Question about Asko 24 in. 1805 Built-in Dishwasher
The soap dispenser pops open
The minute I turn the machine on, the soap dispenser pops open, So the soap is accessed even in the pre rinse - any suggestions>
4 Suggested Answers
  • 523 Answers
SOURCE: Dishwasher isn't dispensing soap or rinsing well.
prime the sink before starting the dw yo make sure hot water is getting there
Posted on Jun 01, 2010
SOURCE: My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Posted on Mar 02, 2012
Rotu
  • 175 Answers
SOURCE: soap dispenser won't stay closed
Only two reasons this may happen. One is the dispenser is just bad (most likely) or that the timer is somehow malfunctioning and sending power to the soap dispenser all the time (least likely) You will usually know if its the second because the dispenser will get really warm after the dishwasher had been on for a few minutes.
Posted on Nov 10, 2012
My detergent dispenser door does not open. It is NOT cloggy inside. Does anyone know if there is a pre-rinse before main-cleaning? I.e if I can just put the detergent into the machine directly? Thanks
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 30, 2010 | Bosch 24 in. SHV99A13UC Dishwasher
My Bosch dishwasher stops with one minute left on the timer but keeps running most time the soap dispencer door has not opened
Ok The soap dispenser is controlled by a wax plunger. This is mounted in the door on the back of the dispenser. Remove the door panel and gain access to the wax motor. Two wires connected to a brown colored small rectangular box about 1 inch long.You must check this wax plunger for resistance and short circuits. This item is a naughty little thing and can blow up your electronic. for mine I would get a new wax plunger and fit it straight away.They dont cost that much. After this if the fault still counts down to 1 tell me if the motor is still running at the end of the cycle. It very well might be. If this is so the electronic may be faulty. You can menil me on fixitap@gmail.com for further assistance.
Also check to see if the cycle works normally on the rinse . That is a cycle whit no heat. Just the pre rinse.
Jul 30, 2010 | Dishwashers
Dishwasher soap dispenser does not release(sometimes partially)and as a result dishes are not cleaning
the solenoide which pops open the soap lid may be faulty.
Better to poar your dishwashing powder or tablet in the bottom of the dishwasher tray until you get the machine repaired. You may want to do a prewash rinse first, then stop the machine and add your soap.
Make sure not to use too much soap. Just the normal amount as you would use in the soap dispenser.
Ash
Oct 27, 2009 | Dishwashers
The some dispenser and the rinse aid dispenser seem to be "stuck", soap door doesnt open and dishes appear streaky from no rinse aid. this happened after I cleaned the deposits from under the screen in the...
There is a solenoid which pops open the soap lid after the initial rinse.
If the solenoid or soap lid latch is faulty, you will need to replace it. In the interim just poar your soap in the bottom of the dishwasher tray before cycle starts.
Only use a little amount as per normal. Dishwashing tablets are best as it is a measured amount and has the rinse aid built in.
Good luck.
Ash
Oct 21, 2009 | Bosch Dishwashers
The detergent dispenser opens but the cascade packet does not fall out and dissolve. Even when I used granulated detergent, sometimes it was coagulated in the soap cup at the end of the cycle - not...
Maybe that is a bit much... I thought of something else you might check... there is a screen at the bottom of the dishwasher... make sure it is clean so that water can keep recirculating.
The thing about adding water is that if you add the water at the beginning, it is going to circulate for 3 minutes or so and then dump out the water and attempt to refill. Most machines do a couple "rinse off" cycles before the soap dispenser opens and the machine washes the dishes for a long time. So you have to put the water in after you hear the dispenser "pop" open.
I'm not completely sure about the Kitchen Aid, but their might be a way to adjust the time that the water inlet valve stays open at the beginning of the cycle... you'll have to check your manual.
Jul 28, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Filled the rinse dispenser with liquid soap. how do I rinse this out? So I can use the washer without it sudsing up everywhere?
Hello chystalsbrr
Welcome,
You said you, filled the rinse dispenser with liquid soap. how do I rinse this out? So I can use the washer without it sudsing up everywhere?
You can try by turning off the breaker in the electric box that feeds the dishwasher for 5 minutes and see if when you turn it back on and the washer resets itself, and the soap door opens.
Or push cancel and then rinse and after it is done and goes to the dry cycle stop it and it should be open.
In the use of liquid soap in both a dishwasher and or washing machine you must use less soap. Half that of powder soap.
Or the suds will roll out of your dishwasher on to your floor. And this is not a malfunction on the dishwashers part. NO bad seal or anything!
In a clothes washer it will destroy the seal and bearing in less than 5 years!
Let me know how it goes!
Huuum
Please remember to leave a rating
Oct 19, 2008 | Whirlpool Dishwashers
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Asko 24 in. 1805 Built-in Dishwasher Logo
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
