Question about ASUS Computers & Internet
Asus m2nse hard disk Not booting Problem. it is very slow
  • ASUS Master
  • 3,320 Answers
Is it slow or does it not boot?
Posted on Apr 13, 2014
2 Suggested Answers
colliewob
  • 781 Answers
SOURCE: slow boot
You could have a USB device connected and switched on and when you boot its trying to find it and boot from it
You could set BIOS to boot from hard drive to see if it fixes it
Posted on Sep 12, 2008
Laptop runs very slow asus
FIXING A SLOW COMPUTER
A slow computer could be caused by a number of things -
1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM.
2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc.
3. Uninstall/remove unused programs, this will also free up hard disk space.
4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it.
5. Install latest Windows updates.
6. Update virus definition files and scan computer for viruses, Trojans, malware etc.
7. Clear the Internet cache for faster browsing.
8. Hard disk maintenance is required at least once a month to keep it functioning efficiently.
Run the following programs -
Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space.
Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
May 12, 2013 | ASUS Computers & Internet
No Hard drive found
I am in agreement William.
What do the Radial Aluminum Electrolytic Capacitors look like?
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://support.asus.com/Download.aspx?SLanguage=en&m=P4SP-MX&p=1&os=
Post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | ASUS P4SP-MX Motherboard
Asus laptop will not boot up after install of new hard drive
If your ASUS laptop uses a SATA hard drive -
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 27, 2013 | ASUS Computers & Internet
My Asus Eee pc 900 is very slow booting. I disconceted the cmos battery and this helped for a few weeks but am now back to taking a good 20 mins to boot, Now the cmos trick wont work. Anyone got any ideas...
Sounds like you disconnecting the cmos and it helping was just coincidence.The hard drive may be bad or your OS needs to be repaired or reinstalled.Alot of times when it does as you indicated the boot sector maybe corrupt or your hard drive has bad sectors where the boot info was written on the hard disk
Jan 21, 2011 | ASUS Eee PC 900 PC Notebook
I have the identical problem as chrisdangelo
hello
I have read your problem and the solution to your problem may be following.
  • The BIOS setting may have changed.You can reset the BIOS settings.
  • The hard disk type may have changed..look for SATA and ATA.
  • Or your window got corrupt.Reset the BIOS setting and reinstall the windows using boot able CD.
  • if nothing work out then may be your hard disk connector is loose or your hard disk is gone.
thank you
Jul 29, 2009 | ASUS Eee PC 900 PC Notebook
Hardisk tidak aktif
likely have problems when the boot disk is .. try to see its boot settings and select the hard disk as its boot ..
possibility also exists on the power problems on the hard disk.
Jun 16, 2009 | ASUS Eee 4G Notebook
Boot system from external hard-disk with USB2
You can check the bios and make sure that it is set to boot from USB. Turn computer off. Turn back on and immediately press F2. This will get you into the BIOS. Look around and find boot properties. Set the boot first to USB. If you do not see the USB option, then your motherboard doesn't support the boot from USB option.
May 09, 2009 | ASUS P5GD2 Deluxe Motherboard
Hard disk boot up failure
check if your first boot device is the hard disk if not then
configure your bios setting by replacing 1st boot device to hard disk
Jan 29, 2009 | Computers & Internet
Slow boot
Sep 12, 2008 | ASUS P5B-E Motherboard
Asus m2v won't boot
Press delete to go to setup. In the boot menu tab of the BIOS make sure the correct boot disk is selected, and that hard disk boot has first priority. Also make sure there aren't any bootable disks in the cd/dvd drives that might prevent the computer from booting.
Aug 21, 2008 | ASUS M2V Motherboard
Computers & Internet Logo
27 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
