Question about Garden
I have a John Deere sabre and it keeps burning the ignition switch up I just replaced it yesterday it started twice and now it won't do anything I just bought a new starter for it also any ideas?!!!
  • Garden Master
  • 2,478 Answers
The starter fix problem? You have a bad short. Check wiring for bad spots. Is solenoid going in and out.
Posted on Apr 12, 2014
  • 133 Answers
SOURCE: John Deere Sabre 14.5/38 HYDR lawn tractorWont't
See if there is a plastic connector on the wires leading to the seat switch. If there is try disconnecting it and use a piece of wire (with insulation on it) to use a jumper. There is probably two wires coming from the tractor to the seat. After disconnecting Place one end of wire into the wire connector coming tractor and the other end of wire in the same connector on the other side. That will act like the seat switch is closed like you are setting on it. Try and start. Had the same problem on an electric hyster at work and that was the fix we used because the switch is pretty expensive and a hassle to change.
Hope this helps
roundo4
Posted on Aug 04, 2009
mowerman1857
  • 389 Answers
SOURCE: Craftsman II LT 4000 MOD # 917-255691 with a
Check the wire from the ignition switch to the small terminal on your solenoid with a volt meter to make sure you are getting current to the solenoid. If not try a "jumper wire" connected to the same terminals and see if it now cranks. If it does, replace the wire
Posted on Sep 14, 2009
mowerman1857
  • 389 Answers
SOURCE: drive belt on a sabre by john deere 42 inch,
Since you didn't ask any question or say what you wanted to know about the belt, you can go to johndeereparts.com , click on parts catalog, enter your model number, click on sectional index and the click on Belt drive and Idlers for which ever transaxle you have. It will show you a very clear picture of the belt and its routing, also gives you the part numbers for each
Posted on Oct 31, 2009
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
  • 252 Answers
SOURCE: briggs 17hp intek overheadvalve on
hi there
pauly46 here
if engine seems to labour when trying to start as if too much compression ?
try adjusting to in and ex valve clearance to 0.003" inlet and 0.005" ex
inlet valve is the bottom valve, and has a alloy push rod. ex valve is top valve and has steel push rod ( as viewed from the front of the machine with rocker cover off ) )
note rotate engine with plug out to tdc compression stroke , then rotate it down the bore on power stroke by 1/4 inch ( 6.35 mm ) this is the point for setting in / ex valve clearances
manual says 1/4 pst tdc on compression stroke - this eliminates decompressor lift from the setting
cheers hope it hepls
Posted on May 02, 2011
John Deere sabre runs for a while then sputters to a halt. Won't restart until it cools down
check coil , ignition control module
This is an indication of component over heating and breaking down.
splutters as the circuit becomes unstable and eventual failure and refusal to start until cool
Jul 07, 2016 | John Deere Garden
I have a John Deere LT115. Lights work when ignition switch is turned but starter does not ingage. Removed diode and replaced it with a jumper wire and engine starts. Will a jumper harm this circuit?
yes. the diode is what keeps it from sending to much volt to and from the battery. if you jump it now if anything happens to the stat-tor it will go through the system not protected. i don't know a lot about them but was told by several shops to not bypass them.
Jun 08, 2016 | John Deere Garden
5525 john deere tractor keeps buring ignition switch
First you will have to check for a short , next i would check the ballast resistor. if the points also burn chance this is a problem.
If you have the wiring diagram check to make sure every thing is wired correctly Good Luck
Dec 08, 2015 | John Deere Garden
When I turn my john deere sabre off at the key the engine shuts down, however ten seconds later the fuse blows. Also brand new safety switches are killing engine when released. Suggestions?
Somewhere, probably in the ignition switch circuit there is a short circuit - otherwise the fuse would not blow. You'll need to take a test meter to each circuit in turn to isolate the circuit and then find the short. Be logical and patient!
Apr 29, 2015 | John Deere Garden
My john deere 2010 backfired twice now wont do anything when I turn the key I hear tumbleweeds
So it won't activate the starter motor either?
If so then sounds like a safety switch issue.
If starter goes and it just won't start, then sounds like your fuel got cut off - check the fuel cutout solenoid that some ride-ons have on the carb - follow its wire back to the ignition switch and look for shorts / breaks etc.
Jan 24, 2015 | John Deere 2010 Tractor Basic Carburetor...
John Deere 345 won't shut off
I would start with either replacing the key switch, or tracing the wires to make sure they are not touching together somewhere, completing the ignition circuit.
Apr 14, 2013 | Garden
Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Oct 25, 2012 | John Deere Garden
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
