Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Drive belt routing
According to the manual routing the belt goes from the engine to the pulley assembly to the trans. but it also has avariable speed pulley beside it with a idle pulley in front of it the trans pulley is equipped for one belt the varible pulley is equipped for two the diagram in the book is showwing 2nd belt going to all three pulleys in reality the pulley at the transmission would have to be equiped for two belt but it is not .
    Guru:
  • 145 Answers
Parts and Diagrams for Husqvarna LT 18542 954571748 2003 11
OH BOY, lots of information. one belt runs the DRIVE LINE. one belt will run the CUTTING DECK. check out the link.Hope this helps :)
Posted on Apr 12, 2014
  • 37 Answers
SOURCE: Drive belt comes off the rear pulley.
Hi, this is a easy solution. on your drive pulley, there should be three belt keepers to keep the belt from coming off. ( belt keeper is a 1/4" dia. rod that goes over the pulley)
Posted on Nov 22, 2008
SOURCE: I need to replace the drive belt to the transmission
On the side of the deck there is a metal rod running along between the tires. Push it back then pull it forward when it releases from the catch it will move the pulley and release the belt. Hope you can figure it out I believe it is on the side with the brake pedal.
Posted on Apr 04, 2009
  • 148 Answers
SOURCE: i need to know the route of the drive belt around the pulley syst
go to www.searspartsdirect.com and you can look up the diagram on their website.
Also you can download a free owners manual at www.managemyhome.com.
Posted on Jul 22, 2009
  • 138 Answers
SOURCE: Repair or replace trans axle pulley on a sears
since the parts illustration doesn't show a woodruff key, i would guess that the input shaft of the transaxle has a flat area that matches up to a flat on the pulley - if it's just spinning, that would mean either the flat has been worn out, the center of the pulley has broken the weld, or the transaxle has something broken internally - the pulley is held on with a snap ring and thrust washer, remove those and the pulley should slide off the shaft - pulley part no. is 184787
Posted on Aug 25, 2009
Testimonial: "Its what I figured.. Now the trick is to how to removethepulley. The clearance between the frame and the shaft is smaller than the width of the pulley"
  • 6 Answers
SOURCE: drive belt is too loose, already replaced belt and
I had the same problem with my Craftsman Lawn Tractor. The Drive Belt (which is not adjustable) is only engaged when the Brake Pedal is released (the Brake Pedal is located on the left side of the tractor, near the foot rest on my Tractor).
The Symptoms: My Tractor lacked driving power, and would not go up an incline, but the mower deck was powerful and working fine, even though the Tractor seemed to lack power and moved slower than usual, and would not travel up an incline.
I too, changed the Drive Belt, which initially seemed to help somewhat for a very short period of time, and then the same, lack of power problem, re-appeared again. The belt was not the problem, but only seemed to work somewhat due to the rougher texture of the belt's surface against the pulleys.
I also changed the Plastic Clutch Pulleys that engage the Drive Belt, thinking that they may have been worn down to a point that the Drive Belt could not fully engage with these Pulleys. No Luck.
NO ONE, NOT EVEN SEARS ON-LINE REPAIR ADVICE CENTER HAD A SOLUTION. THIS WAS VERY FRUSTRATING INDEED.
There had to be a solution: After much investigation, I eventually discovered the problem, which actually was easy to solve, and I would like to share this simple solution with others facing this same Frustrating Problem.
The Brake Pedal, when released, causes the Drive Belt Clutch Pulleys to move, and thus Tighten the Drive Belt. When you look under the Tractor, there is a Protective Metal Plate mounted to the Bottom of the Main Tractor Frame which covers the Brake Pedal Shaft and attached Mechanisms. Over time, Grass Builds up in between the Protective Metal Plate and the Tractor's Main Frame Deck, creating a very narrow space between these two pieces of metal.
This area is very difficult to get at, and almost impossible to clean out. Over time, Grass Clippings accumulate in this hidden area, and harden to an almost rock hard clump.
These Hardened Clippings accumulated between the Brake Pedal Mechanism and its fully released metal stop position. Thus, preventing the Brake Pedal Mechanism from moving to its fully engaged position.
