Question about Nokia HS-23 Headset
HOW TO CONNECT THE COLOURED WIRES TO 9 PIN SOCKET IN HS 23 HEAD SET
3 Suggested Answers
SOURCE: please help me with a diagram for hs-23 plug connections...
I want repair my HS-23 headset. But I haven't that's wiring diagram.
Posted on Oct 01, 2008
SOURCE: HS-23 problem disconnected
Assuming that the joint which connects the neck strap has been damaged ( see below image )
, I advice you fix the loosed or broken joint back in its proper place permanently by using fevi kwik or some other fast bonding adhesive, but the only problem which will remain is that each time you have to use the headset you will have to wear it through your head andremove it the same way.
Posted on Jun 14, 2009
When i try to connect my genius hs-03u's to my ps3 it doesnt work is there any way to make them connect
First, examine the connection receptables on the PS 3. For example, inserting the head set pin into wrong PS 3 connection receptable would not produce any sound discussable.
1. The PS3 device has several connection receptacles either for video audio output or video audio in put.
2. Video audio out put only gets sound and movies out of the PS3 device to be projected on to another device, e.g. projector, TV screen or Any out put devices.
Note: You solution is to connect the headset to the out put indication area keeping in mind not to connect to the Video receptable, else would be trying to output video signals to the headset.
Caution: You do not want to connect the headset pin to the Video Audio Input receptacle areas, because, you would be trying to send signals into the PS3 device rather than get sound out.
Important Notes;
Getting signals out of a device like PS3 is inserting the headset in this case, pin connector would be inserted in the INPUT Area; keep in mind your are tryinng to hear sound, SO connect the HeadSet PIN to AUDIO reception area on the PS3 device
The same techniques is achievable for all equipment requirign connection.
REMEMBER TO PHYSOCALLY LOCATE THE INPUT to OUTOUT area on the device.
Give the following proccess a try.
contact the manual of the PS3 device refering to the device connectivity chapters or
Systems diagnostic or malfunction chapters for technical material when required.
Dec 02, 2010 | Genius HS-03U Headset
Wires for USB go to which MoBo pins?
there is two sets of 4 pin on each with an xtra ground you may not use.
Here is the link for your motherboard manual which shows the connections.
i.e you can connect your two sets of 4 wires to usb 1 or split them i.e 1 set of 4 on usb 1 and 1 set of 4 on usb 2.
http://zhornyak.com/soyo/Soyo_P4X400_Manual.pdf
Oct 06, 2009 | Soyo P4X400 Dragon Lite (P4X400DRAGNLITE)...
Fitting an internal card reader
hello weave!m just curios if that 9 pin is a serial type connection?then if it is..you shoud find an adaptor for a serial port or any port that fits ur 9 pin connector.if u can find a PCI card that has a 9 pin port..then you can connect..just feed me back for your more details.
Jun 19, 2008 | Dell Dimension PIII Tower Computer XPST500...
Creative Inspire 5.1 5200 Remote Wiring
Hi glopher
pin 1 (starting from far left when LED is facing up) = green
pin 2 = light blue/lime blue
pin 3 = black
pin 4 = yellow
pin 5 = pink
pin 6 = red
pin 7 = violet
pin 8 (far right) = blue
I hope this helps
Open345
May 18, 2008 | Audio Players & Recorders
Apr 19, 2008 | Nokia HS-23 Headset
Laptop to Tv
to make this work, we'll need all the model numbers and connector types. Otherwise, it's a guessing game, no?
Mar 06, 2008 | Dell Inspiron 2200 Notebook
Please help me with a diagram for hs-23 plug connections...
http://free-zg.htnet.hr/GoranJurkovic/nokia/
http://cellphones.hackaday.com/2005/08/16/how-to-make-a-nokia-pop-port-to-female-mini-jack-with-volume/
Dec 03, 2007 | Nokia HS-23 Headset
Nokia HS-23 Headset Logo
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
