Question about Nokia HS-23 Headset
HS 23 HEAD SET CIRCIUT DIAGRAM - Nokia HS-23 Headset
3 Suggested Answers
SOURCE:
SOURCE: please help me with a diagram for hs-23 plug connections...
I want repair my HS-23 headset. But I haven't that's wiring diagram.
Posted on Oct 01, 2008
SOURCE: HS-23 problem disconnected
Assuming that the joint which connects the neck strap has been damaged ( see below image )
, I advice you fix the loosed or broken joint back in its proper place permanently by using fevi kwik or some other fast bonding adhesive, but the only problem which will remain is that each time you have to use the headset you will have to wear it through your head andremove it the same way.
Posted on Jun 14, 2009
Cylinder head diagram
https://www.google.com/search?q=2005+Chrysler+300+Cylinder+head+diagram&client=firefox-a&hs=rUn&rls=org.mozilla:en-US:official&channel=sb&tbm=isch&tbo=u&source=univ&sa=X&ei=7YBZU-fVJOX58AH74YHYAg&ved=0CD0Q7Ak&biw=1280&bih=595
Apr 24, 2014 | 2005 Chrysler 300
Creative HS-400 headset & Mic
I had the same problem... with my laptop, using vista. I plugged the mic dirrectly into my laptop and for some miracle, it works! try it out! ^-^
Sep 25, 2008 | Creative Labs HS-400 Headset
Apr 19, 2008 | Nokia HS-23 Headset
Please help me with a diagram for hs-23 plug connections...
http://free-zg.htnet.hr/GoranJurkovic/nokia/
http://cellphones.hackaday.com/2005/08/16/how-to-make-a-nokia-pop-port-to-female-mini-jack-with-volume/
Dec 03, 2007 | Nokia HS-23 Headset
HS-23 Not Being Recognized by Phone
Rub the pins of your headset, and your phone with some tissue paper or something like that.
You might use some cleansining agent like alcohol.
Switch off your phone while doing that.
I too encounter such problems.
Dec 01, 2007 | Nokia HS-23 Headset
HS-23 Nokia Headset
hey kev.. all i can ask you is ... the following 1) open the ear piece of the non working .. then take a multimeter (keep meter in resistance mode) and check the resitance if its good it will show you.. apx 32 0hm and if its showing you 0 or .1 or below 16 ohms.. 2) after you disconnect the speaker.. the broken one that is... chek the cable connectivity.. or rather continuity.. for this keep the meter in continuity mode the pervious resistance mode.. then take one wire and connect one prob from meter to it.. and take the other prob and connect ti too the pins of the cnnector.. ( here is there are 4 pins dedicated to the ear phone.. 2 for each.. nd they are towards the end sid.. just below the # key.. frm # key the last 4 pins connectors are for audio.. ) check the.. pins on the cord connector not the phone.. i hope you can find what wrong with your... head set now.. and yeah if the speaker is out jsut replace both the ear piece with sony or aiwa earphones.. it wil work best if your cable is gone then all the best buy a new one tc aditya
Aug 04, 2007 | Nokia HS-23 Headset
Nokia HS-23 Headset Logo
87 people viewed this question
Top Nokia Radio Communications Experts
Anthony Ward
Anthony Ward
Damen Wong
Damen Wong
jonathan mariano
jonathan mariano
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
