LG FFH-M200 doesn't see CD in tray
    Problem Solver:
  • 6 Answers
If you hear the CD spin but nothing happens, most likely the lens on the laser pickup is dirty. You can take a q-tip dipped in alcohol (not dripping), rub the lens and gently blow it off with canned air. This will remove dust from under the lens as well. I don't recommend "lens cleaner CD's" that you can purchase as they sometimes rip of the lens.
If the CD does not spin up to the proper speed, it is the motor that spins the disk. This can be temporarily fixed by disconnecting the motor wires and using a 9 volt battery to spin the motor in each direction. The trick is to revers the direction while it is still turning in the opposite direction. This will hopefully burn off the carbon and debris in the motor contacts.
Posted on Apr 12, 2014
LG dvd model no: HT 302, doesn;t eject & if eject the cd manualy , disc doesn;t spin & the laser not coming on. what could be a problem?
there are switches needs to be in contact when the loading tray is closed and open. it is placed under the tray mechanism. investigate ribbon cuts and bends. replace it
Feb 25, 2011 | LG Televison & Video
No tengo audio en un ffh-886
PON UN FOCO EN SERIE DE 60W y puentea el relevador despues comenta
Dec 09, 2009 | LG Audio Players & Recorders
How do i free 8mb in Sandisk Sansa M250 i formated but the same result happens plz help me!!!!
SanDisk tech support recommends formatting the m200 series in both MSC and MTP modes to completely clear out all work areas,"fragments" and residual data. The m200 has a very basic Operating System that doesn't have a defrag option. According to tech support, the m200 needs formmating occasionally to keep it working smoothly. I learned that formatting will also clear up intermittent hang-ups. I format mine each time I reload it.
Format in MSC Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then MSC.
Connect the m200 to the PC via the USB cable
Right click on the "Start" button.
Left click on "Explore"
Find the m200. It will show as a hard drive, for example: "SANSA M250"
Right click on the m200 device and select "Format"
After formatting is complete, click on the "Safely Remove Hardware" icon on the System Tray and stop the device
Disconnect the m200 from the PC.
Format in MTP Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then Auto Detect.
Connect the m200 to the PC via the USB cable.
Find the m200. This time it will not show as a hard drive but as a music device, for example: "SanDisk Sansa m250"Note there is no drive letter in MTP mode.
After formatting is complete, disconnect the m200 from the PC. There is no icon to stop the device.
Your m200 device is now formatted and ready to reload.
By the way, MSC mode is mostly for use with other than Windows XP computers. If you are using WinXP and Windows Media Player 10, you might consider using MTP mode and WMP to manage the m200's.
Source: http://forums.sandisk.com
If i was helpful, kindly do Rate!
Regards.
Jul 28, 2009 | SanDisk Sansa m240 MP3 Player
No driver cd for my portege M200
You can download the drivers from:
http://driverscollection.com/?H=Portege%20M200&By=Toshiba
Jun 28, 2009 | Toshiba Portege M200 Notebook
Portege m200 wont boot from cd or anything.
look at this page
http://blog.ryantadams.com/2008/02/01/how-to-boot-from-the-network-pxe-boot-with-tftp-and-windows-pe/
it works very good.
Mar 27, 2009 | Toshiba Portege M200 Tablet PC
Want LAN DRIVERS for satellite pro m200
Hey,
toshiba drivers and software is available at
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
Let me know if you need anything else.
Thanks,
Ekse
Feb 21, 2009 | Toshiba Portege M200 Notebook
Door
Hi abdu
The problem is that at some stage you or someone else forced the cd open or closed, but not to worry, it's not broken. What happened is that the gear that pulls the tray in, mite have slipped a tooth or two. You'll have to open it up. Take the top cover off. It has four small screws holding it. When you take the cover off, the gear system should reveal itself. Now the gear that pulls the cd tray in and out must me ajusted. Before you open the dvd writer, make sure it is in it's utmost closed position. Very Important!. There should be a screw in the centre of this gear. Carefully unscrew completely. Now it depends on which direction the gear turns when it close the tray. Seeing that it doesn close completely, the gear turns anti clockwise to close. Lift the gear in a up sliding position and turn it one teeth clockwise, press the gear back, fasten the screw and test. If it still needs more adjustment, repeat the process with another teeth clockwise. Note if it worsen that it doesn't close, then you need to reverse the process and move the gear anticlockwise, but make sure to mark the teeth that it was originally on when you opened it.
Hope this helps
Cheers
Deon
Sep 10, 2008 | LG (GCE-8527B) CD-RW Burner
What do I do with this "mini disc" supplied with the Sansa MP3 M240player. It is too small to insert on my computer???
Did you look at your CD player's tray? Most have an indented area in the center that accepts mini-disks.
Oct 24, 2007 | SanDisk Sansa m200 (2 GB) MP3 Player
LG F-185 AD (AKA LG FFH-185-AD) - No sound when CDs are played
Sorry, but you have three differant model numbers on this page. Just look up LG downloads then click on support or manuals, then enter the model Number EXACTLY as it appers on the rear of the unit, and you will be able to get a manual there.
Sep 28, 2006 | LG F-185 CD Shelf System
54 people viewed this question
 Grubhead
Grubhead
