Question about Grundig GU19WDT 19 in. LCD TV
Recording problem between dvd vcr recorder combi and hd lcd tv
I have just just purchased a grundig 19'' widescreen hd ready idtv lcd (gu19wdv4) to work with my bush dvd / vcr recorder combi (dvhrs02). However i can get both a dvd and a tape to play but cannot record without problems. I put the bush machine to av1 and attempt to record from a freeview channel and get the sound but no visual only a message saying no signal. If i swap the scart on the bush i get picture but no sound. Is this a compatibility issue between the machines or am i doing something wrong? If it is a compatibilty issue i will return the tv but what tv's will work with the bush machine?
  • Grundig Master
  • 3,866 Answers
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 17, 2009
My tv is showing status database empty. What do I need to do?
Main system control memory IC fault. Check and replace it. Contact any service technician.
Jul 09, 2016 | Toshiba 19DV616DB 19-inch Widescreen HD...
I am considering purchasing a Funai Full HD UpConvert DVD Recorder/VCR Combo. I have a HD Phillips TV with HDMI connections. I do not have cable - just use over the air TV. How do I connect the Fun
Purchase a DVD recorder/player that has a HDMI cable connection and use the connections on the TV so you'll get a hi def picture. RF will NOT give you a Hi Definition picture even if it's up converted.
Jan 01, 2015 | Funai Magnavox DV225MG9 DVD/VCR Combo...
I have just bought a 40 inch HD LCD TV, I want to purchase a combo VCR/DVD HD to be able to record channel 11(the new free to air channels HD). Big W gave the model No. RC 689 D to me but they were not...
The VCR/DVD combo that you purchased will be able to record what you wish to a VHS tape at low quality or to a DVD at a higher quality.
  1. Coax cable (round and screw on) from the antenna to VCR/DVD
  2. Coax/AV/HDMI cable (only need 1) from the VCR/DVD player to TV
  3. TV on and turned to the input matching the cable you used in step 2
  4. Turn on VCR/DVD and use the remote control included with this unit. Not the TV's
  5. Turn it to the channel 11 on the VCR/DVD
  6. Put in a VHS tape or DVD-R to record onto
  7. You will be able to hit record whenever the show comes on or used timed recording in the menu to schedule it ahead of time
Sep 14, 2011 | LG RC389H DVD/VHS Recorder
We have a SAMSUNGA LCD TV. We also have a
You indicated you have a DVD PLAYER, not DVD recorder. You cannot record on to a DVD on a player, you need to buy a DVD recorder/player. Unlike a VCR which stands for Video Cassett Recorder which can record and playback video. DVD recorder technolgy much more complicated.
Nov 28, 2009 | Grundig GU19WDT 19 in. LCD TV
I am unable to eject a dvd from my grundig combi TV. I press eject & get a 'clunking' noise
There should be a small pin hole on the front of the dvd tray. Gently push the end of a paper clip into the hole and that should release the dvd tray.
Oct 07, 2009 | Grundig GU19WDVDPCX 19 in. LCD TV
Cannot view tv program while recording on VCR
Hi and welcome to FixYa,
Initially, pls set the Samsung LCD TV to the Source selection as if watching a playback evgen if you are going to do a recording.
If that does not work, pls postback manner of connection (cabling) from Cox digital cable system to Philips DVD/VCR to Samsung LCD TV LN-T3253HX/XAA .
Good luck and Thank you for using FixYa. Happy Holidays.
Nov 15, 2008 | Philips DVP3345V/17 DVD Player/VCR
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
Mar 23, 2008 | Grundig GF70-600 TV
Camcorder Widescreen Recording Issue
THERE IS REALLY NOTHING YOU CAN DO as your settings conflict with each unit connected
Nov 13, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Grundig GU19WDT 19 in. LCD TV Logo
651 people viewed this question
Top Grundig Televison & Video Experts
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
