Question about Lifetime Sport & Outdoor - Others
Lifetime 1002343 How to adjust height
2 Suggested Answers
SOURCE: Basketball pole
Ihave a pole and backboard but my backboard is cracked badly. Would you consider selling yours?
Posted on Apr 30, 2009
Where can we get details relating to electric height adjustable desk?
There are lots of sites on web that are providing data associated with electric height adjustable desk. These are specially made for all those people that are looking at affordable costs for quality electrical height-adjustable table. To find out more please visit this site:
FlexiSpot Height adjustable standing desk desktop workstation
Mar 06, 2017 | Electric Garden
Height adjustment does not work
Hello! The vacuum does not move up and down when you change the height setting. When the handle is reclined is when the height of the nozzle will adjust. Hope this was helpful!
Jun 26, 2014 | Hoover Tempo Widepath Upright Vacuum -...
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
How to adjust water flow coming out of bubbler
Check stream height from bubbler. Stream height is factory set at 35 PSI . If supply pressure varies greatly from this, remove the (bottom cover plate) and adjust the screw on the regulator Clockwise adjustment will raise stream height and counter-clockwise will lower stream height. For best adjustment stream height should hit basin approximately 6-1/2" (165mm) from the bubbler.
Mar 02, 2011 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
How many thermoststs does the nissan nomad have
1 this being the specifications on it
Features & Benefits Quality Controlled Factory Calibration Assures Accuracy Of Opening & Closing, Regardless Of Pressure Changes. Positive Piston Heat Motor Provides Accurate Temperature Control. Sturdy Metal Construction Throughout. Attributes Depth from Flange : .82"
Design : Offset
Flange Diameter : 2.125"
Height from Flange : .91"
Jiggle Pin : Yes
Temperature Range : 195 Deg
Warranty Limited Lifetime-See Manufacturers Written Policy
Warranty PDF
Material Safety Data Sheet (MSDS) There is no MSDS for this item Application Information: 1990 Nissan Van Engines : 2.4 L 2389 CC L4 SOHC
Comments: 195 Degrees;Alternate Temperature
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Feb 27, 2011 | 1990 Nissan Minivan
Lower for height adjustment?
There isn't necessarily an adjustment on all bikes. You can drop the ride height by adjusting the tension on the spring on the rear shock and lower the front end by moving the forks up in the clamps on most makes and models.
Mar 07, 2010 | 2003 Suzuki DR-Z 125 L
Need to adjust height of handlebar on a jeep sahara bicycle
Most bikes use an allen key to adjust the height of the handle bars. Typically 6mm. But be careful most bikes do not have much adjustment that can be done to the height of the handle bars. The handle bar stem will have a line on it of the "minimum insertion". That line must be below the top of the head set nut for safety reasons. Look for the line as you adjust the height.
Oct 03, 2009 | Jeep Cycling
Basketball pole
Apr 18, 2009 | Lifetime 3819 Impact 44" Basketball...
Height adjust for Dell UltraSharp 1907FP 19" LCD Monitor
Is it stuck, or just not adjustable? Try setting it on a phonebook. I'm kidding. If it is an adjustable base, sometimes they need a little downward pressure before the button will depress and allow it to move upward.
Thanks,
Chris
http://BoiseLCD.webs.com
Jan 03, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Sport & Outdoor - Others Logo
Top Lifetime Sport & Outdoor - Others Experts
Vernon Taylor
michael vanier
Are you a Lifetime Sport and Outdoor - Other Expert? Answer questions, earn points and help others
