Medion akoya my alt key, space bar, c, b & n keys and enter have stopped working on my medion akoya. i have looked on the control panel but it says that it is working fine. using a keyboard now but it's not ideal. plz help!!!
    Master:
  • 388 Answers
Check to see if there is any debris underneath the keys. Use canned air or an air nozzle hooked up to an air compressor. Sometimes, debris can get underneath the keys, keeping them from depressing the membranes underneath. If that doesn't help, you may need to take it to a technician to diagnose the problem.
Posted on Apr 12, 2014
djnick989
  • 1067 Answers
SOURCE: Enter,Backspace, Space Bar on Dell Latitude not functional
time for new kb same thing happend on one i worked on go on ebay 16 20 bucks easy to replace opo up top cover covering the screen hinges that plastic then under that 3 4 screws hold kb down with ribben cable pop it up out its litt rackets the rippon cable then pull up leave up with new one installed then push down
Posted on Jan 26, 2008
  • 3940 Answers
SOURCE: medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Posted on Jan 11, 2010
Testimonial: " many thanks will get it looked at"
  • 3940 Answers
SOURCE: Dell Inspiron 1545 space bar, ''n'' and ''b'' keys suddnly don't work
There isn't any "Known Issues" that I am aware of with that model. Try re-seating the keyboard cable, see if there is any difference:
http://support.dell.com/support/edocs/systems/ins1545/en/SM/keyboard.htm#wp1179891
If no difference, contact Dell if under warranty. If not new keyboards are about $20 on EBay
Posted on Jan 15, 2010
aviral_srms
  • 1216 Answers
SOURCE: I use dell inspiron 1440 notebook. There is no no.
Although there is no num lock button on the keyboard, it can still be turned on - either via external keyboard or the onscreen keyboard in windows. However, the keyboard on this notebook does not have keys which are dedicated to become number keys when numlock is on, so it wouldn't impact usage of the keyboard in the slightest.
onscreen keyboard is located here
start----->all programs-----> accessories---------> accessibility------>on screen keyboard
Posted on Feb 13, 2010
  • 305 Answers
SOURCE: where is the wireless capability key to turn on
check your manual, but sometimes its on the front, some times its an f key ie F1, F2, ect this will have to be used with the fn key press fn + F? keys together.
hope this helps
Posted on Apr 28, 2010
How do i turn on wireless?
Try looking for a wirless sign on your funtion keys probably F5 you would need to hit alt fn then the function key.
Nov 13, 2014 | Medion AKOYA P8610 COMPATIBLE LAPTOP LCD...
Laptop touchpad not working
Dear John,
Although you did not mention your laptop model, Medion laptops use a combination of the 'Fn' key with one of the function keys on the top part of your keyboard to enable/disable the touchpad, that can be F3 or F6 or F8. So, try pressing the 'Fn' key and, while keeping it pressed, press also the F3 key and release them. Check if the touchpad now works. If it does not, try the same operation with 'Fn' plus the F6 keys or 'Fn with the F8 keys.
If none of these combinations works for you, maybe you will need to download and re-install the driver for your touchpad, from the Medion web site. go to www.medion.com site, select your country or region and then look for the drivers page for your laptop model. Select the driver for the touchpad offered there, download and install it in your machine.
Hope this helps!
Regards,
Miguel L. Martins
Nov 01, 2013 | Medion Computers & Internet
How do i get my laptop screen thr right way up i pressed somthing and its gone upside down
You probably flipped the screen orientation (rotated it).
For some versions of Windows (XP and Vista), try pressing Control (Crtl)+Alt+Up arrow (press the three keys together). You can also try the other arrow keys with the Crtl+Alt keys. The Crtl and alt keys are both usually in the row with the space bar. On a full-size keyboard, there are two Ctrl keys on the ends of the row and the alt keys are closest to the space bar.
Otherwise, right click on the Desktop (where there are no programs or icons) and choose Graphics Options > Rotation. Another place to check is right click on the desktop and choose Screen Resolution > Orientation. This is a shortcut to accessing the display properties in the Control Panel. Click Start > Control Panel > Appearance and Personalization > Display > Screen Resolution. For a widescreen monitor, choose Landscape.
I hope this helps.
(The ctrl+alt+arrow key doesn't work on my Win7 desktop but does work on the laptop. The Orientation change from the control panel works on both.)
May 04, 2012 | Acer Computers & Internet
How do you set margins
You move the carrier, with the space bar or backspace key, to where you want the margin to be set.
If the carrier stops before you get to where you want to set the margin, then locate the ALT key at the bottom left on the keyboard, hold it down, then locate the key directly under the words above the keyboard that say M REL (the 3 key) and push it. Then move the carrier with the space bar or backspace key. (whichever direction you want to go)
When the carrier is where you want the margin set, hold down the ALT key and push the key under where it says L MAR (4) to set the left margin, or R MAR (5) to set the right margin.
The ALT key works with all the functions listed above the keyboard.
The CODE key works with the functions/charachters printed on the keys themselves.
Jan 03, 2011 | Brother SX-4000 Typewriter
My wireless wont turn on on medion akoya E5211 ... i need to turn on my wireless connection switch and dont know how or where it is
I had the same problem so I rang Medion & they told me go to the Medion website and download "Launch Manager" from your driver page. It's a program that turns on all of the Fn keys. Thus making the wireless (Fn+F1) work as well as the brightness (Fn+F8 or F9).
This is the only way to get it to work
Oct 24, 2010 | Medion md40298 Notebook
Trying to get a replacement keyboard for my medion akoya E7212, I phoned medion looking to get one, the tech guy suggested I google it as they dont supply spares. Tried that but no luck, Uk supplier...
Here is a link to medion akoya keyboards for sale on eBay, although none of them mention your specific model. In such cases (I'm a laptop repair pro) I contact the vendor through the "Ask a Question" link under their name and feedback rating and inquire as to matches.
http://shop.ebay.com/i.html?_kw=medion&_kw=akoya&_kw=keyboard
Many Laptop companies have the exact same keyboard supplied on a number of different models.
Good luck.
Aug 01, 2010 | Computers & Internet
Enabling wireless LAN on Medion Akoya
install the driver for your wifi device. go to your laptop manufacturer website and download the driver. www.medion.com
Mar 19, 2008 | Medion MD-40954 Notebook
Medion Akoya Multimedia notebook - wireless capability
press the fn key then i think its the f5 key but which ever f# it is it has kinda like wavy lines on it read the instruction manual too it does tellyou
Nov 18, 2007 | Medion md40298 Notebook
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
