Question about Sony Playstation 3 (PS3) Console
I dont have extra hdmi connections so i use av multi with the red/blue/green(no red/white on cable) conections with an optical cable- which will not play sound. What am i missing?
I tried adjusting the sound settings on ps3- nothing
I honestly thought it would have the white red and yellow as well. If it does try plugging in the yellow along with the ones you already have. If not then try plugging the green into the yellow hole.
Posted on Apr 13, 2014
SOURCE: ps3 hdmi-av
i currently have the exact same problem...i always play HDMI but i went home from college for thanksgiving and wanted to play on a regular AV jack TV, hooked up, and have no picture whatsoever...and i think it's because of the settings on the PS3 since it's set to send out an HD signal...Well i found this straight from Playstation3.com, on the support/troubleshooting section
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution."
Hope it helps =)
Posted on Nov 22, 2007
SOURCE: ps3 Surround sound
ttttttttttttttttttttttttttttttt
Posted on Dec 29, 2007
  • 7 Answers
SOURCE: no sound from ps3 to home cinema via an optical cable
If you have not run the set up you will need to, however I'm guessing you did because you would have had to make some changes to the settings to get the image to come up on the screen but without being physically at your location I can just guess.
In order to view your PS3 in full 1080p you need the HDMI cable which you already have. If you have not gone into your video settings then you are not viewing via the HDMI cable and you will need to to get things working right.
In order to view via the HDMI cable you would have had to had both the standard PS3 interface cable that comes in the box (the one that goes from the PS3 to your tv with the composite video (yellow) and the left and right audio (red and white) and the HDMI cable pluged into your PS3 and your tv at the same time. then you turn on the PS3 making sure your TV was set to whatever imput the composite and left/right audio is pluged into (typically VIDEO 1,2,3 ect.) and enter the menu, go to the settings and then down to your display settings and change it to HDMI, the image should then leave the screen (because it switched to HDMI) you will need to have your TV remote handy for this because you will need to switch sources on your tv to HDMI 1,2,3 ect, which ever one you have it pluged into. When you have switched to the right HDMI imput there should be an on the screen that is counting down and asking you if you want to accept the changes. Select yes and Move on through the settings selecting the maximum resolution your tv is capeable of
720, 1080i, 1080p) which can be found on the box the tv came in or somewhere on the tv or manual. While running this settings change it should ask you the audio source you are using make sure you select Digital Optical and that it is pluged in to you PS3 and your reciever. Once this is all done you can remeove the standard PS3 hook up that came with the box and put it away you wont need it any more, unless you move the PS3 around and the tv you move it to does not have HDMI in which case you will have to change the settings before you move it back to the standard cable or you will not be able to see it displayed on the tv sceen you move to and it will be impossible to run the settings.
If you have already done that and just want to verify that your source for audio originating from the PS3 is digital optical you can check that in the same settings menu under audio settings. Then make sure the reciver is on and set to whatever imput you have the cable pluged into and you should be good to go.
If all that I have described has been done already then the audio cable could be bad or the problem lies internaly with the PS3 or the reciever.
Good Luck hope this helps
Posted on Oct 04, 2008
localwonder
  • 6784 Answers
SOURCE: blue rays not playing and screen says no signal
This is blue ray lens failure. this optical Assembly has two separate reading lenses. there is one designated for Cd audio and CD_ROM reading and, the other is blue ray compatible. the blue ray lens in inoperable at this point. you will need to replace this lens assembly.
Posted on May 27, 2009
SOURCE: PS3 Blue Ray White lines on left side of TV
I have the same TV, and a Sony BluRay player (not a PS3). I have the same problem.
I found it only does this when playing back 24p disks. My player has an option to disable 24p output to the HDMI, and it "fixes" the problem.
Not really a fix, but a workaround.
Not sure whether it is the TV or player, and sometimes I have fixed it by turning the tv off and on multiple times.
I am going to test the player on another monitor and see if it does the same thing. If so, the player is going back to the store.
Posted on Aug 03, 2009
I have an older onkyo 1994 or 1995 receiver dolby pro logic with the amplifier and 6 disk changer wnd the system is clear as could be in cd mode. my problem is Ihave my xbox hooked up to the tv with hdmi...
No no no!
# 1. You need to connect all your components to your TV via an HDMI cable. For true HD and digital sound this is needed. Your TV (if its an HD TV) should have 3 or 4 HDMI inputs. So your Xbox/PS3 should be connected via HDMI cable. Your HD sat or cable box should also be connected with an HDMI cable. Same for your Blu Ray player.
#2. Now that your components are connect in a way which will enable you to see their media in either 720p, 1080i or 1080p your ready to get the Digital sound to your speakers. On the back of your TV you should (again on most all HD tv's) have a digital audio (optical) out. You need to purchase a digital (optical) audio cable and plug one end into your tv's digital audio out jack. Then plug the other end into your audio receivers digital audio in jack. You may have to go into your receivers menu to select or enable the digital/optical input. Then you should be rocking and rolling with true digital DTS, Pro Logic, Pro Logic 2 in either 5.1 or 7.1...
Think of your TV as the hub. Connect all the components with HDMI cables. And then your TV to your receiver with a digital/optical cable. It's that simple.
Never never use the red and white cables for audio. They were designed for 2 channel stereo sound. They won't deliver 5.1 or 7.1 digital sound.
