Question about Plano Golf Guard Deluxe Hard Travel Case
Latch replacemrnt latches on travel bar brook
I have a 1996 Jeep Grand Cherokee with a hood latch that does not work. The part of the latch that is operated from inside the car does not engage when I shut the hood. How can I fix this?
It sounds to me that your cable which travels fron the hood latch to the interior handle is binding or sticking. This cable can be replaced, but first check for kinks where it travels thru the frame of the car. Lubricate both the latch assembly and the cable from both ends. With the hood open, the latch inside the car should move freely back and forth and you should be able to feel the spring tension in the latch assembly. The cable is very similar to brake or shoft cables on a bicycle.
May 31, 2014 | 1996 Jeep Grand Cherokee
Trunk won't latch closed
So you know how to work the latch, and the latch is working.
Now you need to look and the holding bar, if you have to remover the plastic cover to see how it's bolted on do it.
Sounds like the bar moved down so the trunk hits the gasket before it can lock on the bar.
See if loosening the bar bolts will allow the bar to be raised just a hair.
Apr 14, 2013 | Cars & Trucks
My honda odyssey 2002 hood latch stuck it opened the hood and now not closing even droping the hood from difference hight and even pressing it ???
SOUND LIKE YOUR HOOD LATCH IS STUCK IN THE RELEASE POSITION. YOU CAN DO TWO THINGS. REPLACE YOUR HOOD LATCH OR PUSH THE LATCH BACK INTO POSITION MANUALLY EVERYTIME YOU OPEN YOUR HOOD. IT'S EASY. FIRST CHECK YOUR HOOD RELEASE LEVER (DRIVER SIDE KICK PANEL)AND MAKE SURE IT'S MOVING FREELY. IF LEVER IS OK,GO TO YOUR HOOD LATCH. LOOK TO THE RIGHT OF THE LATCH (LOOK DOWN FROM THE TOP VIEW)AND YOU'LL SEE A SMALL METAL BAR WITH A SPRING PULLING DOWN ON IT(MIGHT NEED FLASH LIGHT TO SEE BAR AND SPRING). TAKE A FLATHEAD SCREWDRIVER AND PUSH DOWN ON THE METAL BAR WHERE SPRING CONNECT. THE BAR SURE MOVE ABOUT 1/4 INCH DOWN. CLOSE YOU HOOD AND YOU'RE DONE. YOU JUST HAVE TO PUSH THE BAR DOWN EVERYTIME YOU OPEN IT.
Dec 14, 2010 | 2001 Honda Odyssey
Bonnet cable brook on bmw 3 series
Okay, so the hood latch cable on your BMW 3 series has broken. Normally the cable itself will snap and a you can purchase a new cable that can be threaded through the casing and reconnected to the hood latch. You will need to get the hood open, so hopefully there will be some access to the hood latch mechanism from underneath the front of the vehicle.
Apr 27, 2010 | 1996 BMW 318
Hatch back latch flipped in lock position. Door won't shut?
Get some WD40, clean latch. Use a screwdriver or similar tool to simulate the bar the latch attaches to by putting it in the latch. Pull handle to open latch as you pull the bar down.
Jan 24, 2010 | 1993 Jeep Grand Cherokee
Need door latch diagram Kitchen Aid dishwasher (Part No. 9744033)
I thought the metal bar had to be locked into place somewhere in the black latch. This was not the case. I just put the white plastic latch in place in the slot in the door and closed the panel and the metal bar went into the correct position against the black latch.
Jan 22, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
How do you latch the car seat into the stroller on
Found owners manual. Latch from car seat fits into cup holder on front of stroller.
Nov 15, 2009 | Graco Quattro Tour Travel System
How to work restraint latches
Do you mean the little straps that hold the front of the car seat in? On each side of the pushchair there's a short strap with a plastic thing at the end. These line up with the open-ended slots on the sides of the car seat. If you pull the strap straight, the plastic thing can just be tugged around the end of the slot on the seat so that the strap now goes through the slot and the plastic thing holds it on. It's tricky the first couple of times but gets easier. Sorry if that wasn't the question...
Mar 16, 2009 | Graco Quattro Tour Deluxe Travel System...
Plano Golf Guard Deluxe Hard Travel Case Logo
130 people viewed this question
Top Plano Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Plano Golf Expert? Answer questions, earn points and help others