I used a long screw driver to break up the compacted grass clippings, and an Air Compressor Blow Gun to break up the packed grass and blow the area clear. It takes awhile to do this cleanup, and is a bit messy, so do it outside, but be patient, and be sure to clean out all the grass that is lodged in this hidden area.
What was happening was that the Packed Grass was so dense that the Brake Pedal could not Fully Release, thus only Partially Engaging the Clutch Pulleys and the Drive Belt, hence the appearance of a loose Drive Belt even when the Brake Pedal was released.
Once the Packed Grass Debris was cleaned out, you will immediately notice the Drive Belt being tighter than it was previously when the Brake Pedal is released, and when you test drive the Tractor you'll find that everything works perfectly, like it was brand new.
Good Luck...
Rayko
Posted on Nov 15, 2010
Belt deck assembly
Are you still looking for that belt diagram..? Is this for the motor to trans (which is pretty simple) or the belt for the deck..? Couldn't find a diagram so hope my drawing comes out right.. This is for the "deck belt" routing..!!!
Back of mower is up here on the top..
Left pulley (O\ /O) Right pulley
.......Tension \ \@/ / Pulley
.............Engine \ @ / Pulley
Front of mower here, where the motor is..
Main thing is, you take the belt from BETWEEN the right & left pulleys, pull it down and around the tension pulley..
Hope this helps.. Think I have the same Sentinel..
Jun 28, 2013 | Garden
Need a diagram for the drive belt on a wheel horse c 100 8 speed
i don't have a diagram but the belt goes around the trans pulley and around the engine pulley and the pulley from the clutch pedal goes under the top section of the belt pulling up in the center hope that helps you
Aug 18, 2012 | Garden
How do i remove the fan to replace the serpentine belt
Astro, Safari 1997-2005
Accessory Drive Belts
Print
Belt Tension Inspection
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. All worn or damaged drive belts should be replaced immediately.
Drive Belt Routings
Fig. Accessory serpentine belt routing-4.3L engine
Fig. Accessory serpentine belt routing-4.3L engines
Removal & Installation
Belt replacement is a relatively simple matter rotating the tensioner off the belt (to relieve tension) and holding the tensioner in this position as the belt is slipped from its pulley. The tensioner arm contains a machined receiver for a 3 / 8 in. driver from a ratchet or breaker bar.
  1. Before you begin, visually confirm the belt routing to the engine compartment label (if present) or to the appropriate diagram in this section (if the label is not present). If you cannot make a match (perhaps it is not the original motor for this van), scribble your own diagram before proceeding.
  2. Disconnect the negative battery cable for safety.
  3. Install the appropriate sized breaker bar, wrench, or socket to the tensioner arm or pulley, as applicable.
  4. Rotate the tensioner to the left (counterclockwise) and slip the belt from the tensioner pulley.
  5. Once the belt is free from the tensioner, CAREFULLY rotate the tensioner back into position. DO NOT allow the tensioner to suddenly snap into place or damage could occur to the assembly.
  6. Slip the belt from the remaining pulleys (this can get difficult is there is little room between the radiator/fan assembly and the accessory pulleys. Work slowly and be patient.
  7. Once the belt is free, remove it from the engine compartment.
    Fig. On this 4.3L engine, a large wrench (16mm) was used to pivot the belt tensioner and free the belt
To install:
  1. Route the belt over all the pulleys except the water pump and/or the tensioner. Refer to the routing illustration that you identified as a match before beginning.
  2. Rotate the tensioner pulley to the left (counterclockwise) and hold it while you finish slipping the belt into position. Slowly allow the tensioner into contact with the belt.
  3. Check to see if the correct V-groove tracking is around each pulley.
    WARNING Improper V-groove tracking will cause the belt to fail in a short period of time.
  4. Connect the negative battery cable.
Jul 13, 2012 | 1998 Chevrolet Astro
What size is the engine on a 2002 dodge durango R/T? Need to change the surpentine belt.
4.7L or 5.9L and it should be listed on a sticker somewhere in the engine compartment.
Drive Belt Removal & Installation 3.7L, & 4.7L Engines To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Disconnect negative battery cable.
