You should also see either the model "9450" or the software code which varies from machine to machine. You should now see one of two things - "eng1" may be displayed in which case just use the elevation keys to get to "eng4" and hold enter for 3 seconds - then press start - this will calibrate your machine and confirm if there is any speed reading issues.
If your machine displays more numbers as it would on the deluxe and premier consoles of this brand then you should see the model of your treadmill at the top left. hold enter from here until "eng1" appears and the perform the steps as above. If the speed is not calculating properly during the calibration the magnet or the speed sensor may have been moved or the magnet could have gone bad - usually slowing to one speed and not changing is the sign of a bad speed sensor. If the control board had any irregular voltage it would shut down as a safety precaution.
Posted on Aug 05, 2010
guru_fixya
  • 944 Answers
SOURCE: Vision Fitness T9450 Treadmill error code "E4."
E4 means
- Elevation parameters out of range
- Recalibrate it
If you want to calibrate it see the manual page no 5.
Click here to download the manual
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
What does error code R5232 Failed mean on Vision Fitness T9600HRT treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 04, 2016 | Vision Fitness Exercise & Fitness
How to fix error E9 on vision fitness T 9200 treadmill
If you wish to get some details; check the site linked here. Pull up older posts treadmill . Surf the site with patience.
Jan 10, 2016 | Vision Fitness T9200 Treadmill
M tf40 vision fitness treadmill wont change incline or speed only just got today
Please RUN the software calibration for easy diagnose, troubleshooting and fix it.
see the diagram attached.
God bless you
Dec 18, 2012 | Vision Fitness TF40 Classic Folding...
Vision fitness manual for t9200
see this place and download the instr.manual www.iconservice.com or www. fitness.manualsonline.com
God bless you
Jun 27, 2012 | Dmm Vision Fitness T9500 Treadmill
ERROR CODE E9 VISION FITNESS TREADMILL T9200
If you wish to get some details; check the site linked here. Pull up older posts treadmill . http://electro-medical.blogspot.com/ Surf the site with patience.
May 08, 2012 | Vision Fitness T9200 Premier Treadmill
I have a vision fitness treadmill T9250 and now the console display isn't working properly. Some of the
Dear Sir:
Please see the diagram attached from REED switch, adjust, clean, and tight the connector wires very well.
2) change the batteries by new ones, use the best.clean the contact batteries.
3) tight the ribbon cable from keypad .+ tight the connector from display board vs lower board.
4) after you fix it RUN THE sofware calibration for diagnose, troubleshooting, See my personal tips for help
sincerely. God bless you
Apr 30, 2012 | Vision Fitness T9250 Deluxe Folding...
I have a vision fitness treadmill. I turn on the treadmill and it starts at P1 and then it automatically goes through all the programs and sppeds until it gets to 10 miph. I have tried unplugging it. I...
It sound like either the function pad ( more likely the problem ) or the upper electronics have failed. You will need to call Vision Fitness customer support @ 1-800-335-4348
Jun 11, 2010 | Vision Fitness T9550 Folding Treadmill
Exercise & Fitness Logo
Top Vision Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
rattack1511
Level 1 Expert
ray gallant
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
