Question about Mattel Toys
How long should I charge a Tyco Air Blade 12v battery?
How do I get a new battery
I guess you have to decide whether it is worth it to you to replace the battery or get a new compressor altogether. I recently replaced my battery with a 12V 7.2AH Sealed Lead Acid (SLA) Battery. Pretty much the kind used for computer battery backups (UPS). There are plenty to choose from under $20 at Amazon and eBay. Just copy the bolded text above and perform a search.
Jun 10, 2013 | Campbell Hausfeld Cordless Air Compressor...
Need the 6bdc battery pack for tyco sea arrow
there should be a battery box that holds four AA batteries. The box fits in the boat.
May 11, 2012 | Tyco Radio Control Sea Arrow Boat 27mhz
1998 Tyco Boat needs battery
This is not the reason. The dual contacts in the boat are there to accommodate two types of battery packs. Only one pair is used at a time.
Mar 23, 2012 | Tyco Radio Control Sea Arrow Boat 27mhz
How to tell if battery is full charged before using it.
The easiest and best way to test any battery is with a volt-meter.
http://www.northerntool.com/shop/tools/product_12496_12496
The link above is for a multi-meter. These are inexpensive and are an extremely useful tool to have. For about $15-20 you can buy a meter which will test AC/DV voltage, resistance/continuity and often diodes and/or transistors as well.
A fully-charged 12v battery will give a reading of 12v (or very close to 12v) on a volt-meter when it is fully-charged. 6v batteries should read 6v, 1.5v batteries should read 1.5v, etc, etc.
If the reading is lower than the power output of the battery, the battery is either not fully-charged or one or more cells may be damaged. If cells are damaged, you will never get the full 12v output from a 12v battery.
There are other ways to test batteries but they are less accurate. It's possible to use a battery charger, but you can only use this to determine whether a battery is fully-charged if the battery is known to be good. A fully-charged battery should draw 0 amps on a battery charger, but a damaged battery may also draw 0 amps so this is not a good test.
Basically, I'd suggest you get yourself a multi-meter. You be glad you did!
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric.
Mar 11, 2011 | 300 Amp Battery Jumper with Air Compressor...
How long do you have to charge the 12 volt battery for?
how long to charge the 12volt battery pack, using a 45va step down from 240 uk to 110 volt
Aug 30, 2010 | Mattel Tyco R/C Air Blade Hovercraft -...
Do you know how long to charge the 9.6V NiMH Battery for?
the first two charging cycles you are to charge it no less than five and a half hours, after that you only need to charge it for four hours. REMEMBER!! never charge a hot battery, allow it to cool completely before re-charging.
Oct 11, 2009 | Tyco Rc Turbo Pro Wheelie Cycle
How long is needed to recharge the Tyco R/C 9.6v turbo NiCd batte
It appears your battery pack has a capacity of 700 mAh.
If this is correct it would take 3.5 hours to charge with a 280 mA charger.
Apr 11, 2009 | Toys
Lost remote control
wath frecuency is the air blade i have one remote control opf a air blade but i need to know if is a 27 or 49 mhz
Nov 24, 2008 | Tyco Radio RC Batcycle Batman
Toys Logo
Top Mattel Toys Experts
thegtw
Tracy E
Level 1 Expert
Tom Chichester
Are you a Mattel Toy Expert? Answer questions, earn points and help others
