Question about ARB Portable Twin Compressor CKMTP12
My ckmpt12 arb compressor will not work
One of the 40A fuse did melt. After replacing the fuse, powering and turning switch on, only the fan works but not the two compressors.
Heater fan does not get power.
There are two fuses for the blower. One for the relay coil and the other for the relay power. One is a 5a in the interior fuse box. The other is a 40a in the engine compartment fuse box.
Feb 07, 2015 | 1996 Ford Taurus
Why front AC blower won't operate in my Kia carnival
The switch may have melted becasue the fan motor went out. Replace fan motor. Check fuse too.
Aug 10, 2014 | Vehicle Parts & Accessories
Fridge works intermittently
Some Of These Fridge Freezers If You Open The Door For The Freezer There Is A Switch Between The Fridge And Freezer Door Mine Done The Same And I Had To Replace That Switch It Turns The Fan On When Door Is Closed And Off When Open
Nov 04, 2013 | Refrigerators
99 kia sportage will not start and wipers, power windows,and heater fan don't work either
In the engine compartment fuse/relay box, check the 40A IGN fuse. If it is blown, the items you mentioned will not work. Replacing the fuse should clear up the trouble and you'll be able to start
Oct 23, 2012 | 1999 Kia Sportage
Cooling fan not working, van overheats
Try the 40A cooling fan fuse link.
Nov 05, 2010 | 1998 Ford Escort
AMANA---MODEL # ARB 1917CC-22.8 CF..\r\nBOTTOM
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 07, 2010 | Refrigerators
Fan blower fuse location on a ford f150 year 2000
FUSE #105 40A** Climate Control Front Blower, THIS FUSE IS LOCATED IN THE UNDERHOOD POWER DISTRIBUTIOPN BOX
Oct 14, 2009 | 2000 Ford F150 Flareside SuperCab
Compressor no longer coming on (Newair AD-40A)
You can take out the switch and do a continuity test on the switch in the on poisiton. You can do this witha VOC meter. and and if the switch has a High resistence then you can assume the switch is the problem and replace that. If the switch works out, it would be wise to assume the compressor has shot out.
Thanks for using Fixya.com!
Aug 23, 2009 | NewAir AD-40A Dehumidifier
Heater stopped working today. Rear still working but not alot.
2005 Chrysler T&C Van. My front blower also stopped working overnight. Rear blower works fine. I swapped the 40A fuse in the underhood fuse box with the 40A fuse for the power seats since I don't have power seats. No help. I then swapped the front blower relay with the spare relay in the same box. No help. I'm wondering if there is a reset button for the blower and if so where it may be. Any hint or help with the blower would definiely be appreciated. Thanks
Jan 02, 2009 | 2005 Chrysler Town & Country
ARB Portable Twin Compressor CKMTP12 Logo
Top ARB Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an ARB Air Tool and Compressor Expert? Answer questions, earn points and help others