Also... Don't ever hook up any component using the old "yellow" video cable if you want picture quality better than 480i resolution. They won't do HD period.
Here is a list of the popular video cables and they highest resolution.
Yellow video cables - 480i resolution
S video (super video) cable - 480p
Component video cables (red/blue/green) - up to 720p
HIgh definition multimedia interface HDMI - up to 1080p (full HD) and digital sound.
Hope this helps...
Nov 03, 2012 | Onkyo Audio Players & Recorders
Wiring color code for lcd screen
AV VIDEO CABLEYellow- Video Red- Right sound R White- Left Sound L
Component Cables RED ORANGE- video BLUE- video GREEN-video RED- audio R WHITE-audio L
HDMI provides both video and audio all in one.
Optical out Audio Audio format to surround sound. Better sound quakl
Hope this helps
Jul 20, 2011 | Televison & Video
Hi Have Vizio Flat Screen and a Denon 3803 receiver. The Tv a Vizio 65 Inch flat screen was here. Out of the wall is a power cord and red,blue,green monster cable. Red and Blue is audio and green video I...
Red, Green and Blue cables together typically denotes a component video signal - an Analog, High Definition transportation for video. This cable does not carry audio, you need another cable to hook up audio between the DVR and receiver. You can use either an RCA stereo cable (red and white), optical-audio, HDMI, or a whole plethora of other audio cables. I would recommend optical or HDMI to get the most out of your system.
Jul 16, 2010 | Denon AVR-3803 Receiver
I wanted to connect hp dv 4 1275 laptop with sanyo tv with hdmi and 3 rca .but its not working .tried everything din work.
You MUST install HDM IDrivers for your Video Card & MotherBoard. You can only use HDMI, OR Component, but NOT BOTH. Sometimes HDMI, requires an AUDIO OUT Cable, this is the Red & White, AV Stereo input.
OR you use COMPOSITE which is YELLOW, Video, now AUDIO, is Red & White.
COMPONENT, you use, Red, Blue, Green, (ALL VIDEO) PLUS you need the Stereo AV AUDIO too, Red & White.
HDMI, should supply BOTH, but as related sometimes you need the Audio red & White AV, inputs & Outputs.
ALL Cables go color to color.
h10025.www1.hp.com/ewfrf/wc/document?..
Resolving issues,with HDMI. above.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&dlc=en&cc=us&os=2100&product=3860476
DRIVERS link above.
Apr 11, 2010 | Computers & Internet
I Have just bought this reviever (Yamaha Rx-v365)and im just trying to work out how to best connect all my devises. I have Tivo, Lg DVD player with both yellow, red white cables and blue green red cable...
Hi, firstly some terminology:
yellow cable - video composite (worst quality)
white/red - stereo analog audio
blue/green/red - video component (second best quality after HDMI)
You are correct that RX-V365 doesn't do audio over HDMI. Moreover it also doesn't do any video processing, which means composite video input will go only to composite video output (and not to component); compoment input only to component output and HDMI input only to HDMI output.
If you have more devices of same video output (in your example the component blue/green/red), you can connect them to TV via the receiver. But if only one device of same video output, you can connect it directly to TV. There is no reason to go through your receiver for video.
For audio, you can use either the analog stereo white/red cables (rx365 has 5 such inputs) or better use digital SPDIF connection, which is slightly better quality and more importantly supports 5.1 sound. There are 2 types - coaxial (orange RCA plug, can use basic rca cable) and optical (square black connector). Receiver has 1x coax spdif input and 2x optical spdif inputs. Look at your other equipment to decide which cable to use.
For the analog audio inputs, I think you can assign it either to composite video or component video. So for DVD audio white/red plugs, you can choose if either Video composite yellow plug named DVD will be used, or component blue/green/red named DVD will be used.
Jan 03, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Connected to a sat. we have no sound when we put the T.V. to H.D
What cabling are you using? component? (blue red and green) or HDMI? if you are using component then make sure you also plug the red and white RCA cables in the "audio in" inputs. People commonly think that the component cables do it all but they only carry a video signal. If you are running HDMI through an AV reciever you may need to run an optical cable as well as most AV recievers (unless you buy top of the range) can only switch HDMI video but not sound.
Jul 05, 2009 | Televison & Video
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
Connecting ps3 to cinema system
There is no substitute for HDMI. However, the 'digital in' cable connection that you want to use is still digital and will sound almost exactly the same. The differences are barely noticeable to the human ear. Here is a list for you to see the pecking order of each type of connection.
Audio connections from best to least go in this order:
1. HDMI (digital)
2. Fiber optic (digital)
3. Coax - Digital (digital) <--- The one you want to use.
4. Component (analog)
5. RCA/AV (analog)
Video connections from best to least go in this order:
1. HDMI (full HD digital)
2. Component (Blue, green, red, white, red - HD analog)
3. S-Video
4. RCA/AV (Yellow, white, red)
Good luck!!
Sep 28, 2008 | Sony Playstation 3 (PS3) Console
Denon AVR587 Setup
red/white/yellow = composite
red/green/blue= component video cables + audio cables needed
the red/white= stereo audio
the denon 587 has 2 optical (toslink) inputs and 2 digital coax. These are surround sound cables basically, it's the only way to get true 5.1 dolby or dts.
connect cable box, and the samsung to the sony using hdmi. then connect the cable box and the samsung to the denon receiver with optical cable. And that's it.
Jan 15, 2008 | Denon AVR588 Receiver
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
