Question about TOPICS Entertainment Computers & Internet
Trying to register for the french deluxe audio edition but i don't have a link to even register. Where is the link to register a product? My code number on the disc starts with Lv1-003. There are up
I have the French new deluxe audio edition with 16 cds and the audio workbook. I am trying to get a valid license key and have it registered. I have a Level 1 disc with a code on the sleeve of it - I have tried to enter this but it's message tells me to register the key. Looking for help to find a link to properly register my product and know if the code given is the one to register. Also, this code on the sleeve has lower cased letters, but should they all be in upper case?
  • 505 Answers
SOURCE: My MS Excel vlookup function
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Posted on Oct 31, 2008
  • 8 Answers
SOURCE: If formula
What are the "cases"? Your example "more then 8 or less then 9 use 400" implies that there is a decimal part e.g. 8.5 . Is that right?
You dont need to test in both directions
e.g. assuming you name the cell with your number in it "cases"
Need more information on what the numbers are to help further
Posted on Nov 07, 2008
  • 253 Answers
SOURCE: I downloaded microsoft office standard 2007 from
WE cannot "give" away keys here, you should PURCHASE the software if you use it, the keys do not work, because MS has blacklisted them because they are used by to many people, not paying for something that someone else made
Posted on Apr 18, 2009
  • 407 Answers
SOURCE: keyboard types upper case digits instead of lower
It sounds like you may have turned on the calculator function - Does one of your F keys have a light on - F10 or F11, if so Press Fn and the key that is lit up.
Posted on May 21, 2009
the kowalski
  • 86 Answers
When registrating your GPS on myGarmin you should type in your serial number. It's on a tiny label on the back/bottom of the unit, and is the identification number needed to start the registrating process. Your GPS will need to be connected to the PC on the next step.
Posted on Jun 03, 2009
Lost sims serial number for sims delux edition. how do I get another serial without buying the game again?
Try this Serial and feedback if it works or not. enjoy...
Sims Deluxe Edition SERIAL: 4541-9792320-5864954-2633
Jun 03, 2013 | Electronic Arts THE SIMS DELUXE EDITION...
Trying to register Cisco E900 wireless router - dvd link will not load - did not see the product on the list. How do I register this product or should I even worry about it? thanks... John
I think you don't need to worry about registration.
I think, this router has free tech support for 90 days or may be 1 year.
Keep the receipt of purchase with you.
Registration is really not required.
Jun 24, 2012 | Cisco Computers & Internet
Product key office 2010 student edition
Your school college or university should help you with this because they supplied the software to you. they should have a record of it. speak to the person who teaches you IC, information technology or ICT, information and communications technology. or you could try to see if your school college or university have already registered the program with microsoft. if they have then you can get the microsoft website to scan your computer and then automatically download an activation code. once you have an activation code from microsoft, you don't really need the original product key any more. microsoft's website is:
Oct 28, 2011 | Microsoft Office Professional 2007 Full...
Need audio installer asus m2n-sli deluxe
If it is: M2N - SLI Deluxe:
if: M2N - SLI Deluxe/Wireless Edition
select your OS
Aug 06, 2010 | ASUS M2N-SLI Deluxe Motherboard
I lost my registration code for the game The sims 2 deluxe edition and i was wondering if you can give me one of the registration codes for it does not supply codes or product keys for any software. However if you contact the game manufacturer they can provide you with a replacement key.
Apr 05, 2010 | EA - Electronic Arts The Sims Deluxe...
Lost my product code for sims 2
try 4506-2932129-6619288-0323
and if that doesnot work 9730-2898632-2470001-3221
Aug 26, 2009 | EA - Electronic Arts The Sims Double...
Quicken 2009 Deluxe will not print on Vista 64 system on HP 5610 All-in-one printer - ran all the usual suspects about drivers, rebooting, selecting right printer, etc. etc. no luck. Seems Quicken does...
Me too. None of my printers worked and each time I tried Quicken crashed. But only quicken had this problem. Then I read this super simple fix:
  • Click Edit from the menu bar, and choose Preferences > Quicken Program.
  • Go to Register > Notify, and remove the check mark from “Warn if a check number is re-used”
  • Click OK.
  • Print checks.
At this location:
Worked like a charm. Go figure. Wasn't even a duplicate check number.
Aug 18, 2009 | Computers & Internet
Can't register product or use Advanced Audio Editor
I ran into the same issue when I tried to reinstall it. I did some research and found out that this product among many is no longer supported by Turtlebeach. The registration server that were used to activate the licensed copy have been shut down. So even if you own a licensed copy, you cannot install this software anymore and use it. Talk about a company that leaves their customers high and dry after they've purchased a product is unimaginable. It's one thing saying that a product won't work with Vista and another to say that you can no longer use it if your machine crashed and you had to reinstall. I'll never buy another product from this company ever again and I would advise others to stay away from them. They are digging their own hole with this sort of practice...Do these people know how many XP machines are still out there???
Feb 26, 2009 | Voyetra Turtle Beach Record Producer...
Slovo ed dictionary
Please find here enclosed link
Nov 05, 2008 | Nokia N73 Cellular Phone
Computers & Internet Logo
44 people viewed this question
Top TOPICS Entertainment Computers & Internet Experts
Tom Chichester
Rani wadia
Rani wadia
Are you a TOPICS Entertainment Computer and Internet Expert? Answer questions, earn points and help others
