Question about Denon Audio Players & Recorders
I needto know how to reset denon 275 r receiver
Receiver shut down
3 Suggested Answers
  • 4234 Answers
SOURCE: Denon receiver follow up
A sound spike should not heat up the unit enough to shut it down. There is another problem. What is the time frame for the shutdown? Is it only after the unit has been running for a while?
Dan
Posted on Apr 18, 2008
jt085
SOURCE: Denon AVR-1803 keeps shutting down
I had a similar problem with my Denon receiver... I thought there might be some issue with the power source, which was a (supposedly good quality, surge protected) power strip that it was sharing with a lot of other gear.
I unplugged it from the power strip, and ran an extension cord from the next room and plugged it into that.
The switching off & on seems to have stopped.
Posted on May 18, 2012
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/90-receivers-amps-processors/1386123-help-denon-avr-1603-shuts-down.html
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
Denon AVR-1513
disconnect speakers then try again if still shutting down you will have bad outputs.
Aug 26, 2014 | Denon Audio Players & Recorders
Denon avr-1612 keeps shutting off and on
You have an output problem, check outputs for short
Apr 07, 2014 | Denon AVR-1612 5.1 Channels Receiver
How do i connect my sonance 275 SE amplifier to my denon receiver
The answer depends on if you have external speaker level volume controls (usually in-wall type) between the amp and the speakers.
If yes, hook the RCA cables from the 275 inputs to the Denon's Tape Output. With speaker level volume controls set to max, use the level controls on the front of the 275 to set max level desired in each room.
If no, then you must use a line level volume control between the Tape Output and the 275.
Jun 22, 2013 | Sonance Audio Players & Recorders
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Aug 20, 2009 | Denon AVR-1908
Denon AVR588 receiver auto shuts off
You may reset the unit to factory setting. Hold buttons "Speaker" and "SpeakerB"and turn on power switch. Release buttons after 5 seconds. You will loose all your setting and need to do configuration again.
Jul 07, 2009 | Denon AVR588 Receiver
check your speaker wires make sure none are touching each other this will cause a short and shut the reciever down
Mar 17, 2009 | Denon AVR-1803 Receiver
Denon avr 885 it automaticallyshuts off when i try to power it up
Its possible that the Receiver is going into protection mode and possible some speaker cable might have touched the body or with each other.
Remove all inputs and outputs and then restart the receiver. If it starts then you are lucky. Connect all cable and wiring properly and ensure that they do not touch each other. You might have to reset the microprocessor also.
If the problem persist then let me know to further the trobleshooting.
Please do rate this solution and thanks for using FixYa.
Mar 06, 2009 | Denon AVR-885 Receiver
Dan
Apr 05, 2008 | Denon AVR-3805 Receiver
20 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
