Ion Pics 2 SD - how to reset?
My ION Pics 2 SD does not respond to Enter/Mode/Scan buttons. Any clue like reseting? Tks
  • 8 Answers
SOURCE: It will not run as the reset button on the will not lock in place
The lock or the thermostat might be damaged, get them replaced.
Posted on Mar 20, 2009
  • 186 Answers
SOURCE: I cant find the inertia switch to reset my fuel pump
No Inertia switch on Saturns! Check Fuel Pump Fuse Or Fuel Pump!
Posted on May 09, 2009
lester482529
  • 226 Answers
SOURCE: 2003 Saturn ION 2 trunk Problem
there is a manual switch that is located near the trunk latch for a safty lockout it might have been switched by accident look to make sure.hope this helps.
Posted on Jun 21, 2009
SOURCE: h710 won't reset after holdg all buttons. can't get pairing mode
If you can't reset your device- try this, which I just fiddled with and got mine to work (I had same problem). On headset, close boom, hold center button (and it turns pink). then, while keeping center button depressed, open boom- light remains pink. Then look on phone, and hit Add new device-- and bingo, it should be recognized now!! You'll be asked if u want to pair w/ Motorola-- and led through the process--follow those steps. The passcode, as mentioned by others on these posts, is 0000 (four zeros).
I had tried similar earlier, but the trick was to keep the button depressed, and then open the boom. I can't quite remember if I kept button depresed until I also pressed Add new device on phone or just until after opening the boom and the light stayed on ... Sorry I can't be exact; I was too excited. Hope this helps you get yours working!
Posted on Jan 02, 2010
jrock1094
  • 158 Answers
SOURCE: 2005 saturn ion how do you reset the passlock
it has to be done at a gm dealer
Posted on Feb 17, 2010
Why do my slides only show as negatives
There may be a setting in the software to enable you to correct this - if not, then you'll have to deal with it in post-processing.
Jul 23, 2016 | ION Audio ION FILM 2 SD 35mm Film and...
Pic Scans to photoimpressions.Wen try to open on other computer with different programme. Half of the Pics won't show.Help!
could be a resolution problem. What program are you trying to open the photos in ?
Is it windows operating system ?
You may have to resize the photo to be smaller in size.
http://windows.microsoft.com/en-au/windows7/resize-a-picture-using-paint
Nov 10, 2015 | ION Audio ION PICS 2 SD Photo Slide and...
ION Pics 2 SD- Will not accept any memory cards. It says "New Memory Card Detected, Please restart." Bye. Then it shuts down. Anyone else have this issue or know how to solve it?
IF you can put that SD card in a computer then you can use the computer to format the card and then try it again. There are two format types so try them both.
Oct 04, 2014 | ION Audio ION PICS 2 SD Photo Slide and...
How delete memory (pictures) from ion pics 2 sd
Remove sd card and plug into computer and delete photos
Apr 30, 2014 | ION Audio ION PICS 2 SD Photo Slide and...
I cant enter sp mode programe mode there is password on uttilitys ans sp mode so i wants reset code
The BIOS in many machines can be reset by shorting pin No 1 & 2. Please make sure you know the correct 2 pins to reset the voltage . Incase there is a Li ion battery , you can remove that and reinstall it , it will reset the BIOS where the pass word is stored.
Dec 20, 2012 | Konica Minolta Bizhub 362 Copier
I just had my oil changed on my 2005 Saturn ION and now i get the 'chng oil' alert. what should i do?
  • Insert the key into the ignition and turn it to the "ON" position. There is no need to start the caricon1.png.
  • 2
    Press the button located in the center of the instrument cluster ONCE. The display should now read "OIL LIFE" instead of vehicleicon1.png mileage.
  • Read more: How to Reset the oil life monitor on a Saturn Ion ' eHow.com http://www.ehow.com/how_5658600_reset-life-monitor-saturn-ion.html#ixzz28jXOUbyz
    Oct 08, 2012 | 2005 Saturn ION
    Sajnos elvesztettem a driver lemezemet
    Hi, here is the link http://www.ionaudio.com/content1018
    you can download your required driver from the following page.
    Just click on left side menu (required item) and on the right side a menu will appear where you can choose your software or driver free.
    For further more information contact me with English Language.
    Good Luck
    Feb 27, 2011 | ION Audio ION PICS 2 SD Photo Slide and...
    Driver
    Here is the link for downloading your required driver free.
    http://www.ionaudio.com/content1018#
    Just click on your requirements and download your driver or software free.
    Good Luck
    42 people viewed this question
    jasbo
    jasbo