  3. Rotate tensioner until it stops.
  4. Remove belt and slowly rotate the tensioner back to its free position.
To Install:
  1. Install new belt and route around all pulleys except idler pulley.
  2. Rotate the tensioner arm until it stops.
  3. Route the belt around the idler pulley and slowly let the tensioner rotate back to its free position.
3.9L, 5.2L, & 5.9L Engines To Remove:
NOTE: Check the belt routing label, located in the engine compartment, for the most current belt routing schematic.
CAUTION
Do not attempt to check tension with a belt tension gauge on vehicles equipped with an automatic belt tensioner.
  2. Attach a socket wrench to the pulley mounting bolt of the automatic belt tensioner and rotate the tensioner assembly clockwise until tension is relieved.
  3. Remove or disconnect the following:
    • Belt from idler pulley
    • Belt from vehicle
To Install:
  1. Position drive belt over all pulleys except idler pulley.
  2. Attach a socket wrench to automatic belt tensioner and rotate the tensioner assembly clockwise.
  3. Install belt over idler pulley, allow tensioner to rotate back into place, and remove the wrench.
Sep 03, 2010 | 2002 Dodge Durango
The belt dry rotted and flew off without me being able to remove it myself, now I need to know how to install the new drive belt.
To install the drive belt you will have to remove the drive belt first.
Follow the procedure: ---
Park the tractor on a level surface. Set the parking brake and remove the key from the ignition. Study the belt replacement guide decal located underneath the left foot board for proper belt routing instructions.
Remove the mowing deck by first moving the attachment clutch lever to the disengaged position (toward you). Move the attachment lift lever all the way forward to lower the mower housing to its down position.
Crawl beneath the tractor and roll the drive belt off engine pulley (it hangs directly beneath the engine). Remove small retainer clip that holds the clutch spring to the pulley bolt located at the center of the mowing deck. Remove the large retainer springs (two of them), then slide the belt collar away from the mower housing and off the housing bracket.
Disconnect the anti-sway bar rods from the chassis brackets by removing the retaining cotter pins. Disconnect front links from the mower deck by removing retaining cotter pins. Disconnect the suspension arms from the rear mower deck brackets by removing the two cotter pins.
Move the attachment lift lever all the way to the forward position to raise the mower suspension arms to the full up position. Slide the mower deck out from beneath the tractor.
Crawl beneath the tractor and roll the drive belt off of the stationary idler pulley and the clutching idler pulley. They are both located immediately adjacent to the engine pulley. Be sure the belt is already away from the engine pulley, as well.
Push the drive belt slack toward the rear of tractor. Remove the drive belt from the Trans axle pulley by taking it over the trans axle pulley while compressing the movable belt keepers surrounding it. Remove the old belt from the tractor by pushing it clear of the center span keeper (located beneath the Trans axle pulley).
Install a new drive belt by following the reverse of the instructions for removal. Test the tractor and mower for normal operation.
 Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 19, 2010 | Garden
How to replace a serpentine belt in a ford winstars
e
Fig. Accessory drive belt routing-3.0L engine
Fig. Accessory serpentine belt routing-3.0L engine
Fig. Accessory serpentine belt routing-3.8L engine
Removal and Installation
Fig. Drive belt tensioner wear indicator marks
Fig. Place a wrench on the drive belt tensioner bolt and rotate the assembly clockwise to relieve belt tension
Using a 15mm wrench attached to the drive belt tensioner pulley, rotate the tensioner clockwise to release the tension. Remove the drive belt from the pulley. When installing the new drive belt, ensure that the drive belt is routed correctly and note the position of the indicator mark on the tensioner.
Hope heled with this; remember rated this help. Good luck.
Nov 12, 2009 | 2000 Ford Windstar
Riding Mower Variable Speed Pulley Locked Up. How to remove belts
ya it can be freed up with some W-D40 if you pah the cluch down then try to get the belt off i can get you a new pulley let me know
Oct 15, 2009 | Mtd Garden
Replace serpetine belt manual
normally there is a diagram on the shroud of the radiator
Aug 19, 2009 | 1998 Dodge Ram 1500 4WD
Drive belt tensioner pulley bearing failed
go to parts tree .com. put your model# and make in then click deck assembly.they should have what you need .hope this helps
Jul 21, 2009 | Garden
Variable speed belt issue
Get your model and serial numbers from under the seat. Then go to the MTD website where you can download the owners manual which should show the belt diagram.
May 24, 2009 | Mtd Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
141 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
