Question about Whirlpool Refrigerators
Clicking on my ED2KHAXVQ01
Clicking noise, Replaced the run capacitor. This is not it
    Prodigy:
    An expert who has answered 500 questions.
  • Whirlpool Expert
  • 650 Answers
The start device is more than likely the problem. Run capacitors are rarely bad. If the start device rattles then it is bad.
Posted on Apr 13, 2014
ED2KHAXVQ01 clicking noise
Could be liquid refrigerant "flashing" in one of the lines near the compressor. Not so much a problem as an annoyance.There's a kit for it but it's risky - bend one of those lines too much and you'll solve the problem in a brand new way
Apr 12, 2014 | Whirlpool Refrigerators
My CD player just make a clicking noise it won't take a CD
you have to check the power supply board, you need to remove the cover and look for bulging electrolytic capacitor at the power supply board. just replaced those bulging capacitors.
Nov 22, 2012 | Audio Players & Recorders
ED2khaxvq01 not cooling ref and freezer
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Oct 10, 2012 | Whirlpool Refrigerators
My 50" ps50b451b2w Samsung has just had a new main
Clicking sounds like a bad power board. There are small relays on power boards that would make a clicking noise.
I don't know why a main board would have been replaced for that, as I don't know of any main boards with relays or anything that would cause a clicking noise on them.
Sep 15, 2012 | Televison & Video
My Maytag refrigerator Model # MSD2651HEW (26 cu ft , side by side) would not cool there was a rrrrrr noise with a clicking noise and the compressor would heat. I got a factory OEM part from Sears and...
Did you lay down the fridge while cleaning it? if so: Normally if you lay down your fridge the compressor oil is running into the pipes that carries the gas to cool the inside. if that oil is in the pipes you have to shut it down for at least 2 days for the oil to return to the compressor, if not layed down, the chances are that you running out of gas and had to have it refilled
Dec 11, 2010 | Maytag MSD2651 HE Side by Side...
Should the wires coming from the run compacitor have power
The run capacitor is not a mechanical device, so the clicking that you are hearing is not actually coming from the capacitor. If you the wires going to the capacitor, (isolate the capacitor), you can check the microfarad rating of the capacitor to ensure it is still good using a multimeter. Hope this helps.
Apr 15, 2010 | Refrigerators
When i turn on power, the picture doesn't come on and there is a clicking noise as the power seems to go on and off
Ur power board is dead,know how to solders?Check the power board for Capacitors,puff up or burst open,must replaced these capacitors.Or replaced the whole power board.Tries Shopjimmy.com,Ebay.com for the refurbish power board.
Jan 16, 2010 | JVC LT-37X688 37 in. LCD HDTV
Pump makes clicking noise when powered up ?
Clicking?... not knowing which clicking noise you are hearing, I will run down the most likely on a new pump.
1. When wiring the motor you may have left a wire in close proximity to the centrifical start capacitor switch. It spins at high RPMs and can be hitting a wire not properly tucked in
2. Most pool pumps are dual voltage. If you wired motor for wrong voltage than that being delivered, the motors can sometimes make noises. Clicking isn't most common, but the vibrating hum of incorrect voltage might be interpreted as a clicking noise.
3.check to make sure no wire ties, or plastic stringy tag holding devices were left in the pump intake basket.
Aug 23, 2009 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Whirpool GS6SHAXLB03 Refrigerator or freezer do not cool.
This sounds like it's out of freon. Not just low but out. That clicking noise is a thermal overload shutting down the compressor. If you continue let it just click away it will burn this overload out and the compressor will have to be replaced. If the refrigerator just started doing this suddenly it could be that the compressor is locked up. If it has external capacitors either the start or run capacitor could be bad. If the capacitors are good then you could try a hard start kit to try to unlock the compressor.
Jun 30, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Refrigerators Logo
37 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
