Question about Cfm Daikin R410a Split System Air Conditioner
IN MODEL DAIKIN II INVERTER VRV MODEL RXYQ14MAY1 SL NOAOOO273 WHEN SWITCHED ON AC IS WORKING ON SINGLE COMPRESSOR IT IS NOT TAKING LOAD ON OTHER 2 COMPRESSORS I AM NOT GETTING SUPPLY TO CONTRACTORS FR
2`ND COMPRESSOR IS NOT GETTING ON AS IT IS NOT GETTING SUPPLY FROM CONTRACTOR
    New Friend:
  • 29 Answers
Replace boa
Posted on Apr 12, 2014
4 Suggested Answers
farfield
  • 462 Answers
SOURCE: will you tell me the electrical diagram of 12
Remove a door Usually the wire diag is on a cover. I do not under stand why you have so many model numbers. Unless its a generic label used on all the models. and in this case the diagram will most likely be for all them too with foot notes showing the differences. If this helps PLEASE GRADE ME ACCORDINGLY. IF not I need more information.
Posted on Mar 02, 2009
hvac1960
  • 2133 Answers
SOURCE: I have a Daikin Ducted
E5 Outdoor activation of compressor over heatprotection or motor lock.
Dear friend! Replacing spares for defective will not solve problem. But, you must know why it happened?
In your unit,Condenser unit was completely dust blocked. First clean it. And also replace running capacitor. If recently replaced, ignore it. Check motor for bearings. It's mechanism locked due to bearing worn out or weaken capacitor. Ask repairman to check with amps meter for fan and also with compressor. And also loose wiring if any. Compare with unit specified amps.Hope problem would solve now.
Posted on Jan 07, 2011
ar1965
SOURCE: VRV 3 Daikin 2 pipe system. does any one know
no communication between indoor and outdoor units
Posted on Aug 12, 2012
Idec inverter e3 problem
This is stating that there has been a high pressure error on this system.
This could be due to fan motor or air flow problems with the condensing unit, but it could also be an issue with the high pressure sensor or switch
Oct 23, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Error code e4 on daikin split system ducted air conditioner - what does it mean?
This is stating that there has been a low pressure error on the system.
This could have been caused by a blockage in the pipe work or a possible shortage of refrigerant. It could also be due to a fault with the low pressure sensor/switch.
Jan 31, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Red light blinking and no cold air provide
Indoor fan motor is not running. Check and replace it.
Aug 17, 2012 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Daikin VRV J2
This is a fault with one of the standard compressor’s current sensors.
It occurs when the units PCB asks the compressor to run but then doesn’t recognise that the compressor is drawing any current. This can be due to a fault with the compressor contactor not coming in or a fault with either the Main PCB not giving an output to the contactor or not receiving the signal from the current sensor, or it could be a fault with the current sensor itself.
Mar 18, 2012 | Heating & Cooling
Daikin error code H6 Outdoor Compressor motor position detection sensor error
sir
daikin inverter air conditioner we are replace the indoor pcb then next it gone out door pcb,next we are replaced outdoor pcb also then compressor not working oftre last we are replaced compressor then it will be giving H6 ERROR CODE please give me suggestion
Feb 16, 2011 | Heating & Cooling
Will you tell me the electrical diagram of 12 floor standing vrv daikin?the model of indoor units are fxlg63mave and the outdoor units are rxyq12p7ylk rxyq10p7ylk rxyq8p7ylk
Mar 02, 2009 | Cfm Daikin R410a Split System Air...
Cfm Daikin R410a Split System Air Conditioner Logo
127 people viewed this question
Top Cfm Heating & Cooling Experts
David Payne
David Payne
Brett Duxbury
Brett Duxbury
Thomas Woodburn
Thomas Woodburn
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
