Question about Polaroid 7'' Portable DVD Player
No disk error
When i try to watch a disk the player clicks, the disk does not spin, the lens head bobs up and down, then a few seconds later an error message comes up - "no disc". Please help.
    Problem Solver:
  • 12 Answers
The lens could be bad. Have you tried cleaning it ? The parts are sensitive, if it has been dropped there's a good chance it's broken.
Posted on Apr 12, 2014
    Sergeant:
  • 231 Answers
Try another disk, if not this unit may be broken and repair may not be economically to your advantage. These drives where out - they are a mechanical spinning part.
3 Suggested Answers
likha
  • 790 Answers
SOURCE: "No Disc" Error
cleaned your lens with 100% cotton buds, if not work again change the laser eye. do it!!!
Posted on Sep 09, 2007
CoquiBiz
  • 103 Answers
SOURCE: Error: Bad disk
If you are using original discs and have the problem. Try with a cleaning disc and is still the same, check for calibrating the optic lens. About how much is the replace or the calibrating you have to ask on the repair shop or manuf. website. Sometimes, is better buy a new one because the technology moves so fast it makes the same technology disposable.
Posted on Jul 30, 2009
Dvd disc want play. Attempted to play several disc with negative results. Receive message that says"No Disc".
  • This could be a real easy fix actually. When you have a disk in the DVD player and it says "NO DISK" the 1 of 3 things is going on.
  1. Make sure you have a non home made DVD. Some DVD players will not play DVD'S in certain formats.
  2. If you have a normal DVD in the DVD player and are getting "NO Disk" then there is a real good possibility the lens is just so dirty that it is not recognizing your DVD at all. This happens a lot to all disk players that are neglected from the cleaning process. Get a disk player cleaner and run it through a few times until the disk is read again. Sometimes the lens is so dirty you have to try a few times just to get the cleaner disk itself to play just to do the actual cleaning. Make sure to run that cleaner disk through once a week. These disk cleaners "sweep" the lens and work well. You can get one at your local Best Buy for $8usd.
  3. The last thing it could be is that somehow the lens has come out of alignment. Just a millimeter out of alignment is all it takes to not be able to read a disk and DVD players get bumped and knocked off the shelf easy. So this can happen often especially with the more smaller travel DVD player.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 19, 2011 | Durabrand DUR85
My DVD player won't read, keeps saying disk error
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jul 12, 2011 | Televison & Video
I bought 2002 nissan Altima. It has single disc player and it gives me error 3, on cd player shows that disk is inside, but it's not playing neither edjecting the CD. Please advice.
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working , if not there is no laser scanning and the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked. hence the rejection but the best is for cleaning manually the laser head eye with a cotton bud very softly and without any pressing of the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive , if so the board seems to work correctly and the possibility of the optical head being the suspected fault is closer.
But if any of the above seems otherwise we must recheck with possibilities of the processor board
Sep 29, 2010 | Car Audio & Video
I AM HAVING ERROR EACH TIME I TRY TO PLAY A CD.
When your CD does not read any disk, and returns error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, or a faulty spindle motor unit.
If it is a lens problem, then you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , the unit will start losing the rest of functions, and ends up not reading anything at all, and returning error.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player , and clean lens directly with q tips and isopropyl alcohol, or to replace the lens, or the whole drive unit.
Sep 04, 2009 | Technics SL-MC50 CD Player
Dvd player always says no disc . will not load
That happens because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the unit will start losing the rest of functions, and ends up not reading anything at all.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Aug 28, 2009 | Philips DVP3962 DVD Player
Unit stops spinning after loading & shows "no disk"
could be down to a dirty lens , faulty lens or faulty dvd player spindle motor.
jon
Aug 05, 2009 | Amphion Mediaworks M-520 Portable DVD...
Bad disc error on cd player
I'm sure these are good CD's that you are putting in (i.e. not scratched) but are they CD's that were burned from a computer? Some disk burned from computers cannot be read by older p[layers. If not than I would by a laser cleaning kit. This is a specials disk with small bristles attached to it. You add cleaning solution to some or one but not all. Then insert the disk in the player. This will clean the laser lens. The kits are cheap to buy but harder to find these days, check on-line but some department stores might have them. Check to see if the disk is spinning up by listening closely. Either way if cleaning the lens doesn't work you might have to replace the whole unit. Although, I suggest at that point to hard wire a aux input through the antenna wire. That way you can plug in a cheap MP3 player that can hold many of your CD's and play through your stereo.
Feb 17, 2009 | 1999 Ford Explorer
DISK ERROR
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Aug 12, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
DVP642/ 37 DVD player says "NO DISK" with any disk.
Usually if there is a NO DISC error, and the lens is verified clean, there is either dust in the laser assembly (use a can of compressed air to clean it out) or a loose laser assembly cable. Also check to make sure the lens can bob (wiggle around), and that it can slide back and forth.
The emergency eject is underneath, its a small slot. Insert a toothpick at one end and slide to the other end to open the tray.
Oct 28, 2007 | Philips DVP642 DVD Player
Error 6 on in car stereo
Here is the link to the user manual for your player if you need it; http://www.clarion.com/gb/en/MungoBlobs/483/874/DXZ838RMP-EU.pdf Page 38 of the manual (page 42 of the pdf file) describes the error codes error 6 states "a disk is loaded upside down inside the cd deck and doesnt play properly" Suggested solution is to try the disc the other way up, if this doesn't help then there is most likely a problem with the lens - possibly cured by cleaning, please ask again if you want to try this yourself and we can talk you through it Hope this helps :)
Apr 15, 2007 | Clarion DXZ838RMP CD Player
Polaroid 7'' Portable DVD Player Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
