Question about Ngk Vehicle Parts & Accessories
Gearbox Got a opel meriva 2006 auto model got 300,000 on the clock now gearbox giving problem serviced the gearbox change clutch, pressure plates and bearings but still giving problems changing lower gear and taking off and when taking off sometimes it stalls why???
    Problem Solver:
  • 8 Answers
There is a possibility that the clutch pressure plate wasn't torqued down and is loose causing the clutch to not disengage fully making it hard to put in gear at a stop or downshift at higher speeds. The next time this happens try letting off the brake and if it goes into gear easier or the car starts to roll forward faster than it was then this is a good possibility. As for the stalling issue it could be related to the same clutch problem or it could be an icv (idle air control valve) problem which is a common problem with vehicles that are driven alot. I would take it back to the shop that installed it and ask them to take a look at the clutch again because it is acting funny still.
Posted on Apr 14, 2014
When i press the clutch pedal down it makes a rubbing noise similar to worn brake pads.stuart
opel vectra ,,,,ot sure if their is a automatic adjustment on the pedal ,if so it could be this failing which the cable could be frayed ,would really need to see it to know for sure
Feb 08, 2016 | Opel Vectra Cars & Trucks
Noise on gearbox when clutch pedal is pressed down
Hi,I know money is sometimes an issu,but realy when you replace the release bearing you should also replace the presure plate and the clutch plate at the same time so that thay all ware in at the same time,all the best.
Apr 28, 2015 | 2008 Opel Corsa 1.6
Cluch operatng shaft leaver chage vw
are you refering to the clutch fork that connects to the other end of the clutch cable, you will have to drop the gear box as this fork sits over the clutch pressure plate ,and pushes the thrust bearing against the pressure plate tynes so disengages the drive from engine to gearbox, while you've got the box out check the condition of the clutch parts ie thrust bearing,pressure plate spring's,friction plate condition
Oct 01, 2014 | 2000 Volkswagen Golf
Vauxhall meriva faults
Could be a range of things. Rich or Lean mixtures
Vacuum Leaks
Exhaust Leaks ahead of Oxy Sensor
High or low fuel pressure
Leaking Injectors / blocked injector
Faulty Air Flow Sensor.
Jan 08, 2014 | Ngk Vehicle Parts & Accessories
No power on car. The diagnostic lights does not even come on. Opel Meriva 1.7 CDTI 2006 MODEL
check main ecu fuse in engine bay big fat fuse. check this then get back to me on here.
Oct 01, 2013 | 2010 Opel Meriva 1.7CDTi
At 80,OOO kilometers the clutch started juddering, removed clutch plate and had it rebonded,schemed the pressure plate and flywheel, replaced the thrust bearing,replaced the concentic slave cylinder with a...
Replace the pressure plate and disc with new, not rebuilt, have the flywheel machined again, if badly burned replace it.. We call juddering "Chatter" here in my country.
Jul 28, 2017 | HP PLATES,CLUTCH LOCK 282249-001
Grinding in the gearbox area while driving
manual ,thank heaven ,dont see many autos here in spain,right without driving car so i can hear it then it stands two possibilities ,when clutch is depressed you hear a noise like a grinding squel ,this is the thrust bearing ,if you hear a rumbling noise that disappears when clutch is depressed then this is lay shaft bearings ,Now also the problem can be the fingers on the clutch plate are worn and the bearing is pushing the clutch plate fingers down but if one or two are worn away then the thrust bearing is being pushed through the pressure plate ,either way a new clutch is need and as these vehicles are rear wheel drive they are not difficult to renew ,Just have to make yourself a clutch alignment tool from a broom handle .Dont be scared of it they are not that difficult to do just dirty and messy thats all the hardest part is aligning the clutch so the spigot shaft goes through easly and you dont have to struggle pushing the gearbox in
Dec 12, 2009 | BMW 325 Cars & Trucks
Where is the torque converter and drive plate on 97 eclipse gst manual transmission.. so i may markmatch it before removing the tranny
hi, if you have a manual gearbox then you dont have a torque converter a torque converter is what changes the gears in an automatic gearbox as your is manual all you will have inside your gearbox is a pressure plate a clutch plate and a thrust bearing witch operates the clutch when you press the pedal down.
The only thing you need to line up on a manual box is when you have fitted the new clutch you need to have a tool that holds the clutch plate central so that when you tighten the bolts up on the pressure plate the clutch stays central if you dont do this you wont be able to get the gearbox back onto the engine as the spline from the gearbox wont be able to go through the center of the clutch into the engine.
You can make or use you own tool to hold the clitch dead center as long as its a good fit and about the same size as the spline, so once you have the new clutch in and the pressure plate loosely bolted on you can still move the clutch around behind the pressure plate now right in the center their is a hole in the pressure plate and the clutch plate this is where the tool needs to be put so that the clutch plate remains dead center whilst you tighten the pressure plate up this will then make sure that the spline on the gearbox lines up properly not doing this will make it impossible to get the gearbox on properly.
Let me know how you get on or if you need further assistance ok
Nov 07, 2009 | 1995 Nissan Pathfinder
How easy is it to replace a noisy clutch thrust bearing. 53 plate Ford Focus 1.6 petrol zetec.
The thrust bearing is normally a part of a new clutch kit.Comprises pressure plate, clutch plate and thrust bearing.You will need to remove the gear box to change the bearing.The bearing basically slides onto the gearbox shaft. Recommend changing all three rather than just the beaing.You may want to get quotes from garages as dealers are expensive.
Mar 08, 2009 | 2003 Ford Focus
Clutch slip problem when gears are changed after 4000 rpm
you have 20k miles after the clutch has been changed, now are you used to drving clutch, secondly is it hydraulic or cable controled clutc?
if you are used to drving clutch sys probable cause is defective pressure plate or the throwout bearing is not fully releasing in other words the clutch is partialy applied all the time because of the re;ease bearing not fully releasing!!
Nov 13, 2008 | 2006 Volkswagen Jetta
Vehicle Parts & Accessories Logo
73 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
steve morris
steve morris
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
