Question about Sony MHC-RX70 Shelf System
CD tray now operates perfect after belts replaced, but won't read CD's
System pick up CD after CD, spins it a little, then continues to next one. Eventually it says no CD. Suspect CD read head?
    Problem Solver:
  • 6 Answers
Try 1st: You can take a q-tip dipped in alcohol (not dripping), rub the lens and gently blow it off with canned air. This will remove dust from under the lens as well. I don't recommend "lens cleaner CD's" that you can purchase as they sometimes rip of the lens.
Try 2nd: If the CD does not spin up to the proper speed, it is the motor that spins the disk. This can be temporarily fixed by disconnecting the motor wires and using a 9 volt battery to spin the motor in each direction. The trick is to reverse the direction while it is still turning in the opposite direction. This will hopefully burn off the carbon and debris in the motor contacts.
Posted on Apr 12, 2014
CDP cx355 cd doesn't spin
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 13, 2015 | Audio Players & Recorders
Detrola cd player spins too fast
Did you undo any leads when you changed the belt, are they in the correct position, it's spinning fast because it can't focus.
Aug 29, 2014 | Televison & Video
My RCA Stereo system 5 disc cd drawer keeps opening. When I put a cd in it, the unit opens and keeps opening. It only stays closed when I turn off the unit and manually push it closed. What could be...
These units are actually nice units. There is a "loading belt" inside that controls the tray movement as well as the final "load" of the mechism into the play position. If the load does not complete, the unit will "eject" or open up. This is most often cured by replacing the loading belt. This is a common problem with any rubber component. As it ages, it gets a little slippery and thus will not have the grip to complete the loading sequence. The belt for this will run about $5.
Dan
Aug 26, 2010 | RCA 100-Watt Stereo System With 5-CD...
My NAD C251i CD player isn't reading disks - platform stops short
To fix it, you need to replace the spindle motor top bearing. The bearing is worn and the player mistracks as the armature moves about under the changing drive conditions. Makes the player mistrack and skip. Because the disc is spinning fast.
Replacing the bearing should resolves the problem.
Hope this helps and have a great day!
Sep 01, 2009 | NAD C521 CD Player
Hello .Sometime does not play track
It is having trouble reading the CD.
Either....Dirty CD. Dirty laser eye. Duff CD. Duff laser unit.
One More Time does not like CDs made on your computer too.
Jul 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
DISC STUCK
Hi Ernie,
There should be a tiny little hole on the front of the CD drive, next to where you would usually press the button to eject it. Turn the laptop off (or at least wait until the CD stops spinning) and insert a straight paper clip into the hole. You will have to insert it perfectly straight and apply a little pressure. Doing this should manually pop the CD tray open.
Hope the helps!
David
Nov 19, 2008 | Computers & Internet
CD Changer spinning continually
i have the same exact problem with mine. what i did was manually pull open the cd deck, stop the disk carousel from spninning by holding it still, then push the deck closed. the cd deck will no longer work, but at least it stops spinning. the auxiliary works fine and so does the radio.
Feb 07, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
CD Changer
Common Problem with AIWA 3 disc machines. I have 3 in my service shop right now. For tray not rolling in on it's own, the drive rollers have to be changed, along with the Drive Belt. Also, for CD not reading, try CD lens cleaner.
Sep 10, 2006 | Aiwa NSX-A115 Shelf System
CD Player Tray Spins Continuously With or Without Disk
Yuo didnt mention if it was used or new,. If it was new I wouldnt mess with the unit and take it in under warranty, as there is no quicky fix for this one. Its going to turn out to be a problem with the disc motor servo circuit or the microprocessor. Good Luck
Aug 06, 2006 | Teac DC-D2831 CD Shelf System
127 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
